FastRobPlus
Nice work Hese!
See the sales/group-order thread: https://www.amibay.com/showthread.php?111871-A4000TX-rev-1-1-ATX-motherboard-PCBsInterested in one PCB, is there a forecast of availability? Thank you!
Yeah, I'm aware, but I wasn't completely sure if the 4000T rom has other (required) changes aswell, or only the SCSI support.. but ok, A4000D rom [x]You should use 4000D kickroms. The 4000TX does not has SCSI onboard.
Either the U100 (68030 CPU) or R145 needs to be installed.
If you install the CPU, don't install the R145.
If you don't install the CPU, you need to install the R145.
You have to access it through a web server. XAMPP for example.
