Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: My Amiga500 Desktop-Case project.
  1. #1
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    Age
    43
    9 (100%)
    Default My Amiga500 Desktop-Case project.
    Hi all.
    I want to share two pictures of my 500-Desktop project, as the project have progressed as of now. Except for the keyboard hookup, then it is a fully functioning 500, just inside an old 1994 PC desktop case. The power to the systemboard is likewise internal.
    Just a quick note. This is the first time in my life that I have ever embarged on such a project, and it is the first time that I have ever cut anything with a dremel cutter. So bear with me, if the finish is not quite the best. The board is sitting on it's original RF shield, and I did give it an onboard ChipMem upgrade. Memory is at this stage only 1mb.
    I have one question...
    What Amiga model, does my case look like the most? To me it looks like a bunch of Commodore models, came together and made a child.
    Like they say... Pic's or it did not happen. (did I do well?)
ID:	149119Click image for larger version.
    As I mentioned. Then I need to sort out the missing keyboard issue. Then add the following stuff:
    - Internal IDE interface.
    - 8mb FastRam.
    - Scandoubler.
    - DF0/DF1 boot selector.
    - Kickstart switcher.
    The goal (for me personally) is to have a unique Desktop Amiga, designwise, that have a compatibility close to 500/OCS.
    Just with a bunch of features on top.
  2. #2
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    148 (100%)
    Hi it looks made for it
    You got pics of inside too
    A1200T 1d4:blizzard 1260/50/64mb:fastata-iv:amiga to ps2 mouse:80gb hd:zip100 ide:a4000 keyboard
    A1200D 1d4:blizzard1230mk4/50/64mb:indy mk ii:fastata mk ii:40gb*A1200 rev 2b*2 x A1200 1d4*A1200 1b*A600 2mb 4gb*A500
    PC:8700k@4.8ghz, Msi sli plus mobo, Corsair 32gb ddr4 3000mhz, Evga 1080ti ftw hybrid, Evo 970 m2 500gb.
    sfs cf guide http://www.amibay.com/showthread.php?t=19953 cwb3.9 guide http://www.amibay.com/showthread.php?t=20315 mediator drivers http://www.amibay.com/showthread.php?t=11993 p96 newres guide(radeon install) http://www.amibay.com/showthread.php...905#post325905
  3. #3
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    Age
    43
    9 (100%)
    Quote Originally Posted by johnim View Post
    Yup... I had to do some custom mounting points and cut the RF shield. Then have the board lifted up, using a piece of cardboard and using some epoxy to secure the mounting points. The result is a board, that are mounted, using the holes that are on the board.
    I will keep the pictures for now, as I need to use them for my blog. I will however post a couple of youtube vid's that I made. They are short and are only meant as quick demonstration vids, so they are not public on youtube.
    https://youtu.be/c2ykj5DoI-o
    https://youtu.be/6r2jwwg88yY
    Hope you like them.
  4. #4
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    Age
    43
    9 (100%)
    I have done the build-log on my blog....
    https://to9xct.blogspot.com/2019/08/...0-vintage.html
  5. #5
    Kyle's Avatar
    Nov 2009
    Livorno, Italy
    Toscana
    Age
    43
    117 (100%)
    Well done!
    And the case is very Amiga stile
  6. #6
    Rakeim132's Avatar
    Jun 2010
    Gold Coast
    Age
    48
    76 (100%)
    Really cool build. There are some nice and modern solutions for the keyboard, such as this one:
    https://rover.ebay.com/rover/0/0/0?m...2F133011221515
    Keep us informed of your progress!
    A600HD, A1200 in "home made" tower, A4000T in progress...
  7. #7
    Brostenen's Avatar
    Nov 2015
    Denmark
    Northern Jutland
    Age
    43
    9 (100%)
    Quote Originally Posted by Kyle View Post
    Well done!
    Thanks... I am happy with the case. I have another desktop case, that are an old IBM case. Also 486 era. It is one that have this sliding door. I chose the Unisys case, because it looks way better than the IBM, and because the IBM have no space under the PSU.
    Quote Originally Posted by Rakeim132 View Post
    I will.... Yes. I have seen those adaptors. Yet I think an USB adaptor are a way better choice. As far as I can see, then I can have an original 500 keyboard attached as well. So I have begun to build my own standalone keyboard today. I have taken an old AT class keyboard that are of those membrane types, and gutted it. Don't worry, it was dead anyway. And I am slowly removing the correct amount of material on order to be able to fit a 500 keyboard inside it. The worst part will be to create a custom top-plate for the keyboard. You know. Cutting out the correct openings for the keycaps and then glue it firmly in place and finally create a paseable surface finish.
  8. #8
    Aeberbach's Avatar
    Feb 2019
    Victoria
    5 (100%)
    Looking really good! Quality beige cases like that Unisys are a real find now.
  9. #9
    Rakeim132's Avatar
    Jun 2010
    Gold Coast
    Age
    48
    76 (100%)
    I think you are going down a very complicated job with the keyboard. Why donít you find a big box Amiga keyboard (even deffective because your A500 keyboard will perfectly fit in it) and work out a neat connection between it and the case?
  10. #10
    rcade's Avatar
    Jun 2008
    United States
    Augusta, Georgia
    Age
    48
    8 (100%)
    Very tastefully done. Now all you need is a logo sticker...
    Pete Rittwage
    C64 Preservation Project
  1. Replies: 176
    Last Post: 30th November 2016, 22:22
  2. Replies: 13
    Last Post: 14th February 2016, 20:34
  3. Walker Case Project - Was: My New Project Teaser
    By Justin in forum Legendary Threads of the Photo Booth
    Last Post: 18th October 2013, 12:00
  4. A600 Desktop project
    By merlinkv in forum Photo Booth
    Last Post: 7th April 2011, 16:39
  5. A600 / Slim-Desktop PC project.
    By merlinkv in forum AmiOracle
    Last Post: 14th February 2011, 07:17
Tags for this Thread
