For Sale lost stuff from the 90's and early 00's
Roman78
Germany
NRW
I am doing a clean-up. I just collected too much stuff now collecting dust. I want to focus more on the 80's computers, so some of the 90's and 00's has to go. I'll ship worldwide from Germany. Prices are basis for negotiation, on some hardware i just dont have any clues. I did note made Pictures yet, but if someone needs some, i am happy to make some. I also test the hardware before shipping. So lets start...
PowerMac 6100 Logicboard € 30,-
PowerMac 6100 PSU €25,-
PowerMac 6100 MAXpowr G3 - 266 Mhz https://everymac.com/upgrade_cards/newertech/maxpowr_g3_nubus/maxpowr_g3_nubus_266.html €100,-
PowerMac 6100 DOS Card (i have two, but only one breakout cable) Thought they were 486 66Mhz €75,- for both. -sold-
And a whole 6100 including HDI45-DB15 cable. Someone sawed a piece out near the CD-Rom drive €75,-
PowerMac 7300 Logicboard €25,-
PowerMac 7300 PSU €25,-
And a whole PowerMac 7300/166 €50,-
A 133 MHz CPU € 20,-
Apple LC475 (don't know the specs, and maybe i'll do a recap if wished) € 75,- Sold
CPU Upgrade for the Macintosh LC (I was unable to google this card, i don't know the exact type, but it has 50Mhz) €50,- -Sold-
MaxPower G4 7447A Dual G4-1600 for the G4 AGP up to the Quicksilver. There are actually 1420Mhz CPU's on that card, but they sold it as 1600Mhz, even in the Manual only a 1.6 up to 2.4 GHz settings are mentioned. €100,
- -Sold-
https://www.newertech.com/products/maxpower47.php
https://www.newertech.com/products/compare_maxpower47.php
Manual:
https://www.newertech.com/downloads/nwtmang4max.pdf
I have a some G3 and a lot G4 stuff up to the Quicksilver, a Dual G4 450 mhz. Some default graphic cards and CPU'S. Also have lots of older RAM, PCI graphic cards, PCI SCSI Cards and cache modules for the older systems.
And something new...
MacMini 2009 Core2Duo 2.0 Ghz. Default configuration (2GB and 120GB HDD) €125,- 8gb instead of 2gb + 40€ and if wished i can add a SSD.
https://everymac.com/systems/apple/...i-core-2-duo-2.0-early-2009-nvidia-specs.html
iMac 2011 20.5" i5 2500S 3.1 Ghz, 12GB RAM and 240GB SSD €360,- Sold
https://everymac.com/systems/apple/imac/specs/imac-core-i5-2.7-21-inch-aluminum-mid-2011-thunderbolt-specs.html
And some parts from a MacPro 3.1, like Logicboard, CPU, Cooler, PSU
Oh and i have a AVID Blue Ice Video card with Dongle, also could not find any specs of this card... but it looks cool... Picture is stolen from another side.
/edit: Got here a PowerBook 520 including a nice Apple Bag. OS is dutch, PSU is making some noise, maybe a Capacitor. €75,-
Bildschirmfoto 2019-09-13 um 19.06.53.jpgBildschirmfoto 2019-09-13 um 19.07.02.jpgBildschirmfoto 2019-09-13 um 19.07.11.jpg
And some bigger stuff, but hard to ship.
A Cube G4 including 17" Studio Display, keyboard and Mouse. € 250,-
Apple Macinstosh IIcx including Hi-Res monitor and Apple Scanner €250,- (don't hd the space to set it al up, but i can make some more pictures if wanted)
Hi !
Could you please be more specific about the others items (graphic cards, CPU'S, older RAM, PCI graphic cards, PCI SCSI Cards and cache modules for the older systems) ?
Yes, off course. I'm going to make a list tonight at home. Do you looking for something special?
Hereby some pictures of the PowerMac6100 Dos cards and the G3 for the PowerMac6100. I just looked at the connectors and they are different indeed, so you cant use both at the same time.
And now i am making a list of my other hardware...
/edit... and hereby a list of most of my cards. Some are still in some computer, i did not opened all yet.
Graphic cards PCI
ATI Radeon 7000 Mac32M Sold
ATI Rage 128
Twin Turbo 128M/M2
Twin Turbo 128M8
Villa Tronic 16 MB PCI Sold
Graphic cards AGP
ATI Radeon R6 32MB
ATI R128P (3x)
Nvidia GeForce 4 32MB
SCSI PCI
Advance 2911 U (2x)
Adapted 2990CU MAC (2x)
Memory:
4x4 MB 64pins (think from a IIfx) Sold
4 other 64pins modules (think from the same IIfx)
Sold
Lots of 72 Pins modules
And even moor 168 Pins modules from 8 to 64 MB each 5V/3.3V buffered and unbuffered
Most modules i can check on the hardware i own.
Cache modules:
Apple 820-0672-A 256K (Google sais Powermac 5200 6200 8200)
Apple 820-0719-B 256K (Google sais PowerMac 8500)
Apple 820-0719-C 256K (Google sais PowerMac 8500)
Video Memory
Apple AP2761-04 2MB (Google sais PowerMac 4400/200 and Starmax 3000)
4 x 1 MB Apple PowerMac 112-Pin VRAM Module (2 different types)
Hi, declaring interest in the mac lc 50MHz cpu upgrade. Is it possible to have a photo of the card ? What are the capacity of the biggest 72 pin memory modules ? Thanks in advance.
I'm making some pictures tonight. The biggest 72Pins are 32 Meg. Maybe i have some 64 Meg, ill have to test first.
So this is the card. It is an Extreme Systems Impact 030 with 50 Mhz FPU.
Driver are here: https://vintageapple.org/macdrivers/accel.shtml or https://www.macintoshrepository.org/7740-accelerator-card-drivers
I read here: https://68kmla.org/forums/index.php?/topic/28355-extreme-systems-impact-acclerator-card-for-lc/ that the card also should work in Color Classic hmmmm But could not find any other information about the card.
/edit: Just tested some of my 72-pins memory. I have some pairs of 4, 8, 16 and 32 Meg each, and a lot of 8 meg single modules. But i'm not finished yet. Also found 2 68-Pins modules. According to google, this are VRAM for the LC.
Somehow the picture does not work, well here is a new one.... this is the LC Card.
And here are some pictures of the Dual G4.
This is the original Cooler, but the previous owner somehow cut it into two and connected the upper part to the to the other end. I replaced the fan whit a low Profile fan, because i used it in a Quicksilver and the normal 25mm Fan reaches the PSU so the cooling was not optimal.
Just tested the CPU in my QS using Xbench. I think xbecnh only uses one CPU. The first picture is with the Dual 1.6 and the second with the default 867Mhz.
Declaring interest in Mac IIfx ram stick if they really are 4MB.
How much for shipping to Laris (France)?
Envoyé de mon iPhone en utilisant Tapatalk
Payment sent for the LC CPU accelerator and two 32MB 72pins memory sticks.
Payment received and ready to ship tomorrow.
4 of them are label as 4MB Module, so i think they are 4mb each. The other 4 don't have a label, i thin those are 1mb each.
