Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
Thread: Open68000Relocator: A500 CPU Relocator that does not interfere with Kickstart
  1. #21
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    39
    38 (100%)
    And received!
  2. #22
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    39
    38 (100%)
    Payment received from go0se, too.
    All shipments should take place tomorrow.
  3. #23
    pillock's Avatar
    Mar 2018
    United Kingdom
    Leicester
    39
    1 (100%)
    Apologies, no longer needed. Can't delete post?
  4. #24
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    39
    38 (100%)
    I have exactly 3 PCBs left, but I'm not sure about the other components. I will check and report later.
  5. #25
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    39
    38 (100%)
    Correction: I only have 2 PCBs left.
    @Pillock: Ok, noted your withdrawal of interest, no problem.
    Packages for @theq1337 and @go0se sent this morning.
  6. #26
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    43
    9 (100%)
    Item recieved... Installed in my 500, and is working like a charm. Thanks to this relocator, I now have finished my 500-TF530 machine. Thanks.
    You can see the board in my blog here below...
    https://to9xct.blogspot.com/2018/12/...500-turbo.html
  7. #27
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    39
    38 (100%)
    Glad you enjoy the relocator, and kudos for the great work on your Amiga and the detailed review!
    One thing: Kickstart 1.3 and earlier could only boot from DF0:. That means that when you swap the drives you will only be able to boot from DF1:. Also keep in mind that with most drive swappers the internal drive is not usable (it remains sort of invisible) when the swapping is in place.
  8. #28
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    43
    9 (100%)
    Quote Originally Posted by SukkoPera View Post
    Yup... The idea (and I think I have mentioned it somewere in the blogpost), is that I want to be able to switch to 1.3 and use external Gotek at some point in time. This is to preserve real disk loading internally. So the BootSelector expansion choice, is well thought out. The 3.1 Rom selector is only because I want an internal harddrive, and because I do not want harddrive access when I switch to 1.3 and because of the 3.1 Rom then I can have access to writing ADF off the harddrive or dive into WHD-Loader if I choose to set it up with that. All in all, a well thought expanded 500.
  9. #29
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    39
    38 (100%)
    Of course it is... I have a 500+ with the exact same configuration, except for the Indivision . I use it with an LG 26" TV that displays an amazing signal through RGB!
  10. #30
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    43
    9 (100%)
    You have an Indivision in yours? Personally I like my ScanPlusECS better. It only outputs 50hz refresh rate, yet that gives 100% smooth scrolling, so I am lucky that my Sony LCD can do 50hz. No need for IndivisionECS.
  1. Replies: 5
    Last Post: 4th November 2018, 04:10
  2. For Sale A500 CPU Relocator ( 90 degree ) Ideal for TF530
    By KGC210 in forum Amiga
    Last Post: 9th July 2018, 13:02
  3. Replies: 5
    Last Post: 24th June 2013, 01:49
  4. Replies: 4
    Last Post: 28th March 2013, 08:50
  5. Replies: 3
    Last Post: 24th December 2010, 19:15
