Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: 8501 replacement for C16 Plus4: work in progress...
  1. #11
    MCes's Avatar
    Sep 2013
    Italy
    Rome
    38 (98%)
    I found a demo that use the krill's loader and illegal opcodes,
    the illegal opcode can't be compatible,
    but I want to try to make my project compatible with krill loader....
  2. #12
    MCes's Avatar
    Sep 2013
    Italy
    Rome
    38 (98%)
    Now I have in my hand the jiffydos for PAL, and it work with my project.
    A "krill's loader" programmer was so kindle to make a little modify to eliminate 1 illegal opcode (ONE!!!)
    and to give me a version of V166 demo with no illegal opcodes: it work!
    Now I can suppose that CPLD design (that perform also the I/O port emulation) has no problem:
    the only limit knowed (and not superable) is the not possibility to execute the illegal opcodes.
    I just have to test it again with the new PCB I got and make it (finally) available.
  3. #13
    MCes's Avatar
    Sep 2013
    Italy
    Rome
    38 (98%)
    ok,
    now I have to prepare the announcement for the sale, the price of my 85MC01 will be:
    29€+untracked shipping cost: PPal "FOR FRIENDS" (I can't be responsible for untracked shipping)
    29€+tracked shipping cost + PPal fees: PPal "COMMERCIAL"
  4. #14
    Inactive Member bmamo's Avatar
    Oct 2018
    Malta
    Xghajra
    1 (100%)
    So I am in need of a CPU for my c16, and found your thread here. What exactly are you selling? PCB only or full package?
  5. #15
    MCes's Avatar
    Sep 2013
    Italy
    Rome
    38 (98%)
  6. #16
    MCes's Avatar
    Sep 2013
    Italy
    Rome
    38 (98%)
    Some people want that own CPU could manage the illegal opcode for the best compatibility....
    OK!
    from the "85MC01" experience...... the "CPU4C16"!
    a CPU replacement (specific for the C16 shape) that use a selected 6502 N-MOS core: it manage the illegal opcodes
    Features:
    A) normal sw N-MOS 6502 behaviour (as 8501, illegal opcode included)
    B) The I/O bits are at right places: the self-turbo routines (loaders) will work
    C) R/W line is put on 3state and HOLD as 8501 timings spec
    D) TBC (Time Base Corrector) technique applied to help the CPU, also into the "worst case", for matching the correct bus timings
    E) each 6502 that I use on it are selected for 2 specs: 1) it has to be an N-Mos, 2) it has to match to the specifics timings (more than 2MHz)
    Remember that N-MOS 6502 chips are discontinued, often on market the sold chips are refurbished and relabelled with a label different to the old one:
    chips marked as "6502" may not be N-Mos as it have to be, and vice versa (C-MOS, so no execution of the illegal opcode).
    I found a chip labelled as "W65C02S" (10MHz C-MOS) that is a 1MHz N-MOS!!!!!
    http://www.amibay.com/showthread.php...-C16-(CPU4C16)
    My personal C16:
    https://plus4world.powweb.com/forum/38827?fbclid=IwAR0_CVyOO4KjHJRIpl89QJsIw7c-uujlfePKxoI6PXv7ehp2pC7tgC41Le8
  7. #17
    MCes's Avatar
    Sep 2013
    Italy
    Rome
    38 (98%)
    Why a CPU4C16 and not a CPU4PLUS4?
    It's arriving!
    CPU4PLUS4
    http://www.amibay.com/showthread.php...S4-(CPU4PLUS4)
  8. #18
    SukkoPera's Avatar
    Nov 2017
    Italy
    Turin
    40
    53 (100%)
    (Please delete)
  1. Wanted C16 / Plus4 8501 CPU
    By SunDown79 in forum Commodore
    Last Post: 26th April 2015, 00:17
  2. Closed C16 / C116 / Plus4 CPU 7501 or 8501
    By alke01 in forum Found Archive
    Last Post: 16th August 2012, 07:30
  3. Work In Progress LED A1200
    By Witcher1979 in forum Photo Booth
    Last Post: 8th September 2010, 17:28
