Swap all the items below for an all in one keyboard with built in sequencing or ipad support so i can learn to play properly
I can supply new sealed midi cables, usb cables and a roland (pc to serial cable) so you can use softmp401 in dos/win9x with the sound canvas for monkey island etc.
Roland ua-100 with AC adaptor
The UA-100 (Audio Canvas) is a audio and MIDI processing unit with a USB interface. It has 20-bit A/D-D/A converters for audio playback and recording using a PC, as well as a 2 input / 2 output MIDI interface. It also has a built-in 24 bit (internal) DSP multi-effect that can be used for recording or playback.
https://www.roland.com/global/products/ua-100/
Roland A-500Pro (I think with AC adaptor, I will check, but can be USB powered ) ( found generic PSU tested working )
A-500PRO 49 key MIDI Keyboard Controller,
Velocity-sensitive 49 keys with channel aftertouchInspiring feel and response for serious players
45 assignable controls: knobs, sliders, buttons, transport and more
8 Dynamic Pads for finger drumming and MIDI triggering
Sure-grip Pitch Bend/Modulation Stick
Expand playability with sustain and expression pedals (available separately)
USB Bus Powered — no AC adaptor required (AC adaptor is an optional)
Durable Roland-quality manufacturing and craftsmanship
Works with any DAW on Mac or PC
https://www.roland.com/global/products/a-500pro/
Roland Sound Canvas SC-88VL, with AC adapter
Sound Canvas SC-88
(General MIDI System GM / GS Compatible)
NUMBER OF PARTS
32
MAXIMUM POLYPHONY
64 Voices
INTERNAL MEMORY
Sound Map: 2 (SC-55, SC-88 )
Preset Sounds: 654
Drum Sound Set: 24 (including 2 SFX sets)
User Sounds: 256
User Drum Sound Set: 2
EFFECTS
Reverb (8 types)
Chorus (8 types)
Delay (10 types)
2-Band Equalizer
DISPLAY
70.6 x 24.5mm Backlit LCD
CONNECTORS
MIDI connectors (IN A, IN B Front/Rear, OUT/THRU)
Audio Input jack x 2 (L,R)
Input Volume knob
Audio Output jack x 2 (L,R)
Headphones jack
Computer terminal
Computer switch
https://www.boss.info/uk/support/knowledge_base/201965679/
http://cdn.roland.com/assets/media/...748.10949657.1559688728-1030753481.1559688728
Sound Canvas SC-88
NUMBER OF PARTS
32
MAXIMUM POLYPHONY
64 Voices
INTERNAL MEMORY
Preset Sounds: 654
User Sounds: 256
EFFECTS
Reverb (8 types)
Chorus (8 types)
Delay (10 types)
2-Band Equalizer
DISPLAY
CONNECTORS
Input Volume knob
Headphones jack
Computer terminal
Computer switch
