I have a small oldish 15 inch cheap LCD TV which I use for retro stuff - right now my BBC Micro is hooked up to it.
Anyway, the TV works in a sense perfect image, RGB SCART, RF, Composite, sound, remote etc all works fine.
The issue is with the standby. While using the TV its perfectly fine but when I put it in standby or off and go to use it later it more often then not will not switch on unless I unplug it and plug it in again - sometimes once, sometimes two or three times.
It has a power LED with 3 colors - Green means ON, when its off or I press standby the light usually goes RED. When I try and power it up the light goes green, then goes orange.
