Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: 3.1.4 and Autoconfig
  1. #1
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Default 3.1.4 and Autoconfig
    Hello,
    do you know if there is some issues with Autoconfig and zorro cards, with this new version of OS?
    And if there is some materials for developer free?
    Thanks in advance
    Stefano
  2. #2
    SYS64738 Amibayer! Storm's Avatar
    Jun 2010
    Victoria
    Age
    46
    57 (100%)
    So far I haven't noticed any cards of mine acting strangely with OS 3.1.4. I have a very expanded Amiga 2000 and 4000.
    Retired original Sysop of the Shoikan Grove BBS Australia.
    Amiga 500, 500+, 600, 1000, 2000, 4000 and CD32
    Commodore 64 and 16 PowerMac Dual G5 & G4 Mini with MorphOS
  3. #3
    Jack of Many Trades, Semi-Master of Some thebajaguy's Avatar
    May 2017
    United States
    Rhode Island
    34 (100%)
    I did a lot of testing of the 3.1.4 AutoConfig in the beta. It is actually cleaner than it was in all previous versions. We kicked some bugs that have been around (technically) since KS 1.2/1.3 - although, in all fairness, the CPUs needed to uncover them weren't around until the early 1990's. In particular, we cleaned up a number of race conditions that affected high speed CPU cards (040/060) combined with some pokey PICs - in effect, expansion hardware being too slow for the newer CPUs execution of expansion.library. There are now definitive delays between the read and write of a card's registers, and between cards handing off the AutoConfig signal to the next slot (both in Z2 and Z3 space). There was also some cleanup done on last-board/full 8M space that someone else found. Just know that designers should make their boards be able to be 'shut up' (disappear), but alas, some older hardware was never able to. A board that can't be shut up (because there's no space left) halts AutoConfig of the next board that might be able to fit if of a different type. The biggest culprit are the big 8M space cards (it's easy to over-fill that space).
    I personally know of one bug that remains in Z2 config, but it's an extremely rare 'full Z2 I/O space' issue, which means you have to try to overfill the $E90000-$EFFFFF I/O zone, and also have cards that are not able to be 'shut up'. I happen to have a few rare I/O boards that consume 128K I/O slots (you wouldn't normally have 2 of them in a system) instead of the typical 64K, and a few multi-function cards that combine with them to make the perfect storm. It's actually impossible to overfill a large back plane (A2000, 3000T/4000T) with only 64K PICs (you have 7 64K windows, and at best 6 slots) even with the CPU slot and the cards currently available.
    The 3rd Edition of the Hardware Reference Manual (the 5-book RKM set) still applies - there are online copies scanned that you can browse or download (PDF), although paper copies (which I prefer) won't be free unless you are opportunistic and lucky. Combined with (optional) SAS/C 6.58 (6.50 + 4 patches) or ASMOne, and the Amiga OS updated headers and includes posted on Aminet since 3.1.4 release, you will have what you need.
    A500(2x)/A1000/A1200/A2000(4x)/A3000D(2x)/A4000D(under repair)/A4000T (all loaded....Toys...Toys...Toys...)
    Former GVP Tech Support 1989-93 - The beatings will continue until morale improves...
  4. #4
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    thanks to all of you! I will read carefully your reply to understand if this is the case.
    I have started this thread because a test of my ide card, done on a 3.1.4 system, has poorly failed. So i have read the spec. of this new 3.1.4 and read the sentence on the Hyperin's site '...it has more robust Autoconfig' i was feared about some incompatibility with the code inside my own card (made by me, look at my thread for IDE@ZII).
    Later i have discovered that, the 3.1.4 was not the point, the issue on a test made on an A4000D was on the machine itself.
    Many thanks
    Stefano
  5. #5
    May 2017
    United States
    Rhode Island
    34 (100%)
    While we went through testing, one thing to keep in mind was that with the A3000 (and presumably the A4000), the SuperBuster and the bus buffers can present a challenge when you try to poke/read at actual hardware (i.e. bi-directional registers). There are some instances, as put by some former Commodore and 3rd party engineers, where some of the bus buffers get 'sticky'. One might read a phantom value from the previous write cycle to a register. It's been suggested that hardware mirror it's registers (make one set read, the other set write), and even provide byte-swap versions of them if there are Big/Little Endian conversions involved, to ease the chances of the bus ghosts appearing. One may have to build a definable delay before performing a read off a card too soon off of a write, as circuit propagation delays were rarely an issue with the Zorro II/68K's 4-cycle (or more) 7Mhz propagation and possible code overhead, but a 68040/68060 running from an instruction cache and a high clock speed can potentially get back to that board very quickly, as in the next valid bus access.
