Hey all,
I found an Amiga 2000HD I was trying to get working. I've only ever had a black screen output from it. I tried swapping all the socketed chips with the ones in my A500 and all of the chips worked in the 500 but inserted in the 2000 would make no difference.
I just got a diagrom chip and during the first boot, it boots up fine but will hang soon after (Sometimes with a "Division by zero" error). Every attempt to boot after will result in scrambled output.
If I wait a while and try again, the whole process will repeat over. The machine won't stay up long enough to run any tests. Any ideas!? I'll include the output in case it gives any hints.
Thanks!
-Keith
@▒▒▒U
Garbage before this text was binary numbers: 1, 2, 4, 8, 16, 32, 64, 128, 240, 15, 170 and 85
To help you find biterrors to paula. Now starting normal startuptext etc
Amiga DiagROM V1.1 - 27-Oct-18 - By John (Chucky/The Gang) Hertell
Testing if serial loopbackadapter is installed: <> NOT DETECTED
- Parallel Code $ff - Start of ROM, CPU Seems somewhat alive
Checking status of mousebuttons for different startups:
Set all Interrupt enablebits (INTENA $dff09a) to Disabled: Done
Set all Interrupt requestbits (INTREQ $dff09c) to Disabled: Done
Set all DMA enablebits (DMACON $dff096) to Disabled: Done
Testing if OVL is working: OK
- Parallel Code $fe - Test UDS/LDS line
- Test of writing word $FFFF to $400 OK
- Test of writing word $00FF to $400 OK
- Test of writing word $FF00 to $400 OK
- Test of writing word $0000 to $400 OK
- Test of writing byte (even) $ff to $400 OK
- Test of writing byte (odd) $ff to $401 OK
- Parallel Code $fd - Start of chipmemdetection
Addr $00100400 OK Number of 32K blocks found: $20
Chipmem Shadowram detected, guess there is no more chipmem, stopping here
Startaddr: $00000400 Endaddr: $00100000
Using $000ECD00 as start of workmem (Base)
- Parallel Code $fa - Starting to use detected memory
Detecting if we have a working raster: DETECTED
Detected Chipmem: 1024kB
Detected Motherboard Fastmem: 4294967232kB
Basememory address: $000ECD00
- Parallel Code $f9 - Detected memory in use, we now have a stack etc
Set Start of copper (COP1LCH $dff080): Done
Starting Copper (COPJMP1 $dff088): Done
Set all DMA enablebits (DMACON $dff096) to Enabled: Done
Set Beam Conter control register to 32 (PAL) (BEAMCON0 $dff1dc): Done
Set POTGO to all OUTPUT ($FF00) (POTGO $dff034): Done
- Parallel Code $f8 - Starting up screen, text echoed to serialport
Doing ROM Checksumtest: (64K blocks, Green OK, Red Failed)
$6946ACF4 $B526F1B8 $E967DADB $00000000 $00000000 $00000000 $00000000 $006C0070
CPU: 68000 FPU: NONE MMU: NOT CHECKED
Doing some fastmem detection skipped at start as chip was found
Pressing left mousebutton will cancel detection (if hanged)
Checking if a 24 Bit address cpu is used: YES
- Checking for Memory in 24 Bit area (NON AUTOCONFIG)
- Checking for Memory in Ranger or Fakefast area
IF This ROM is sold, if above 10eur+hardware cost 25% MUST be donated to
an LEGITIMATE charity of some kind, like curing cancer for example...
If you paid more than 10Eur + Hardware + Shipping, please ask what charity you
have supported!!! This software is fully open source and free to use.
Go to www.diagrom.com or http://github.com/ChuckyGang/DiagROM for information
To use serial communication please hold down ANY key now
OR click the RIGHT mousebutton.
