Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 76
Thread: SukkoPera's C64 Accessories
  1. #1
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    Age
    39
    49 (100%)
    Default SukkoPera's C64 Accessories: Saver, Carts & Joystick Adapters
    When I entered the '64 world I wasn't too happy with the price and/or availability of some accessories, so I just designed my own. Hopefully they will be useful to other people as well.
    For each item you can either buy the PCB alone, or the PCB plus a kit with all the components you will need to build the accessory. Either way, you will have to DIY, I will not be selling pre-built devices (Temporary exception: I have a couple of built devices available, see below).
    Note that some items require the soldering of some SMD components in the 0805 package. For those who are not comfortable with that, I am now offering to pre-solder them for free.
    If you require this service, please specify it in your order.
    OpenC64Saver - SOLD OUT
    OpenC64Saver is an implementation of the Computer Saver device developed by Ray Carlsen.
    Note that these kits are not suitable for the faint-hearted, since they require soldering some surface-mount components (0805 package). You will also have to use a variable voltage source and a precise multimeter to set the cut-off point.
    Kit contains:
    • 2x100nF 0805 Capacitor
    • 1xZener Diode 4.7V
    • 1x1N4148 Diode
    • 1x3-pin Header Strip
    • 1x3-pin Screw Terminal
    • 2x2N3904 Transistor
    • 1x820 0805 Resistor
    • 1x220k 0805 Resistor
    • 1x2.2k 0805 Resistor
    • 2x1k 0805 Resistor
    • 1x5K Variable Resistor
    • 1xSRD-05VDC-SL-C Relay
    Prices:
    • PCB: 3,00€
    • Kit: +5,00€
    • With bi-color led R/B 3mm: +0,50€ over standard kit
    • With RGB led 5mm: +1,00€ over standard kit
    • With 7-pin male + panel-mount female DIN connectors: +2,00€ over standard kit (These are useful if you want to make an external device putting the saver in its own box)
    OpenC64Cart 8k - SOLD OUT
    OpenC64Cart is an 8 KB Cartridge for the Commodore 64. It allows multicarts and comes with a reset button.
    Kit contains:
    • 1x100nF Capacitor
    • 4x3-pin Header Strip
    • 2x2-pin Header Strip
    • 5xJumper Cap
    • 1xPush Button
    • 1x28-pin Socket
    Prices:
    • PCB: 3,00€
    • Kit: +3,00€
    • With Machined-Pin Socket: +1,00€ over standard kit
    • WinBond W27C512 EEPROM: +4,00€
    OpenC64Cart 16k - SOLD OUT
    OpenC64Cart16K is the 16 KB counterpart to OpenC64Cart. It supports up to 4 images in a single cart.
    Kit contains:
    • 1x100nF Capacitor
    • 2x3-pin Header Strip
    • 2xJumper Cap
    • 2x1n4148 Diode
    • 1x10k Resistor
    • 1xPush Button
    • 1x28-pin Socket
    Prices:
    • PCB: 3,00€
    • Kit: +3,00€
    Open2327RomAdapter - 11 KITS AVAILABLE
    Open2327RomAdapter is an adapter that allows the use of a 27xxx EPROM in place of a 2364 PROM. This is mainly useful for replacing the KERNAL and other ROMs in Commodore 64 and VIC-20 home computers and 1541 drives.
    This kit requires the soldering of three 0805 SMD resistors.
    Kit contains:
    • 3x10K 0805 Resistor
    • 2x12-pin Header Strip
    • 1x28-pin Socket
    Prices:
    • PCB: 3.00€
    • Kit: +2,00€
    OpenC64MegaDrivePadAdapter - 1 PCBS + 1 KIT AVAILABLE
    OpenC64MegaDrivePadAdapter is an adapter that allows the safe connection of a Sega Mega Drive/Genesis controller to a Commodore 64 computer. Also works with Amiga!
    Kit contains:
    • 1xDB9 Male Connector
    • 1xDB9 Female Connector
    • 5x1n4148 Diode
    • 2x2.2k Resistor
    • 1x100k Resistor
    • 1xBC547 Transistor (Or equivalent)
    • 5x3-pin Header Strip
    • 1x2-pin Header Strip
    • 4xJumper Cap
    Prices:
    • PCB: 3.00€
    • Kit: +5,00€
    OpenC64TapePortBreakOut - 10+ PCBS AVAILABLE
    OpenC64TapePortBreakOut is a PCB that breaks out all the pins on a Commodore 1530 Datassette Connector. It is mainly useful for building Tapuino devices.
