Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
Thread: 4x IDE Adaptor (A4000 (T) / A1200)
  1. #1
    Fook42's Avatar
    Sep 2016
    Germany
    Niedersachsen
    27 (100%)
    Default 4x IDE Adaptor (A4000 (T) / A1200) - IDE Fix compatible !
    Hello,
    i would like to share a small project i did.
    the idea comes from the AMINET (here) and gives the following benefit to the IDE-Port of Amiga 4000(T) and Amiga 1200 :
    the IDE port usually provides 1 channel (Master+Slave). But in the Amiga the port contains 2 select lines (CS1 and CS3) where only one of them is currently used.
    these 2 lines can be used to create 2 IDE-channels (each serving a Master and a Slave-Device) using only 2 Diods and some wiring.
    So you end up with 4 IDE devices being connected to your System instead of only 2
    To be able to use the second channel, you will need a patched scsi.device !
    But at this point the Adaptor is using the same mechanism as IDEFix! uses, so installing IDEFix (IDEMax)-Software will give you a new scsi.device that recognizes the 2nd channel properly. (this can be seen at the screenshot i attached - new scsi.device has a different version 119.19).
    So i created some PCBs and with them complete Adaptors that can easily be plugged to the IDE-Connector on the Mainboard (A4000(T)) or using a 44pin->40pin-Adaptor to your A1200.
    here is the result: (complete adaptor, PCBs, screenshot showing 3 devices on my Amiga4000, mounted in the A4000 - it fits perfectly under 2 ide-drives)
ID:	141949Click image for larger version.
ID:	141950Click image for larger version.
ID:	141951Click image for larger version.
    price for assembled adaptors: 13 Euro 12 Euro + shipping
    price for unassembled kit: 10 Euro 9 Euro+ shipping
    shipping in germany: 3 Euro
    shipping in europe: 5 Euro
    [if you order more than 1 item, please ask for shipping-costs]
    thanks,
    fook42
    Last edited by Fook42; 10th August 2019 at 16:33. Reason: price reduced.. will produce as many as required
  2. #2
    Fook42's Avatar
    Sep 2016
    Germany
    Niedersachsen
    27 (100%)
    UPDATE: .. also offering unassembled Adaptors (consist of PCB, Connectors, Diods) ..
    price: 10 Euro + shipping (see above)
  3. #3
    Kavven's Avatar
    Feb 2018
    Sverige
    Medelpad
    1 (100%)
    Declare inrerest of two unassembled.
    Pm sent.
  4. #4
    Fook42's Avatar
    Sep 2016
    Germany
    Niedersachsen
    27 (100%)
    PM replied, packet with 2 Adaptor-Kits shipped to Kavven.
  5. #5
    Fook42's Avatar
    Sep 2016
    Germany
    Niedersachsen
    27 (100%)
    XMAS-Sale offer ..
  6. #6
    Teps71's Avatar
    Jun 2018
    United States
    Ohio
    11 (100%)
    Declaring interest for two unassembled kits.
  7. #7
    Fook42's Avatar
    Sep 2016
    Germany
    Niedersachsen
    27 (100%)
    PM answered with details..
  8. #8
    Fook42's Avatar
    Sep 2016
    Germany
    Niedersachsen
    27 (100%)
    2 Adaptors for Teps71 .. packed and will be shipped on monday
  9. #9
    Fook42's Avatar
    Sep 2016
    Germany
    Niedersachsen
    27 (100%)
    small price update...
  10. #10
    cvtof's Avatar
    Oct 2016
    France
    Pas de calais
    4 (100%)
    hello Declaring interest for 1 assembled adaptors.... thank
  1. Found A4000 rgb to vga adaptor
    By Coope in forum Found Archive
    Last Post: 20th June 2016, 23:02
  2. Replies: 28
    Last Post: 11th April 2015, 14:21
  3. IDE HD and CF adaptor on A4000
    By p_a_green29 in forum AmiOracle
    Last Post: 3rd May 2011, 20:31
  4. CF->IDE adaptor on a4000, HDD light always on?
    By WhyreByter in forum AmiOracle
    Last Post: 3rd April 2011, 15:56
Tags for this Thread
