Results 1 to 3 of 3
Thread: A2000 HDD LED with compact flash adapter
  1. #1
    Finger lickin' good Amibayer! matt020's Avatar
    Dec 2009
    Western Australia
    Western Australia
    4 (100%)
    Default A2000 HDD LED with compact flash adapter
    I have an Amiga 2000 with compact flash card for a hard drive, and Iím trying to use the 2000ís HDD LED to show hard drive activity.
    I have soldered the 2000's red HDD LED wire to pin 39 on the CF adapter (the activity line) and all I got was a very dim constant HDD LED light. On the CF adapter, the hdd activity light was constantly lit. The CF HDD drive worked fine reading and writing as normal.
    (I tried connecting black to both ground on the CF adapter, and the Amiga chassis, with same result).
    Any suggestions or help would be appreciated. Thank you!
    Amiga 500 - 030/25 - 1mb chip - 2mb fast - 2GB HDD
    Amiga 2000 - 030/40 - 1mb chip - 5mb fast - 2GB HDD
    Amiga 1200 - 030/40 - 2mb chip - 32mb fast - 4GB HDD
    Amiga CD32 - 2mb chip - 8mb fast - TF328 - 8GB HDD
  2. #2
    Starvak-Sp's Avatar
    Mar 2018
    Spain
    Huelva
    0
    Hi.
    I do not know much about electronics, but from what I've read, I think you have to insert a resistance (330 ohm approx), so it is not always on, and only shine when a voltage is exceeded.
    You can look for the solution in this way.
  3. #3
    Dec 2009
    Western Australia
    Western Australia
    4 (100%)
    I have it working.
    My mistake was connecting positive side of the LED (red wire) to the CF HDD adapter on pin 39, and connecting black wire to ground (chassis). This does not work.
    The correct way is to connect positive side of the LED (red wire) to a 5v positive + power source, BUT put a 330 ohm resister on the red wire somewhere. Then, the black wire of the LED goes to the CF adapter on pin 39. This worked 100%
    +5V --- 330 Ohm resistor --- +side (LED) -side --- pin 39 IDE
    Easy!
  1. Replies: 9
    Last Post: 9th January 2016, 19:00
  2. Replies: 16
    Last Post: 9th December 2015, 21:28
  3. Sold 4 GB Compact Flash With Adapter
    By sblurter in forum Sales Archive
    Last Post: 7th July 2011, 09:22
  4. Sold Compact Flash HD Adapter
    By StrontiumDog in forum Sales Archive
    Last Post: 11th January 2011, 21:06
