Results 1 to 6 of 6
Thread: Mixer Error 80000020 message
  1. #1
    Roysters Roysters's Avatar
    Mar 2019
    Bracknell, Berkshire
    Age
    59
    0
    Default Mixer Error 80000020 message
    Hi
    I have at least 3 CF cards with this message now.
    Trying to install my Mediator PCI 1200 LT4 with a S3 Virge card but every time I install the MM software when I reboot the above message occurs.
    Is there any way I can recover these cards and is there a set install procedure I am unaware of ?
    Thanks in advance
    Roy
  2. #2
    Warp One, Mr. Sulu VIP
    Amibayer!
    J.T.Kirk's Avatar
    Aug 2008
    Hellas
    Chania, Crete
    206 (100%)
    Mixer error? Have you installed any Mixer tool for sound cards? If yes, then delete it.
    You are standing at the end of a road before a small brick building. Around
    you is a forest. A small stream flows out of the building and down a gully.
    > GO EAST
  3. #3
    Math inside Amibayer! BLTCON0's Avatar
    May 2011
    Hellas (Greece)
    Chania, Crete
    Age
    43
    96 (100%)
    Quote Originally Posted by Roysters View Post
    Hi
    Thanks in advance
    Roy
    Using other PCI cards on the Mediator requires some video RAM reserved as PCI DMA buffer, IIRC. Is this actually supported with the Virge card? Maybe it's only with Voodoos and Radeons (the implication being if you use a Virge card, it's the only card that should be installed).
  4. #4
    Mar 2019
    Age
    59
    0
    Hi
    I only had the Virge card installed at the time of MM installation. I mainly would like advice on recovering the CF cards if possible. Booting with no start-up doesn't work either
  5. #5
    Mar 2019
    Age
    59
    0
    Recovered my CF card, installed Mediator and the graphics drivers for the Virge, it says it should be Cybergraphx and renamed Virge after install. Which I have done but now I am damned if I can find the Virge help files. I can find the Radeon and Voodoo but not the Virge. Have ordered a Radeon in desperation
    Bugger, but this is hard
  6. #6
    Mar 2019
    Age
    59
    0
    Thanks to all who replied. I now have a Radeon 9200 plugged in and am going to search this forum for advice before I try it out. Wish me luck
Tags for this Thread
