Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 44
Thread: A new IDE card is born! Read this thread and have fun!
  1. #11
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    now the sata drive is well inserted into the system, but i am not so happy about the speed of the disc; maybe i will try to improve it...
    The code of this device driver can manage size of the disc until 2 TeraBytes: larger HardDisk will be forced automatically to avoid addressing outside this limit.
    Cheers
    Stefano
ID:	139861 Click image for larger version.
    It seems that HDToolBox recognizes, despite the big size of the disk, a disc addressed in 28bit mode (RDB report this size and not the true size, see the picture above that show two different values).
    Here the tool in action...
ID:	139929 Click image for larger version.
    ...and a different view of the card...
  2. #12
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    ...a IOmega ZIP (IDE version)
ID:	140473 Click image for larger version.
    Now the fourth prototype
ID:	140475 Click image for larger version.
    it is very similar to the third one, but it has a slight difference on the use of some lines accessing the Zorro bus. Both cards are compliants with the protocol and all the specifications made by Commodore for this series of computer. The fourth prototype seems to be more compatible in some situations that can happens with an Amiga 2000; it need test to confirm this thing.
    Cheers
    Stefano
  3. #13
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    i am very happy because i have burned a CD, using MakeCD (the public beta) and isocd, from Commodore, to make an iso image file. The device driver seems to be ok and it will deserves to be tagged as version 1.0!! But even this CD is special because into it i have engraved forever some of my drawings and sources...
    This device driver is almost complete for MM devices and cartridges with magnetic disc, but in theory many others ATAPI devices can be used safely. ATA devices was never a problem but the removable ability of a compact flash card is not possible on a two-devices channel like this (card + device driver), especially if the CF is master: if you remove it, the device driver get confused by some replies that will be pure (in hexadecimal) $FFFF.
    Cheers
  4. #14
    TommyE's Avatar
    Mar 2015
    Norway
    Buskerud
    0
    Impressive work
    TommyE
  5. #15
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Quote Originally Posted by TommyE View Post
    Impressive work
    TommyE
    Hello,
    thanks, this work was done with passion! Stay tuned, the last part will come soon...
    Cheers
    Stefano
  6. #16
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    wish you become betatester for this project? If yes, you need to own at least an A2000 with 68020 cpu and at least a Zorro card like a graphic card installed, to do serious test; a second machine like an A4000 is very good, to do further test on both computers.
    I have planned to print this card with machinery (just a couple of boards, to see how it work), so, i will do comunication here when a card is finished and ready to be delivered, with the software, that is complete.
    Best wishes
    Stefano
  7. #17
    8 Bit Dreams DjCook's Avatar
    Apr 2016
    Germany
    Bavaria
    Age
    41
    175 (100%)
    Hello,
    im very interested to become a beta tester, do own both A2000 & A4000 Amigas, also own several accelerator cards with 020 and 030 CPU's,
    Have also graphic card PCB here, just need to assemble it. So yeah, can do a lot of tests..
    Kind regards,
    Viktor
    8 Bit Dreams - computer & hardware repair in Germany
  8. #18
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    so, when a couple of cards are ready, i will post here more info! Many thanks for your reply!
    Cheers
    Stefano
  9. #19
    Apr 2016
    Germany
    Bavaria
    Age
    41
    175 (100%)
    Thank You Stefano, will be happy to hear back from You!
    meanwhile got Subway USB, so will be also possible to test Your card with copying from/to USB devices..
  10. #20
    Marco06's Avatar
    Dec 2011
    France
    Cote d'Azur
    Age
    51
    34 (100%)
    Nice job Stefano !
    A4000D - A3640 rev.2
    A4000D modding in Big Case - Work on progress
  1. Replies: 1
    Last Post: 16th March 2015, 11:46
Tags for this Thread