Holding down the LEFT mousebutton will force serial on and turn off screen
forcing stuff to run in fastmem if avaible
By John (Chucky / The Gang) Hertell
MAIN MENU
0 - Systeminfo
1 - Audiotests
2 - Memorytests
3 - IRQ/CIA Tests
4 - Graphictests
5 - Porttests
6 - Drivetests
7 - Keyboardtests
8 - Other tests
Serial: 9600 BPS - S - Setup0 - Chip: 1024kB - kBFast: 0 Base: $000ECD00
Information of this machine:
Dump of all readable Custom Chipset HW Registers:
BLTDDAT ($dff000): $FFFF DMACONR ($dff002): $6380 VPOSR ($dff004): $3000
VHPOSR ($dff006): $E523 DSKDATR ($dff008): $FFFF JOY0DAT ($dff00a): $1000
POT0DAT ($dff012): $0000 POT1DAT ($dff014): $0000 POTINP ($dff016): $5500
SERDATR ($dff018): $0800 DSKBYTR ($dff01a): $9000 INTENAR ($dff01c): $0000
INTREQR ($dff01e): $0028 DENISEID ($dff07c): $FFFF HHPOSR ($dff1dc): $00CC
Chipmem starts at: $FFFFFFFF and Ends at: $000FFBFF Unused chip: 969989 Bytes
Is $1114 readable at addr $0 (ROM still at $0): NO
Is $1114 readable at addr $f80000 (Real ROM addr): YES
Is $1111 readable at addr $f00000 (expansion ROM addr): NO
Stuck buttons & keys etc at boot:
Serial: 9600 BPS - CPU: 68000 - Chip: 1024kB - kBFast: 0 Base: $000ECD00
MAIN MENU
0 - Systeminfo
1 - Audiotests
2 - Memorytests
3 - IRQ/CIA Tests
4 - Graphictests
5 - Porttests
6 - Drivetests
7 - Keyboardtests
8 - Other tests
VHPOSR ($dff006): $1031 DSKDATR ($dff008): $FFFF JOY0DAT ($dff00a): $1000
SERDATR ($dff018): $0B0D DSKBYTR ($dff01a): $9000 INTENAR ($dff01c): $0000
INTREQR ($dff01e): $0028 DENISEID ($dff07c): $FFFF HHPOSR ($dff1dc): $FFD8
MAIN MENU
0 - Systeminfo
1 - Audiotests
2 - Memorytests
3 - IRQ/CIA Tests
4 - Graphictests
5 - Porttests
6 - Drivetests
7 - Keyboardtests
8 - Other tests
Memorytests
1 - Test detected chipmem
2 - Extended chipmemtest
3 - Test detected fastmem
4 - Fast scan of 16MB fastmem-areas
5 - Slow scan of 16MB fastmem-areas
6 - Complete Memorydetection
7 - Manual memorytest
8 - Manual memoryedit
9 - Autoconfig - Automatic
Serial: 9600 BPS - 0 - MainmenuNTAL New Manual Memorytest Base: $000ECD00
Checking detected chipme @▒▒▒U
Gbgboeh e a nynbr ,,,1 ,6 2 0 510n8@▒U
oepofnbto oaa wtrn oa ttpxec
ei feilobcdprsitld>N TCD-Pae d$f atfR,P essea i
hcnsasfmsutsfdfrttrp
Stl trpebet(NN d0)tDse o
tl trprqebt(TE$f9 ibeDn
ea Meali DCNd06tDsl
ei fVi ri:O
-aal d e-e DL i
so in r$F o4
so in r 0 o4
Ttowtnbe(e)ft 0O so iiwd$0t 0O
etfwtgbeod$ o41K-aaeCd$d atfhpmtco
hmmSdwadtt,gste ooehmmspi rd 000dr00
ttd:040Ead 10
sn$C0ssro rm ae
Prl o a-ttnt eeet er
Ttgisilopcdprsitld <>ODTT
Dei feavD
eceC
l ufdieo oaa wsrn oa auttt aaeer i xwsbayues12 63,4182,1 0a 5
maDR 1 2-t8 B o CuyT n)eel
Tsn ra obkat nae: ODTCD-Pae d$f ttfR,P e owa i
ekgsasfmsbtsf fensaus
S lD nbbt(AO$f9 ibeDndoe ea nrp qsbs(NE$f9) sbdDn
eigfO oi:K-aal o e-e DL i
so in r F o4
Ttowtnwd$0 0O so iiwd$Ft 0O
Ttowtnbten fo$0O
hm hoa tc,ustr o hpm tpnhe e ri y d)f $1K-aleCdf-Sro iedeto
Srdr$00 dd:00
ig$C0ssro rmmBe
Prl o a-ttnt sdet er
Dei feavD
eceC ▒U
Grae eoetistx a baynmbr:1 , ,8 6, 2 4 18 4,15 7 nd8
T el o id ierrst al. o trtignmg iaRMV.1 7Ot-8 yJon(hck/h ag)Hrel
aale oe$ff-Sat fRM PUSessoehtaivED
hcig ttsof osbttn o ifeetstrus
e ll nerptealbts(NEA df9)toDsbene e l ntrutreqetis ITE df9)t Dsben
SetalDA nbeis DAO $f06 o iald oe
etn i V s okn:O
aale oe$e Ts DSLSln
-Teto rtigwr $FF o$40O
-Teto rtigwr 00 o$00
