Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 53
Thread: Full anodised aluminium front bezel for A4000 - Interest poll
  1. #21
    Nowee's Avatar
    Sep 2013
    France
    Lorraine
    10 (100%)
    Blog Entries
    1
    Hello, intterested as well!
  2. #22
    Amibayer! Magic's Avatar
    Feb 2008
    Edmonds Washington USA
    8 (100%)
    I am interested.
  3. #23
    PRS's Avatar
    Dec 2015
    Dutchieland (Netherlands)
    Utr
    23 (100%)
    Excellent!
    I will add you both to the list...
    Only 2 to go!
    Amiga 500 Rev.3 (stock) and 500 Plus (2MB chip, GVP A530 8MB, A500Flash)
    CDTV (2MB chip, 8MB fast, SCSI, kickstartswitch)
    Amiga 1200d Rev. 1d4 (BPPC 66/333Mhz, BVision, HxC floppy, PicoPSU, RapidRoad)
    Amiga 4000d (Cyberstorm mk III 68060@50Mhz, Picasso IV, RapidRoad)
  4. #24
    PRS's Avatar
    Dec 2015
    Utr
    23 (100%)
    Please find some snapshots of the CNC drawing. The orange parts are machined with a 2mm radius, as that is the lower limit.
Name:	Amiga corners.jpg
ID:	150112 Click image for larger version.
Name:	Amiga corners 2.PNG
ID:	150113 Click image for larger version.
Name:	Amiga corners 3.jpg
ID:	150114 Click image for larger version.
Name:	Amiga corners 4.jpg
ID:	150115 Click image for larger version.
Name:	Amiga corners 5.jpg
    The current price (if all 8 will continue to the purchasing part) is € 1422,- per lot, i.e. € 177.75 per bezel (excl. shipping to your address and if applicable paypal fees).
  5. #25
    shanshe's Avatar
    Apr 2018
    Spain
    Seville
    7 (100%)
    Quote Originally Posted by PRS View Post
    Please find some snapshots of the CNC drawing. The orange parts are machined with a 2mm radius, as that is the lower limit...
    2mm? won't it be 0.2mm? I think letters can't be made with a 4mm diameter milling bit..., but could them be made with a 0.4mm one?
  6. #26
    Feb 2008
    8 (100%)
    Will there be enough flex in the attaching prongs to allow them to snap in to the front of the case without breaking? The plastic holders are a pretty tight fit as is.
  7. #27
    PRS's Avatar
    Dec 2015
    Utr
    23 (100%)
    I got an update from the manufacturer, and the lowest radius that they can offer is indeed 0.2mm
    With regard to the clips, I'm not sure about the flexibility of them. However, I'm looking into the possibility to adapt the design a little to solid rods with thread, so we can screw the front to the amiga chassis.
  8. #28
    Stoobs's Avatar
    Nov 2013
    Suffolk
    0
    Hi all, this is exactly why I created the project - either 3D print it, or get them milled - I'm still not 100% sure of the tolerances for milling, but I'm pleased someone is giving it a try
    I do have the design up on shapeways, but the cost was so high I never ordered one to test - I've 3D printed it on a home FDM machine and the fit seems good enough (I designed it so it can be printed in two parts and joined together - fill with superglue etc and spray paint to make whole), I also designed it with magnets in mind on a later revision (The posts pop into a recess, so changing them out for magnetic catches should be simple).
    Looking forward to seeing the results!
  9. #29
    PRS's Avatar
    Dec 2015
    Utr
    23 (100%)
    Hi Stoobs,
    I think this fellow is using your design and sells them 3d printed:
    https://3dprintserviceshop.com/en/we...r-coming-soon/
  10. #30
    Stoobs's Avatar
    Nov 2013
    Suffolk
    0
    Hi Stoobs,
    Hmm, I'm not against anyone wanting to produce them commercially, but credit would be nice... (in fact if that's from thingiverse, then he should be giving me attribution as per the license, although my github is MIT, sooo...)
    Oh, and in case it wasn't clear, this group buy has my full blessing, in fact I'm tweaking the design so that the magnetic attachment stand half a chance of working!
    If there are any issues with the design when sending for CAM I'm more than happy to tweak it
  1. Found A4000 top metal case, A4000 front plastic bezel
    By trixster in forum Amiga
    Last Post: 26th August 2018, 22:52
  2. Wanted Perfect A4000 front bezel.
    By ElectroBlaster in forum Amiga
    Last Post: 9th August 2018, 00:28
  3. Wanted a4000 floppy front bezel - normal height
    By dday_one in forum Amiga
    Last Post: 12th May 2016, 09:12
  4. Sold A4000 front bezel & power button
    By Sleepy_Man in forum Sales Archive
    Last Post: 9th November 2012, 06:17
  5. Closed A4000 Floppy drive Front Facia/Bezel
    By hikey in forum Found Archive
    Last Post: 15th July 2010, 12:54
Tags for this Thread
