Results 1 to 10 of 10
Thread: C64 Case Saver Repair Kit
  1. #1
    Jeff_Birt's Avatar
    Nov 2017
    USA
    Rolla, MO
    0
    Default C64 Case Saver Repair Kit
    Hopefully, this is OK here. I'm not a 'commercial' Commodore vendor but do offer a few things through my website that are Commodore related. The forum rules were a bit opaque on exactly what constituted a commercial vendor or what to do if you were not when you joined but might be considered so now.
    After a great deal of trial and error, I came up with a ‘C64 Case Saver’ kit. The kit includes repair parts for the screw posts, PCB standoffs and the three rear tabs on the top case. The post sleeves and PCB standoffs are CNC machined out of natural ABS. The three rear tabs for the top case may be CNC machined or 3D printed. I 3D print these in such a way that the strength lies along the length of the tab, so the business end won’t snap off.
    The screw post repair sleeves are castellated, so they slip right down over the top of the posts. Some posts might be ‘mushroomed’ (smashed a little on top) and require a bit of sanding. The PCB standoffs have a wide base for plenty of gluing area but are narrower at the top so they will fit the holes in the PCB bottom metal shield. The top case rear tabs are designed to self-align to make gluing easier.
    Along the way, I have discovered there are at least 4 different types of tabs used on the rear of the top case. Type 1A tabs are flat with two wide tabs and one narrow tab. Type 1B tabs are flat and all three are wide. Type 2A tabs have a recess with one narrow and two wide tabs. Type 2B cases have slightly larger 7mm (?) screw posts and different tabs. I do not have this case type on hand to measure and make repair parts for. If you are in the USA and have this case type contact me!
    Also included is a good quality #39 drill bit which not only aids in aligning the PCB standoffs but is the correct size to drill out the crew holes in the screw mounting posts is you should need to fill one with epoxy to repair damaged threads!
    Look carefully at the pictures on this page to make sure you are ordering the correct kit for your case. I just added a lower cost method for international shipping. It is about 1/2 the cost for small/light items but is NOT insured.
    Product page: https://www.soigeneris.com/commodore...ver-repair-kit
    Installation video: https://youtu.be/TOX1zKe6ItA
  2. #2
    BobbinThreadbare's Avatar
    Jan 2019
    United Kingdom
    Berkshire
    43
    10 (100%)
    Is there any good way for me to determine the case type(s) I have? Or would you be willing to sell a kit wit the normal amount of post sleeves and PCB standoffs but with rear tabs for all 3 case types? (for somewhat less than the $38.85 the 3 separate kits would cost)
  3. #3
    Jeff_Birt's Avatar
    Nov 2017
    USA
    Rolla, MO
    0
    Take a look at pictures on the product page and the YouTube video. I tried to go into great depth so you can tell what case you have. The only question at this point is the difference between Type 2A and 2B. These are the tabs with recesses. In the Type-2A, the ribs were added to the flat tab so you have a 2mm or so flat tab with 1mm ribs (just round numbers off the top of my head), in the Type-2B the center of the flat tab was removed, so the center is the same thickness as the wall thickness of the back of the case and the hook is more like a hoop.
    If you want to send me some pictures of that you have I'll help you identify the case.
  4. #4
    Jan 2019
    United Kingdom
    Berkshire
    43
    10 (100%)
    After just taking a second look I realised I was 'reading' the pictures wrong the first time I checked. I thought you were showing images of the cases with the replacement parts in place but that's the cases as they originally were and none of mine match. My bread bins only have 2 small hooks in each location (6 total) without any material to bridge between them. I'll upload pictures when I get a chance. Looking at how sturdy the other versions are in comparison I'm struggling to see how you break them!
  5. #5
    Jeff_Birt's Avatar
    Nov 2017
    USA
    Rolla, MO
    0
    @BobbonThreadbare it sounds like
    you might have the elusive 2B type rear tabs. I had someone in Canada contact me with a VIC20 with this type of tabs. He just sent some great pictures last night. I've attached one there to confirm it is the same type you have. I have seen al four types of tabs break though the 2A seems to be the most robust.
    Also, thanks for stating what about the photos was confusing. I'll rework the captions to make it more clear those are the original intact tabs and I'll add pictures of repaired tabs too.
Name:	Type 2B tabs.jpg
  6. #6
    Jeff_Birt's Avatar
    Nov 2017
    USA
    Rolla, MO
    0
    I did find that I had a VIC20 cse with the type '2B' tabs (hook style three wide tabs). The fellow in Canada has what I'm calling a Type 2C case as it has hooked tabs but two wide and one narrow. To make things more interesting the 'wide' tabs on the two case styles are different widths as well.
    I made some replacement tabs for both style cases this weekend. I've test fit the replacement on my Type 2B and it fits and the fellow in Canada will try the 2C reapir set on his VIC20. If all goes well I'll have a replacement kit both cases in a few weeks.
    Still working on the 64C kit...
  7. #7
    Jeff_Birt's Avatar
    Nov 2017
    USA
    Rolla, MO
    0
    Update on C64, VIC20, and 64C Case Saver Kits
    In this video, we covered a few new case saver types for the Commodore VIC20, C64, and 64C computers. I hope this will allow folks to repair their vintage cases and keep using them and enjoying them for decades to come.
    In the description below are links to the original installation video and the Case Saver product page. Look for the new repair kits to be added very soon. If you would like I can make it possible to pre-order them. Just let me know.
    https://youtu.be/07h_9CUrbJs
  8. #8
    Mbosschaart's Avatar
    Mar 2018
    Netherlands
    Europe
    45
    3 (100%)
    Hi Jeff, just received an order of two kits and they are great. Fixed three cases with them. Now is it also possible to just order just the tabs, instead of a full kit that also has the standoffs in it? Most of the cases that go through my hand only have damaged tabs, are of the fragile type 2A/B and almost none have broken standoffs. I'd be happy with an order of 10 sets of type 2B and nothing else.
  9. #9
    Jeff_Birt's Avatar
    Nov 2017
    USA
    Rolla, MO
    0
    I'll look at that. Having 10 sets of tabs of each type in a seperate kit might be doable. Maye call that a 'bulk' pack or something like that.
  10. #10
    Jeff_Birt's Avatar
    Nov 2017
    USA
    Rolla, MO
    0
    @Mbosschaart your wish is my command...bulk paks of top case rear tabs are now available. These contain 10 sets of 3 tabs of ONE case type. (30 pieces total.)
    https://www.soigeneris.com/commodore...-tabs-bulk-pak
  1. For Sale C64 SAVER
    By TREXoldcomputer in forum Commodore
    Last Post: 16th September 2019, 12:33
  2. C64 Case Clip repair
    By balford in forum Photo Booth
    Last Post: 9th July 2016, 18:23
  3. Case front bezel repair
    By ajk in forum Photo Booth
    Last Post: 18th December 2010, 21:08
  4. A4K case repair
    By Justin in forum Photo Booth
    Last Post: 2nd March 2010, 21:34
