Page 1 of 2 12 LastLast
Results 1 to 10 of 12
Thread: The first and original pi1541 hat
  1. #1
    Arananet's Avatar
    Oct 2015
    Spain
    Madrid
    5 (100%)
    Default The first and original pi1541 hat
    pi1541 is a real-time, cycle exact, Commodore 1541 disk drive emulator that can run on a Raspberry Pi 3B (or 3B+) designed by Steve White. This board has been designed using the Steve’s schematics. The installation is super easy. The board goes on the top of the Raspberry Pi 3 (like a HAT). Just plug the HAT, put the SDcard with the required software and you are done .
    This new version (different from my github version) of the board includes:
    • Custom PCB.
    • 220 2.54 connector.
    • 5 buttons.
    • Levelshifter
    • Buzzer (yes, its emulates the seek of the floppy drive), only first 9 units.
    • Plastic separator (screw required).
    All the components are presoldered.
    This board does not include.
    • Raspberry Pi 3 or similar.
    • 0.96″ OLED Screen (GND VCC SCL SDA pinout) (this used to browse the SD directly without connect the PI to the HDMI).
    More info about the Steve White project, here: https://cbm-pi1541.firebaseapp.com/
    Some good friends help me with the reviews:
    https://youtu.be/aC2hYmPMNzM
    Note: Because of I ran out of DIN PCB connector. All this new units came with a hand-made IEC cable that plug directly on the pcb. Also the last that remain units in stock will came without buzzer component. You can buy one and solder it on the PCB.
    23€ + 2€ Shipping, normal non tracked, worldwide
    Order directly from my little store: https://www.arananet.net/pedidos/pro...-1541-c-drive/
    Thanks.
    Edu.
  2. #2
    kwhizzy's Avatar
    May 2011
    United States
    West Virginia
    1 (100%)
    I ordered one. A few quick questions:
    1) Do you know of any cases (like the clear cases with open sides) that accomodate the hat and would provide at least a little bit of protection?
    2) Do I need any software to run it besides moving my SD2IEC SD Card to the Pi? For example, would CBM File Browser just come up the same as with an SD2IEC?
    3) What is the power draw? For example, would a 1 amp generic microUSB phone charger be enough (since I have many of those lying around)?
    4) Can I run the SD Card through a USB Adapter on the PI or does it need to be in the main PI SD slot?
    5) Since this is a full 1541, would it work OK being daisy chained to a real 1541 or 1571?
    6) If I have another Pi 3 B+ that is being used as a RetroPi/Amibian machine, can it still run or boot as a normal PI or does it become a single purpose 1541 emulator once the hat is installed?
    Thanks,
    Kristin
  3. #3
    Arananet's Avatar
    Oct 2015
    Spain
    Madrid
    5 (100%)
    Quote Originally Posted by kwhizzy View Post
    Thanks,
    Kristin
    Ok, some of the question I can reply others don't (software related).
    1-Not at this time. Maybe in a few weeks I made one for my hat and share on my thingiverse.
    2-You need to follow Steve's instructions.
    3-You will need like Raspberry Pi recommend any at least 5v / 1Amp power supply.
    4-I don't know, I haven't tested.
    5-This version is for use directly to the IEC port.
    6-You can exchange SD for retropie.. to pi1541 sd.. I don't fully understand this question.. if its just that or are you telling something else
    Regards,
    Edu.
    New price. 20€ plus 2€ shipping worldwide.
    Edu.
  4. #4
    Ratteler's Avatar
    Jul 2014
    New York
    0
    Hey!!! I am full on excited about this, but I have a few questions.
    1) Can you navigate through the system with open commands or JiffyDOS @commands?
    So I can change disks without actually touching the RPi.
    2) Can it do D64, D71, and D81 filetypes?
    3) Is this running on a linux os, or are you banging the metal?
    4) Can it emulate multiple drives. IE, can you have it answer as all 4 IEC devices for application that need multiple drives.
    5) Have you checked to see how much resources the RPi is using load?
    6) is there any I/O left to... say, connect the RS232 to the Pi and have it also be a WiFi modem?
    Depending on the answers... I have a FLEET of other questions.
  5. #5
    Arananet's Avatar
    Oct 2015
    Spain
    Madrid
    5 (100%)
    New price, now including OLED screen. 18 € plus shipping. BTW I have designed a case for this device. The design is available on thingiverse. https://www.thingiverse.com/thing:3001455
  6. #6
    mrr19121970's Avatar
    Jan 2016
    Germany
    Hessen
    Age
    47
    298 (100%)
    Blog Entries
    1
    Quote Originally Posted by Arananet View Post
    I think I need one of these (declaring interest - pending questions)...
    I assume, it is as pictured complete (working) with IEC adaptor and screen.
    It's missing the hex invertor ? meaning it is unsafe to daisychain IEC devices ?
    Is the buzzer also missing ?
    See www.amibay.com/entry.php?176-My-Offerings
    Speed up the transaction ?? PayPal.me/mrr19121970 as family'n'friends and PM me with what you want and where to send it.
  7. #7
    Arananet's Avatar
    Oct 2015
    Spain
    Madrid
    5 (100%)
    Quote Originally Posted by mrr19121970 View Post
    This is direct connection, not make to work with a iec chain. What you see is what you get i dont have buzzers in stock but you can buy one and solder it.
  8. #8
    Jan 2016
    Germany
    Hessen
    Age
    47
    298 (100%)
    Blog Entries
    1
    I paid (Order number: 841)
  9. #9
    rcade's Avatar
    Jun 2008
    United States
    Augusta, Georgia
    Age
    47
    5 (100%)
    If it doesn't come with the pictured buzzer, can you send a link to a compatible one?
    Pete Rittwage
    C64 Preservation Project
  10. #10
    Arnold101's Avatar
    Sep 2016
    italy
    italy
    0
    Default stock
    Hello when new stock will come? thanks
  1. For Sale Pi1541 - kits and/or assembled
    By bos in forum Commodore
    Last Post: 29th November 2018, 15:13
  2. For Sale Cables for Pi1541 - Commodore 1541 Floppy Drive Emulator
    By TREXoldcomputer in forum Commodore
    Last Post: 25th September 2018, 03:51
  3. For Sale Fully assembled Pi1541 with 2 IEC connectors
    By Bruktmoped in forum Commodore
    Last Post: 8th September 2018, 00:22
  4. Replies: 6
    Last Post: 9th August 2018, 20:26
  5. Replies: 9
    Last Post: 24th May 2017, 18:09
Tags for this Thread
