I got this converter with the intention of using it with Amiga RGB but I cannot make it detect RGB signals. When I apply an Amiga RGB signal, it writes CVBS in the corner so it is trying to display a composite signal and does not switch to RGB mode. It displays a picture from my C64 using composite so it is partly working. Also included is a single page manual which states that it supposedly should support RGB mode.
I cannot be bothered to make it work since I got another one that works with RGB, so I thought that maybe someone else want to try it out. The AC adapter has a US plug so you will probably need an adapter (not included). Alternatively, you might already have another suitable 5VDC supply lying around.
Price 5 EUR plus fees and postage (~7.5 with tracking for most EU countries).
ID:	142176Click image for larger version.
ID:	142177Click image for larger version.