    There are some pitfalls (in general) one should account for between the different CPUs. This came out of some Zorro III discussions. One I recall is a recommendation that all registers be safe to read or write a 32-bit long word valuie, and that they appear on 32-bit long word boundaries, or even quad-longword boundaries, if performance is an issue. The 040 and 060 don't have the bus-sizing logic the 68020/68030 do, hence the 32-bit long word alignment, and of course the 68000/10 needs/prefers most everything aligned on 16-bit words.
    I'm not privy to the actual code, but this is AutoConfig: A PIC is signaled to appear at the address for configuration (in Z2, this is $E80000) with the CFG_In line. Expansion library code reads the board's identifiers and requirements (maker, model, board type and size, can it be shut up, and if there is a diag ROM - (i.e. - driver) to be accounted for/activated later, and is there another on-card board (chain config) behind it, etc. Upon deciding where it can go, expansion.library writes it's configuration destination base address to the PIC and the card relocates there. The programming of the address causes the board to (if the last in the on-card chain) signal it's CFG_Out for the next card to appear at the config address. An on-card chained config would presumably act similar. Later on, expansion.library activates ROMs and allocates further resources based on driver needs.
    I don't believe the OS's board config structure changes at all. Olaf Barthel (involved in the 3.1.4, also) has noted to me recently that the OS 3.5 developer updates are the (overall) current ones, and minor updates for things like the RDB and FFS structure additions are in the latest includes on AmiNet. I'm working on an updates FastPrep/ExpertPrep, and I need to deal with >32-bit integers now (large disk and partition geometry) and things like the SCSI_Direct flag for the FFS.
  6. #6
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    i have read your reply (more times to be honest), and to link solutions to the fact that my IDE card, by someone poorly tested in a A4000D (sometimes not seen by the system and sometimes with issues with 040 cpu, like read/write errors); where actually two of them are in my plain Amiga 3000 and are used daily without any issue (by the way, is useless a card that give I/O errors!); i come to the conclusion (this card is a Zorro II card, so, as 'Slave' PIC, is the buster responsable of the cycle timing of the CPU, whatever it is) that the resistors used for the comparator to the Zorro II address are not right in value. I have used sometimes 8k Ohm for the lines with value 'one', where some old card use 10k Ohm and a well know USB card uses about 50k Ohm! My card in a A4000 fails with expecially third parts daughterboard, where in my system work rock stable.
    Or far more realistic, a defective solder joint (the card was seen by the system, at first shot, then the tester has reported, later, issues): i have soldered all the parts :-/
    By the way, until today i haven't seen nor pictures neither videos of this test done with my card, never seen a text file of the debug version of the device driver of my card; so i argue that the problem can be at electrical level.
    I have heard about a relative new Zorro card that gave problems with 040/060 cpus; this card was a combi card with ethernet and ram, but i suppose it is a Zorro III card and not a Zorro II.
    Stefano
  7. #7
    May 2017
    United States
    Rhode Island
    34 (100%)
    I'm not sure where the answer lies (vibros) with your situation, but I happen to have gotten some real Hardware Reference Manuals (3rd edition) last week, and re-read a few areas again.
    Zorro II backplane (A2000) is terminated by a cap and resistor connected to Ground for termination. Relative to that, the A500/1000 has no termination on the edge connector, sans the sidecar/addition module provides, and expansion cages could go either way. The A3000/4000 expansion must use something different, and does. It uses both pull-up/pull-down resistor pairs to be more friendly to the higher speeds needed for signal propagation. I'm not sure what the replacement Z2/Z3 daughter card uses. This difference in termenation can cause problems for some poorly designed PICs.
    C= also notes that cards built to 'behavior' rather than to 'the specs' are going to have issues depending on how far out of timing they are. Buster 6/7 is going to be fine for slave-only Zorro II, but there are known issues with some Z2 DMA (and ChipRAM) that are only fixed with 1) Buster -11, and when it comes to an A3640, with the 2) Rev 3.2 fixes. Dave Haynie has documented this in his 'definitive buster' notes, and the timing fixes he mentions are provided in the revised A3640 parts some sell pre-programmed. It doesn't hurt to also chase down the A3640 wait-state removing GALs designed by SpeedGeek while you are updating the board. Other cards may also see the Z2 issue depending on the sampling of a certain signal he mentions.
    As for AutoConfig, if identified as Zorro III, it gets sent high to Z3 addresses. If it is Z2 I/O, it goes to $E90000-$EF0000 or 8M space if big ($200000-8FFFFF). There's also a 3.1-OS defined potential to show up in $A00000-$B7FFFF (Page 388, and a diagram on a nearby page) but I don't think it gets used (I'm investigating) yet by any expansion.library, but may in the future). AutoConfig is the expansion library means to configure cards. 3.1.4 fixed some expansion.library code that fast CPUs could exceed the reasonable hardware speed between board config signals, but they won't fix bad or marginal board-driver behavior.
  8. #8
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    a fast reply (with a question) because i will read carefully your whole text later. How affordable can be a Zorro II card build around a plain 3000D?
