Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: AAlchemy custom PSU
  1. #21
    sdz's Avatar
    Feb 2019
    Romania
    Brasov
    30
    8 (100%)
    Hello,
    A 500W power supply should be more than enough to power one AA5 board and the rest of the system.
  2. #22
    Thank you very much for you answer.
    For a graphic card Aalchemy 8164 512mb is correct this model of PSU 2,7v ?Click image for larger version.
ID:	151343 Is the connection made only through these 5 links as shown in the picture?
    Thank you
    Best regards.
  3. #23
    sdz's Avatar
    Feb 2019
    Romania
    Brasov
    30
    8 (100%)
    You're welcome.
    Yes, 2.7V is fine, it should be correct for all AA5 cards (I explained why some posts ago), regardless if they are marked as 2.7V or 2.9V.
    And yes, only 5 links are required, you need to use 5x M3 screws, 4-5mm length should be OK. There are some photos in the first post in this thread showing how the PSU is installed on the AA5 card.
    If the 5x pads on the AA5 card are dirty/oxidized (they usually are), be sure to clean them on both sides before installing the PSU.
    Don't forget to add some cooling, both the AA5 and the PSU need it.
    Regards,
    sdz
  1. Wanted A600 custom LED's
    By Climat in forum Amiga
    Last Post: 14th December 2014, 16:40
  2. My custom A4000D...
    By mfilos in forum Photo Booth
    Last Post: 29th July 2012, 08:35
  3. Closed not sure about this post but custom 3.9 rom
    By Justin in forum Found Archive
    Last Post: 26th February 2011, 17:30