    NOTE: PCBs currently on sale have a BLUE solder mask.
    Kit contains:
    • 1x6-pin Header Strip
    Prices:
    • PCB: 3.00€
    • Kit: +1,00€
    Payment methods accepted: PayPal Family & Friends (or add commissions), Bank Transfer, Satispay (for Italian buyers)
    Items will ship worldwide from Italy. All shipments will be trackable and at cost. As a rule of thumb, shipping for up to two-three kits (total weight up to 100 grams) should be 4,30€ to Europe, 5,20€ to the US and 7,10€ to Australia. Add 6€ for tracked & signed for. Ask for exact quote.
    Items are also on sale elsewhere.
    Please note that I designed all of these boards primarily for my own use. I am open to suggestions and (constructive) criticism. All of my projects are Open Hardware, feel free to check out the KiCad design files on GitHub.
    There is more to come, but this is it for the moment. Feel free to ask any questions.
    My Sales:
  2. #2
    botialoach's Avatar
    Mar 2014
    Cyprus
    Nicosia
    65 (100%)
    Question about OpenC64Cart 8k, you put up to 4 games on the card and play them with your C64, how are the games transfer to the card? Can you give me a link of how to use it? Thank you
  3. #3
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    Age
    39
    49 (100%)
    You don't put the games directly on the card, but rather on an (E)EPROM, such as the Winbond W27C512 I have for sale.
    To program the EEPROM you need a programmer, I recommend the TL866 from autoelectric, which is widely available, quite cheap and reliable. I use an CS model, but nowadays I think you can only find the II model, which should be OK anyway.
    Also note that the W27C512 is 64K, so with the 8K cart you can have up to 8 games.
  4. #4
    piacc64's Avatar
    Mar 2011
    Italy
    Piacenza
    128 (100%)
    hi
    i need one pcb OpenC64Cart 8k
    payment sent
  5. #5
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    Age
    39
    49 (100%)
    Cart for piacc64 sent this morning.
  6. #6
    Amibayer! demolition's Avatar
    Oct 2012
    Denmark
    Copenhagen
    Age
    39
    67 (100%)
    Declaring interest in:
    1x OpenC64Cart 8k PCB only
    1x OpenC64Cart 16k PCB only
    3x Open2327RomAdapter PCB only
    5x 3€ = 15€ plus postage. Will they fit within 100g?
    A1200 (NOS) : 030 33MHz 128MB fast RAM (ACA1232) : Indivision AGA MkII : 8GB CF : RR USB : Ethernet
    A600 #1 : 080 V2 : 128MB fast : 2MB chip : Indivision ECS : 32GB CF : RR USB
    : Ethernet | A600 #2 : 010 : 2MB chip
    A500 : 68000 42MHz : 1MB chip : 8MB fast : 4GB CF | A500+ : 080 V2+ : 128MB fast : 2MB chip : 32GB CF
  7. #7
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    Age
    39
    49 (100%)
    I think they'll even fit 50g, but I only have 2 Open2327RomAdapter PCBs at the moment.
  8. #8
    Oct 2012
    Denmark
    Copenhagen
    Age
    39
    67 (100%)
    No problem, then I'll just take the two. Will send PM.
  9. #9
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    Age
    39
    49 (100%)
    Payment received from demolition, will ship ASAP.
  10. #10
    Half-Brite's Avatar
    Sep 2018
    Nottinghamshire
    1 (100%)
    Hi
    Please can I order 2 OpenC64MegaDrivePadAdapter PCB+Kits, for shipping to the UK.
    Thanks,
  1. For Sale PS2 accessories
    By slk486 in forum Other
    Last Post: 28th July 2013, 04:09
  2. Replies: 4
    Last Post: 5th March 2013, 12:47
  3. Closed C64 and Accessories
    By Craig in forum Sales Archive
    Last Post: 18th June 2012, 01:11
  4. Closed MZ-700 with some accessories
    By wilsonsamm in forum Sales Archive
    Last Post: 15th June 2011, 14:58
  5. Closed Plus 4 accessories
    By Xenobiotical in forum Found Archive
    Last Post: 13th March 2011, 21:21
Tags for this Thread
