Page 1 of 31 1234511 ... LastLast
Results 1 to 10 of 303
Thread: A4000TX ATX Amiga motherboard
  1. #1
    Amibayer! hese's Avatar
    Aug 2008
    Finland
    Savo
    297 (100%)
    Default A4000TX ATX Amiga motherboard
    Let me introduce to you the latest Amiga motherboard project I've been working on.
    A4000TX ATX motherboard
    , the first Amiga based motherboard in ATX form factor (actually a hybrid ATX/EATX form factor).
    A4000TX is an A4000cr motherboard and daughterboard embedded together with a few additional features.
    The motherboard is fully hand-routed like the A4000+ Alice motherboard was.
    The specifications of the A4000TX Lisa rev 1.0:
    - fits into (E)ATX case
    - uses standard ATX power supply
    - Amiga AGA custom chipset
    - CPU slot connector for accelerator cards
    - on-board 68030 CPU
    - on-board 68882 FPU
    - 16 MB Fast RAM
    - 2 MB Chip RAM
    - four full-length Zorro III slots
    - three ISA slots
    - extended video slot
    - 3.5" IDE port
    - internal floppy port
    - PS/2 keyboard port supporting Amiga and PC keyboards (PC work in progress)
    - PS/2 mouse port (work in progress)
    - Amiga mouse and joystick ports
    - serial and parallel ports
    - 15-pin VGA port with 15kHz RGB output
    - 24-pin breakout header with full RGB port support (for external scandoublers, genlocks, SCART cables, etc..)
    - 3.5mm stereo jack
    - on-board RTC with battery
    Blank PCB
    Here are pictures of the blank pcb.
    The board is a four-layer PCB, which is quite crowded with components and traces both on the top and bottom side.
    There is no space left on the board for many additional components.
    Assembled PCB
    Here are a few pictures of the assembled PCB.
    Motherboard installed in an ATX case
    The motherboard was installed in a standard ATX case.
    Motherboard I/O connectors
    Here is a picture of the back of the case showing the I/O connectors.
    I/O connectors from top left to bottom right are
    - PS/2 keyboard (Amiga or PC)
    - PS/2 mouse (PC)
    - Amiga mouse port
    - Amiga joystick port
    - serial port
    - parallel port
    - VGA port (15kHz RGB output)
    - 3.5mm stereo jack
    Behind the VGA port is the 24-pin breakout header to which you can plug in your custom-made cable (for scandoublers, genlocks, SCART, ...).
    A4000TX motherboard dimensions
    The picture below shows how much free space is required at the bottom of the case for fitting the motherboard.
    The A4000TX motherboard is a hybrid ATX / EATX form factor board.
    The standard ATX motherboard dimensions are 30.5cm x 24.4cm, EATX has 30.5cm x 33.0cm (height x width) (EATX = Extended ATX).
    The aim was to create an Amiga motherboard that would fit to most ATX cases and still support full-length Zorro cards.
    Top side of the motherboard has standard ATX dimensions (24.4 cm wide).
    The bottom side had to be made wider (30 cm) so that full-length Zorro cards can be used with the motherboard.
    The motherboard can be fitted into a standard ATX case if there is enough space at the bottom of the case. A full-length Zorro card is 34cm long.
    Alternatively the motherboard can be fitted into an EATX case.
    In the picture the motherboard was installed into an Enlight ATX case that takes standard size ATX motherboards only, no EATX.
    And yet the motherboard fitted in well.
    Epilogue
    The motherboard is fully working (except the PC keyboard and PC mouse support that need fine tuning).
    I have some prototype boards that I will be putting for sale soon if there is interest.
    I would like to hear what you think, is there a demand for an ATX motherboard like this.
    And also if there are some features missing that you would like to have in some later revision (reasonable please, can't embed a PPC there...).
    All kind of discussion is welcome. Thanks.
  2. #2
    k0x's Avatar
    Aug 2013
    Czech republic
    Ostrava
    136 (100%)
    Big bow --- you are legend!
    Definitely interested in one piece
    Does A4000T only accelerators fit on these board?
    http://www.bigbookofamigahardware.co...t.aspx?id=2048
  3. #3
    a4Kuse's Avatar
    Dec 2013
    Germany
    NRW
    31 (100%)
    OMG.
    What a great Stuff!
  4. #4
    amigahitoro's Avatar
    Jul 2009
    Netherlands
    In the Dutch mountains
    90 (100%)
    Quote Originally Posted by a4Kuse View Post
    OMG.
    What a great Stuff!
    Awesome
  5. #5
    k0x's Avatar
    Aug 2013
    Czech republic
    Ostrava
    136 (100%)
    Feature - what about integration of Floppy-fix?
    http://amigawiki.de/doku.php?id=de:-...000t_diskmodul
  6. #6
    Inactive Member
    Amibayer!
    WonkeyDonkey's Avatar
    Mar 2012
    U.K
    Sheffield, South Yorkshire
    Age
    50
    75 (100%)
    What a fab idea this is !
    Cant see the actual pics here at work but will look when I get home.
  7. #7
    eteP's Avatar
    Apr 2017
    Germany
    Niedersachsen
    31 (100%)
    Amazing work again! Interested if you have some for sale...
  8. #8
    Joolz's Avatar
    Aug 2016
    Germany
    Bavaria
    Age
    41
    27 (100%)
    hese, this is super cool - if only for showing off what individuals in the community are capable of in comparison to others talking and rambling all the time instead of delivering.
    That being said, at least for myself I wouldn’t really have a use for it as I prefer having my Amigas in their original cases.
    As I know myself though, I might still consider getting one just to own it and maybe another for the fun of assembling it
    big thumbs up!
  9. #9
    mattymuc's Avatar
    Sep 2016
    Germany
    Bayern
    16 (100%)
    That is really awesome hese!
    The one and only thing I'm missing is the 64MB or 128MB hack to get more memory.
    I hope I can put this next to your awesome Alice 4000D in near future
  10. #10
    Lord_nelson's Avatar
    Apr 2017
    Deutschland
    M-V
    Age
    43
    31 (100%)
    Coooool! Awesome. I am interested in a prototype. Maybe a later revision can have more zorroslots.
  1. Wanted Amiga 2000 Motherboard or Repair Service for Motherboard
    By madgrizzle in forum Amiga
    Last Post: 25th June 2017, 13:12
  2. Replies: 3
    Last Post: 6th July 2016, 00:41
  3. Replies: 1
    Last Post: 17th February 2016, 15:50
  4. Replies: 0
    Last Post: 17th April 2015, 13:21
  5. Sold Amiga 1200 Motherboard 'DOA' (just the motherboard)
    By keitha in forum Sales Archive
    Last Post: 12th July 2014, 13:48
Tags for this Thread