    Regards
    Stefano
  9. #9
    May 2017
    United States
    Rhode Island
    34 (100%)
    Really quick, 2x 8-bit bi-directional data bus buffers, an 8-bit address line buffer for your 8-important address lines you typically have to listen for (8M->64K), a 74-series address decoder on the address buffer lines to know when (at what address) to respond to the bus, a GAL for the AutoConfig board-info that expansion.library reads when the Config_In line is signalled, a GAL for a custom address decode register when you are programmed by the AutoConfig/expansion.library logic (you are given your base address to move to) - it alters the decoder mentioned earlier, plus I think 2 smaller TTL logic parts will be needed for the bus signal lines you have to have good current driving on the expansion bus. Passives, headers, connectors, as needed.
    Internal (on the card side), a decoder or GAL logic to split up your 64K board into something like four 16K segments, maybe decode the AutoConfig info in one 8K and the programming register(s) go in the other 8K. You will need some spare logic gates at various points to trigger basic things with clock signals and/or latch data with bus signals, so common (N)AND/(N)OR/XOR parts.
    You need your choice of custom purpose chip (look at many of the I/O boards out there of PC-XT-like function), and you decode it's registers into to one of the 16K segments - the driver reads and writes to these to perform I/O. Keep an eye on best practices - 32-bit longword alignment of registers (performance killer on 68020+ if not), no odd-byte aligned 8/16/32-bit register accesses (a 68000/68010 no-no), separate read and write registers (or mirror them if bi-directional - it's an A3000/A4000 thing called sticky bus buffers). A big/little endian byte swap trick can be done with the mirroring if dealing with 16/32-bit Intel integer data.
    A ROM can go into another 16K (2x 8K EPROMS, or signal in AutoConfig it's 8-bit diag, and to copy it to RAM) or none if you will load software for it later.
    If the chip and the Amiga should share common SRAM, you could put 16K (8K x 8 x 2 give 16-bit) of it in another bank, or leave it for future expansion with another add-on chip. Additional logic overhead for this might apply.
    For a memory board, the base logic is the same for AutoConfig (but that board address segment disappears from the address space once configured), and with address decode still needed once programmed, although simpler. The bus buffers will still be needed, plus you have to add memory refresh logic with DRAMs using additional logic and clocks. Any one of the 2MB or 8MB FastRAM boards made of TTL logic are examples.
    Much of the non-buffer logic items can eventually end up in a 5V-tollerant custom gate array component. JTAG programmable devices might be able to be directly connected to the needed TTL bus buffer/driver parts, and you just plug in your chip of choice on the 'other side' and do your pin programming/glue logic from there.
    Hope that helps. I take this basic list from the GVP Series I and II cards, A2091, and a few others of the I/O type.
  10. #10
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    as ever, thanks for your reply; i will read it later, and sorry about my poor english language: on the post above, i mean 'i reply with a question'!.
    Quote Originally Posted by thebajaguy View Post
    C= also notes that cards built to 'behavior' rather than to 'the specs' are going to have issues depending on how far out of timing they are. ...
    that's true! I have built hardware and software (i mean content of the PLD of the card) with regard of what i have read on the document 'A500 A2000 Technical Reference Manual' about the signals of the Zorro II bus and the timing, and all was respected (nature of every signal generated by the PLD) during develop of this card; then the technical manuals of Motorola for MC68000, MC68020 and MC68030 and the specs of the IDE bus and his timing, by X3 (from T9.2 and succ.); and all the signals was measured and i was happy and sure about a good result...and that was on my Amiga 3000D.
    If i could to sketch a graph of what happened to my card sent for a test, this will look, more or less, so:
    the first day the card was seen by the system (Autoconfig) but the device driver (installed later) fails; presumably this happens more time the same day;
    a new day, time to change daughterboard and later motherboard of an Amiga 4000D; the card is sometime seen by the system, but not with some third party daughterboards; fears about 3.1.4 happens here; the line of the graph sinks terribly!
    after a couple of days i receive an info that a CF formatted under 3.9 is not seen by my tool that mounts DOS partitions; formatted on my card, the CF is not seen as DOS device on the internal IDE port of the A4000! Anyway, the line of the graph, rises positively...
    after that, just short comunications that 'more test are needed'; the line of the graph stop his job...'comunication interrupted'.
    I have requested the return of my card and possibly, with an old and not working A3640, to check my card into my Amiga with a 040 cpu. So, if you wish to donate an old A3640, without cpu, in not working state; and/or a 2000 motherboard (about revision 6), withou any socketed IC except the two CIAA and CIAB, i will be wery grateful!
    Chers
    stefano
  1. Amiga OS 3.9 ad RAM Autoconfig
    By Violo in forum AmiOracle
    Last Post: 5th January 2016, 15:43
  2. Sold A2000/A500 8 MB RAM non-autoconfig
    By bdb in forum Sales Archive
    Last Post: 14th November 2013, 21:59
Tags for this Thread
