Results 1 to 10 of 10
Thread: Storage options: Tidying up my collection (without Marie Kondo)
  1. #1
    bkodenkt's Avatar
    Dec 2017
    Deutschland
    Bremen
    13 (100%)
    Default Storage options: Tidying up my collection (without Marie Kondo)
    I recently decided to give my smaller Amiga's a better chance of survival in storage, so I started researching my options since I have long lost the original boxes. And, to be honest, those original boxes are way to clunky to carry your 'miggy around. So... I found a case for measuring instruments that sported layers of block-foam. Those layers can be cut with a simple knife to fit right about every device you want to put into the case. For 30 Euro per case I gave it a try with my furia'ed A600:
    Yeah, well. It fits, right along with mouse, one Competition Pro Joystick, RGB-to-SCART-cable and some PCMCIA cards. Tight and sturdy enough to carry the June Bug to conventions once or twice a year. And a great option to safely put the Amiga onto a storage shelf. But what about the PSU and all the other gadgets like card reader, second Joystick, 4-player-adaptors and SCART-to-HDMI adaptor?
    Easy! I opted for another case, this one smaller in width and length, but higher to accomodate the PSU. And while I was at it, I bought a third case for my A500's accessories like the AlfaPower 500, PSU, cabling, another SCARt-to-HDMI adaptor and A520 TV-modulator. Well, there goes my money... But, as you can see, it all fits quite snug. So for my A600 and the A500 each I now have two cases to carry. The cases are well stackable for easy storage.
    Okay, I already mentioned the A500. It's a rev5, Kick 1.2 system with 1MB Chip-RAM mod and 6MB Fast-RAM via the AlfaPower 500... So, here it is, case number four:
    As you can see, this is very tight fit with the same case size I used for my A600. But, again, very well stackable and a good option for storage or safe travel.
    At last I felt "the need" to safely store my CD32 including its Kipper2k riser card and the TF330, one original joypad, asmall PS/2 keyboard and a new, small PSU.
    Again, this ist the same size case I already used for my A500 and the A600. Fits perfectly!
    So, this is the whole lot of my small Amiga storage solution:
ID:	147098Click image for larger version.
    Five cases, two different sizes, three Amiga's and all accessories safely stored. Overall cost about 140 Euro. I am very pleased with this solution, but I am absolutely clueless about storing my A2000
    And yes, Ms. Kondo, this does make me happy.
    What do you guys think?
  2. #2
    Math inside Amibayer! BLTCON0's Avatar
    May 2011
    Hellas (Greece)
    Chania, Crete
    Age
    43
    104 (100%)
    Nice concept
    I especially like the frankestein US-DE layout of the A500 keyboard
  3. #3
    bkodenkt's Avatar
    Dec 2017
    Deutschland
    Bremen
    13 (100%)
    You have very sharp vision
  4. #4
    gebes's Avatar
    Nov 2013
    United Kingdon
    Edinburgh
    3 (100%)
    Could you please link to the type of cases you got ? Thank you
  5. #5
    bkodenkt's Avatar
    Dec 2017
    Deutschland
    Bremen
    13 (100%)
    Sure! It's both a rather cheap brand, in Germany they are called PeakTech. I guess it's some generic china brand, though, that does have different names in different countries.
    The smaller one for accessories is: https://www.reichelt.de/koffer-premi...?&trstct=pol_0
    The bigger one for the Amigas is: https://www.reichelt.de/koffer-fuer-...?&trstct=pol_1
  6. #6
    Amibayer! demolition's Avatar
    Oct 2012
    Denmark
    Copenhagen
    Age
    39
    66 (100%)
    Looks nice and tidy, however I would worry that some chemical in the foam might impact the plastic cases. Perhaps the color will rub off or fumes may cause some other impact. I have seen many examples of stuff being tucked away in a box where they have become damaged in this manner. The insulation on cables often 'melts' plastic where it touches and the same is seen with rubber bands, so I would avoid any kind of rubber-to-plastic contact. I have even seen examples of styrofoam 'rubbing off' on stuff it had been in contact with.
    A1200 (NOS) : 030 33MHz 128MB fast RAM (ACA1232) : Indivision AGA MkII : 8GB CF : RR USB : Ethernet
    A600 #1 : 080 V2 : 128MB fast : 2MB chip : Indivision ECS : 32GB CF : RR USB
    : Ethernet | A600 #2 : 010 : 2MB chip
    A500 : 68000 42MHz : 1MB chip : 8MB fast : 4GB CF | A500+ : 080 V2+ : 128MB fast : 2MB chip : 32GB CF
  7. #7
    bkodenkt's Avatar
    Dec 2017
    Deutschland
    Bremen
    13 (100%)
    That's a good hint, @demolition! I will have that in mind, but I regularly check my Amigas anyway - as in taking them out to play with them
  8. #8
    quantum8's Avatar
    Jan 2019
    QLD
    2 (100%)
    Great setup there!
    I should probably get around to doing the same to my CD32
  9. #9
    Forza GVP NoPyroNoParty's Avatar
    Dec 2015
    Finland
    Helsinki
    106 (100%)
    I was toying with the same idea a couple of days ago and good to see how it actually works. What dimensions your cases are?
  10. #10
    SolidCore's Avatar
    Jul 2017
    united kingdom
    west midlands
    11 (100%)
    Jealous of those padded cases, how much do they set you back and how easy is it to replace the foam if you made a mistake or want to adjust things?
    Kipper2K dual/quad kickstart rom boards
    Kipper2K MX Keyboard
    Kipper2k A1208 SD, Ethernet 8mb fastmem
  1. Replies: 17
    Last Post: 11th August 2014, 10:27
  2. Closed Ultima collection rare origin pc game collection
    By Pulu in forum Other
    Last Post: 7th August 2013, 17:23
  3. Commodore 64 Web.It - CF Options
    By Skilgannon in forum AmiOracle
    Last Post: 10th April 2013, 16:14
Tags for this Thread
