Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
Thread: My Amiga500 Desktop-Case project.
  1. #11
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    44
    9 (100%)
    Thanks.
    Yup... I bought it as a defect machine, some 3 years ago. The motherboard was all dead and they are just too darn expensive when they finally show up on eBay or other places. (If they show up at all) At least I get CPU, Memory, 1 GigaByet SCSI harddrive and SCSI CD-Rom drive out of it. The case just screamed Amiga to me.
    Quote Originally Posted by Rakeim132 View Post
    I think you are going down a very complicated job with the keyboard. Why don’t you find a big box Amiga keyboard (even deffective because your A500 keyboard will perfectly fit in it) and work out a neat connection between it and the case?
    Making keyboard, making keyboard. It's not a cat, nor it's a hat......
    Fun aside.... There is nothing a sharp box cutter cant not do, with old soft ABS plastic. The wires need to be rerouted or the keyboard-shell need to have a bit more material removed. Yet this is the progress so far. Biggest issue is time, because it takes two days to remove all this, because it need to be fitted perfectly.
    I did consider an old Dell membrane keyboard, yet this was an Keytronic membrane IBM ripoff. And yes, membranes, ohh the horror. (At least it was dead)
    Next step is to make a better fit for the wires, glue in some brass standoff's so I can close it with 2 or 3 screws and finally make a new plate to hide the PCB and the plack plate. When done, I need to fix it with some filler and do a paintjob. Surface need to be flush.
ID:	149228Click image for larger version.
ID:	149229Click image for larger version.
    Quote Originally Posted by rcade View Post
    Very tastefully done. Now all you need is a logo sticker...
    Yup... I will go for a custom one, if I can find some place that allow me to design my own.
  2. #12
    Rakeim132's Avatar
    Jun 2010
    Australia
    Gold Coast
    48
    77 (100%)
    Iím very impressed with your determination.
    It definitely comes from a vision you have, and I see which one now. Good job!
    A600HD, A1200 in "home made" tower, A4000T in progress...
  3. #13
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    44
    9 (100%)
    I’m very impressed with your determination.
    The vision that I have been building from, is to have a convertion that not many show off (most are towers). And to have something that are designwise in the spirit of both Amiga and late 80's or early 90's. The last part of the vision is to have a total case convertion. Meaning, that I convert an Amiga500 keyboard into a PC keyboard shell as well. Finally, it is kind of the best choice to have a real Amiga500 keyboard, for an Amiga500 anyway. Modern keyboards are not really the same, and personally I hate keyboards with switches. It is that punch that the switches give in tactile feedback, that I simply can not stand. And even worse, is the clicking noises that a real IBM Model-M gives. The two best keyboards that I have ever tried in my life, are Mitsumi Amiga500 keyboards and Commodore64 keyboards. I just love these keyboards with springs that are not switches. Yes they are as far as I know membrane, yet they are not rubber dome. It is the spring that for me makes a good keyboard. Like I have a couple of PC keyboards that have springs. And they are heavy as well, because they have this metal plate inside. Let people keep their Model-M's or modern mechanical keyboards. They are not for me.
  4. #14
    voyager_1701e's Avatar
    Jan 2014
    Australia
    Maitland, NSW
    46
    126 (100%)
    That's a great project you've got, I like your choice of case
    Ash
    A1200 ACA1221 ACA1221lc, A600 ACA620/Vampire II Black, A500,A500+ and A500++ ACA500+ and Vampire II, A2000 Recreated with VXL30, C64 / C64 Reloaded
  5. #15
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    44
    9 (100%)
    Quote Originally Posted by voyager_1701e View Post
    Thanks...
  6. #16
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    44
    9 (100%)
    Gave my 500-Desktop some IDE and Ram upgrade....
    https://to9xct.blogspot.com/2019/08/...0-vintage.html
  7. #17
    McTrinsic's Avatar
    Oct 2013
    Germany
    Leverkusen
    15 (100%)
    As much as I think that this is a great project. I donít think I would consider a 7200rpm drive silent. Go for a CF!
  8. #18
    mariuszk844's Avatar
    Mar 2017
    Poland
    Masovian
    16 (100%)
    quite neat! i need to look for some desktop case too
  9. #19
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    44
    9 (100%)
    Quote Originally Posted by McTrinsic View Post
    As much as I think that this is a great project. I don’t think I would consider a 7200rpm drive silent. Go for a CF!
    Yeah. A couple of those drives had spinning noises. Yet the one I chose are quite low noise. I am having trouble hearing the platters spinning and the head-noise are equally low noise. I am having problems hearing the drive, once it is inside the case. Pretty darn close to silent. However. I did not say that it is noise-less at all, only that it is extremely low noise.
    Quote Originally Posted by mariuszk844 View Post
    Thanks.
    Yeah... Those cases are quite difficult to get a hold on. I have an old IBM case, yet the PSU is resting at the bottom of the case of that one. However that case, are a prime candidate for an Amiga600 case mod. The biggest issue, is that the IBM case looks too much like a PC and have none of those Amiga design language qualities to it. A good paint job will get rid of most of the IBM'ish look.
  10. #20
    Mar 2017
    Poland
    Masovian
    16 (100%)
    But as for now i have plans to towerize one of my A600.
    Few weeks back bought this AT case (whole PC to be exact for $5, on local flea market), that looks like E-Box 1200 Power Tower, slightly slimmer.
  1. Replies: 176
    Last Post: 30th November 2016, 23:22
  2. Replies: 13
    Last Post: 14th February 2016, 21:34
  3. Walker Case Project - Was: My New Project Teaser
    By Justin in forum Legendary Threads of the Photo Booth
    Last Post: 18th October 2013, 13:00
  4. A600 Desktop project
    By merlinkv in forum Photo Booth
    Last Post: 7th April 2011, 17:39
  5. A600 / Slim-Desktop PC project.
    By merlinkv in forum AmiOracle
    Last Post: 14th February 2011, 08:17
