Results 1 to 9 of 9
Thread: Replacing PSU fan A4000
  1. #1
    tekk's Avatar
    May 2014
    The Netherlands
    Groningen
    4 (100%)
    Default Replacing PSU fan A4000
    Hiya,
    Does anyone know a good tutorial on replacing the A4000 PSU Fan?
    What are the needed dimensions anyway? How big is it. It's so noisy...already heard that the airflow/pressure output is important because of the design of the case.
    Thanks.
  2. #2
    Half-Saint's Avatar
    Sep 2013
    Slovenia
    Idrija
    Age
    42
    161 (100%)
    That should be straightforward. The fan is probably 80x80 mm. You can quickly confirm that by opening up the power supply and measuring it yourself. You can also check, if the cable is soldered directly to the PCB or not, at the same time.
    My main rig is a 386DX-40
  3. #3
    Sage's Avatar
    Jan 2019
    Norge
    Vestlandet
    0
    Yes, it's an 80mm fan. 12V. Can't remember if it's soldered directly to the PCB but I think so.
  4. #4
    tekk's Avatar
    May 2014
    The Netherlands
    Groningen
    4 (100%)
    Thanks. I'll check it.
    What about the Noctua fan? Seen here (https://youtu.be/2HJCK2SexSE?t=383) in an A2000 PSU fan replacement by Jan Beta. He has the Noctua NF-A8 ULN edition. It's a series of three where the ULN edition is the quietest.
    ULN: 10.4dB - 1400 rpm
    FLX: 16.1 dB - 2000 rpm
    PWM: 17.7 dB - 2200 rpm
    https://noctua.at/en/products/fan
  5. #5
    Half-Saint's Avatar
    Sep 2013
    Slovenia
    Idrija
    Age
    42
    161 (100%)
    I would get the FLX because of a much larger airflow. Sure it's not as quiet as ULN but it will still be much quieter than your stock fan.
  6. #6
    tekk's Avatar
    May 2014
    The Netherlands
    Groningen
    4 (100%)
    Yes, that's what I did. Thanks for confirming that
  7. #7
    Amibayer! Skyrunner's Avatar
    Mar 2010
    37 (100%)
    Here's what I did with an Acid Blaster which is more or less silent.
ID:	146780 Click image for larger version.
ID:	146781 Click image for larger version.
ID:	146782 Click image for larger version.
ID:	146783 Click image for larger version.
  8. #8
    tekk's Avatar
    May 2014
    The Netherlands
    Groningen
    4 (100%)
    Nice, thanks for sharing The fan will be in tomorrow.
  9. #9
    Amibayer! bebek's Avatar
    Apr 2010
    Poole, UK
    Dorset
    Age
    43
    260 (100%)
    If you want it quiet cut out the original mesh and fit wire mesh - much better airflow and noise is significantly cut down.
  1. Replacing a A3000 powersupply
    By Arananet in forum Photo Booth
    Last Post: 20th March 2017, 06:40
  2. Replacing the fan in an A4000 PSU - Airflow ?
    By Amon_RA in forum AmiOracle
    Last Post: 13th January 2016, 17:03
  3. Replies: 9
    Last Post: 22nd October 2009, 00:17
Tags for this Thread
