Results 1 to 8 of 8
Thread: Installing problem AmigaOS 4.1
  1. #1
    McA4000T's Avatar
    Aug 2019
    Netherlands
    Noord-Holland
    0
    Default Installing problem AmigaOS 4.1
    After years of not using my A4000T, I wanted to install AmigaOS 4.1 (not the final edition).
    I am currently running 3.9 without problems, even when I try my emergency floppy together with the CD, everything works fine.
    Now when I startup with the bootfloppy of 4.1 everything seems to work fine, the CD is spinning and it sounds it's beginning to install.
    But then the CD stops spinning and nothing else happens, screen stays black. I am using a Picasso IV with RTG.
    Now I also connected a 1084S monitor and then I see in the moment the install stops a blue, red, green flash in the screen,
    last color remains in the screen and that's were it al ends.
    So I hope someone can shine a light on this.
    For me it is strange that 3.9 has no problems at all and 4.1 (4.0 has same problem) will not install.
    A bit info on my A4000T:
    Picasso IV, CSPPC 604/200MHz, Plextor UltraPlex CD-rom (SCSI), kickstart ROM V3.1 (40.70).
  2. #2
    McA4000T's Avatar
    Aug 2019
    Netherlands
    Noord-Holland
    0
    A little update:
    I tried my CSPPC in a A4000D, which had no other expansions and the problem was exactly the same.
    So I guess the problem must be in my CSPPC.
    I know my UW-SCSI controller onboard my CSPPC is faulty, but there is nothing connected to it.
    Now my question is, is it possible that during the installation the UW-SCSI controller is checked anyway and causes the crash?
  3. #3
    Amibayer! drbrain's Avatar
    Mar 2010
    Sweden
    Helsingborg
    Age
    36
    53 (100%)
    What SCSI-card do you usefor The CD? The onboard A4000T SCSI is not supported iirc.
    Not all of them are supported in OS4.1...
    Have you tried with a CD connected to the internal IDE-port?
    A4000DT: CSPPC 604e@330, 060@60, Mediator PCI 4000D, R9200 256MB, CVPPC, IndiAGA MKII, Deneb, PCI NIC+Sound, 144MB, Intel 40GB SATA SSD, AmigaOS 3.9/4.0/4.1
    A1200D: Blizzard1220@28MHz, 8MB, IndiAGA MKII, AmigaOS 3.9 A4000D: 030@25, IndiAGA MKI, 8MB, AmigaOS 3.9 A3000D: 030@25, 16MB, AmigaOS 3.9
  4. #4
    McA4000T's Avatar
    Aug 2019
    Netherlands
    Noord-Holland
    0
    The Plextor is SCSI indeed connected to the internal SCSI.
    I do not have a IDE CD-ROM player.
    So the UW-SCSI controller is indeed checked, may this cause the crash or has it something to do with using the internal SCSI?
  5. #5
    Online Gangster Amibayer! fitzsteve's Avatar
    Aug 2009
    Sevenoaks, Kent
    Age
    39
    1013 (100%)
    Blog Entries
    2
    The CSPPC UW SCSI is supported by OS4.1 so as you say this might be the issue as it's probably trying to load the module.
    Have you tried connecting active terminators to the SCSI? Or can the SCSI not be turned off in the CSPPC boot menu?
    Lastly you could try to install OS4.1 in WinUAE and then load up the installed disk on your Amiga?
    My Website has moved to: https://fitzstevesamigaworld.000webhostapp.com/ It's now on Free Hosting to preserve the content.
    My YouTube Channel: https://www.youtube.com/user/fitzsteve
  6. #6
    McA4000T's Avatar
    Aug 2019
    Netherlands
    Noord-Holland
    0
    I checked the boot menu, but you can switch on/off the ID's except 7, which is the controller.
    I switched off all the ID's but same result, crash during installation.
    I guess my sick CSPPC needs a doctor ...
  7. #7
    Aug 2009
    Sevenoaks, Kent
    Age
    39
    1013 (100%)
    Blog Entries
    2
    Quote Originally Posted by McA4000T View Post
    Maybe you can comment out the module in the SS for 4.1 so it doesn't try to load the SCSI?
    I can zip you OS4.1 Classic Ready to run if it helps? (of course I need to see your CD)
  8. #8
    McA4000T's Avatar
    Aug 2019
    Netherlands
    Noord-Holland
    0
    Thanks for the offer, but I prefer to fix the UW-SCSI controller first.
  1. Having a real hard time installing AmigaOS
    By samaron in forum AmiOracle
    Last Post: 30th December 2014, 19:19
  2. Problem installing Cgx v4
    By UberFreak in forum AmiOracle
    Last Post: 28th February 2011, 20:11
  3. New to Amibay need help installing AmigaOS.39
    By AmigaRevolution in forum AmiOracle
    Last Post: 8th February 2011, 19:38
  4. Problem installing CyberVisionPPC
    By TheRogue in forum AmiOracle
    Last Post: 7th June 2010, 01:06
Tags for this Thread
