Hey guys,
I am selling my complete A1200 setup (this is also listed on the Commodore Amiga group on Facebook too)
It is a re-capped 1200 Rev1D4 board. It has 3.1.4 roms fitted and also an IDE2CF with an 8mb CF. It has a HxC slim SD card floppy drive replacement, flashed to the latest firmware.
The A1230 is a GVP Jaws I with FPU and 32mb Ram. I had the EC030 changed for a full gold top 030, which is clocked at the boards limit of 42mhz. The 030 is the 50mhz revision, which does not get as hot as others. Still, I have wired a noctua silent fan to the floppy drive cable as I don't like anything getting warm if I can help it. There is an RTC on the clockport.
The case is one of the A1200.net reproduction cases in White.
There are 2 cons, The first is when I opened the case to take photos, I noticed the floppy drive LED wire had come away from the board. It will need to be tacked on or you could get a Bifrost replacement which is what I was going to do. Also like for like replacements are also available for £13 I think it was on SellmyRetro.
The second con, is that when the board was being serviced, it was found that one of the pads on the Alice chip was raised. So the Alice is socketed with a very small jumper wire to fix the pad issue. All professionally done and works great and you can barely see the jumper with the socket.
With the system will be all my accessories and an aftermarket PSU. The PSU is an Amiga one from C64PSUs.com, the small black bricks with the red switch. Does not get hot and no worries about voltages. I have them for all my wedge amigas and my C64.
There is also a Rastport PCMCIA port re-router, so that your PCMCIA cards (LAN ones in particular) face the back of the system and don't stick out the side taking up desk space. There is also a PCMCIA CF card adapter and an Ethernet lan card, which works great with Miami and roadshow. There is also a dustcover included.
I can include a tank mouse for free but it is a bit yellowed, personally I use the laser mice from Amikit. The white would go well with the White case.
Tried to be as thorough as possible there. I am looking for 580 euros for the lot plus postage from the Netherlands. Payment via PayPal with fees paid. Or alternatively collection from the Amsterdam area.
If you would like any more info let me know.
Thanks.
Thanks.