-Tst fwiin od$F0 o$00
-Ts o rtngwr 000t 40O
etofwiig bt een f o$40OK - eto wrtn yt od fft 41O
-PaallCoe$d-Str fcipedtcto
hpemSaorm eetd,gester sn orcimm,sopn hr4Adr$0840dr$040
aale oe $a-Sarigt sedtcedmmr Satar 0040 nadr 0000
Tstn fseillobakdper sisale: <> O ETCE
abaebfre hstxtwsbnrynmes:1 ,4 8 6 2 6,18 20 5 70ad8U
Amg igOMV. 7-c-8 -B on(Cuk/he ag ereltc
Cekigsau o osbutn o dfeetsttp:eETD
e llItrup nbeit ITN $f0a t ialdoe Stal nerp rqetit ITE $f0c toDsbedDoe eetngi V iswrig: f06 t ialdoe
-PrallCd $e-Tst D/D ln
-Ts o rtn wr FFFt 40O
Ts f rtn or 0F to$0 K - eto wiigwrd$F0t $0O
-Teto ritn od 00 o$40O
-Teto rtigbt (vn f t 40O
dd 040Ad 0040Ad 0140Ad 0F40 O Nmer f3Kblcsfud:0Adr$040
CimmShdwa ettd uesteeisn oe cimm sopn er
Uig$00D0a sato woke Bae Satadr 0040 nadr 0000
-PrallCde$a-Sarigt seeetd eoy
etn f eillopakdptri ntald <> O ETCE
Dee ie 10]:饥▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒W]:饥▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒U
arbge efore this text was binary numbers 1,2, , 8, 16, 32, 64, 128, 240, 15, 170and85
To help you find biterrors to paul. Nw sarting normal startuptext etc
Amga iagROM V1.1 - 27-Oct-18 - By John(ChckyThe Gang) Hertell
Testing if serial loopbackaaptr i installed: <> NOT DETECTED
ale-tRPmm
itostoftt
Irnb(Af s:
sniOLi oi: Sle ssRf)ide lAl Cf ien
rllo e sU/Si
d 0080Ar040d 0140 Nmrf2bc u:0Ar0000Ad$04Ar$0240d 000d 000 mro 2 osod0Ar$240d d080Ar04Ar$0340d 034mrf2bc u:0Ar008000Ad 0000
sg$0D0asr re(s Satd 040Ear$300
-Prl o a ai eecdmoy
si rlobkae sntl: < ODEEDen eewinDE ▒U
ohlp o id ierr t al. o trin omlstrutxtt8 4 5,10ad85
[mAiaDagRMV. -2-c-8 -BJhn(hcyTh ag Hetl
aale oe$f tr f O,P SessmwhtaieTCED
StalInerp nalbs(ITN df0a oDisbenfmosbtos o ifeetsatus
St l nerutrqesbt ITRQ$f09 oDsbld o Stal M nblbt(MAO df96 oDsaben
Tesigi OLi okig
-PaallCde$e-Te D/D ln
-Ts f rtn wr FF t 40O
eto wiigwor 0F t$0 K - Ts fwrtn od F0 o 40OK -Teto riigwr $00t $40OK
- eto wiigbte(vn fft 0O
et o rtngbt od)$fo$41O
alelCd f -Satof hpedeeto
hpemSaorm eetd,gester sn or hpemsopn hr40dr$084Adr$040d 0040Ad 0040Ad 014
Uig$00D0assatof oke (ae Sartdr 0040 nddr$0100
-PaallCod f Satn o s eece eoy
etn isra oobcaaptri nsald <> O ETCE
te4
[[3Yej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYe▒Yej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej▒▒J▒YYej
l ufdieo oaa wsrn oa auttt4182,1 0a 5
so in r F o4
Ttowtnbten fo$0O
Srdr$00 dd:00
ig$C0ssro rmmBe
Dei feavD
eceCh
Thanks!
-Keith
@▒▒▒U
MAIN MENU
0 - Systeminfo
1 - Audiotests
2 - Memorytests
3 - IRQ/CIA Tests
4 - Graphictests
5 - Porttests
6 - Drivetests
7 - Keyboardtests
8 - Other tests
MAIN MENU
0 - Systeminfo
1 - Audiotests
2 - Memorytests
3 - IRQ/CIA Tests
4 - Graphictests
5 - Porttests
6 - Drivetests
7 - Keyboardtests
8 - Other tests
MAIN MENU
0 - Systeminfo
1 - Audiotests
2 - Memorytests
3 - IRQ/CIA Tests
4 - Graphictests
5 - Porttests
6 - Drivetests
7 - Keyboardtests
8 - Other tests
Memorytests
ea Meali DCNd06tDsl
ei fVi ri:O
-aal d e-e DL i
so in r$F o4
so in r 0 o4
ttd:040Ead 10
sn$C0ssro rm ae
Dei feavD
eceC
so in r F o4
Ttowtnbten fo$0O
Srdr$00 dd:00
ig$C0ssro rmmBe
Dei feavD
eceC ▒U
etn i V s okn:O
aale oe$e Ts DSLSln
ale-tRPmm
itostoftt
Irnb(Af s:
rllo e sU/Si
-Prl o a ai eecdmoy
Tesigi OLi okig
te4
so in r F o4
Ttowtnbten fo$0O
Srdr$00 dd:00
ig$C0ssro rmmBe
Dei feavD
eceCh
