Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: Did my PPC604e die?
  1. #1
    McA4000T's Avatar
    Aug 2019
    Netherlands
    Noord-Holland
    1 (100%)
    Default Did my PPC604e die?
    I have a CSPPC in my A4000T, but I am afraid that the PPC is no longer working.
    I do have the ppc.library (v46.37) and ppcdiss.library, but when I run PPCInstall it says "no ppc.library available".
    SysSpeed doesn't mention a PPC either.
    Are there any other tests I can run or anything I can check?
    Help and tips are very much appreciated.
  2. #2
    Online Gangster Amibayer! fitzsteve's Avatar
    Aug 2009
    Sevenoaks, Kent
    Age
    40
    1026 (100%)
    Blog Entries
    2
    What does sysspeed/whichamiga say?
    Or you could try installing warpos and running an PPC application like ADoomPPC
    Finally you could try to reflash the firmware
    Beyond that I would send it to an expert like Stachu
    My YouTube Channel:
    https://www.youtube.com/user/fitzsteve
    CD32 + TF330, A500+ Vampire V2, A1200T Black Box + Mediator B1260 + Killer K1 PPC
  3. #3
    Amibayer! drbrain's Avatar
    Mar 2010
    Sweden
    Helsingborg
    Age
    37
    57 (100%)
    You could try downloading the PPC Test Disk from here and boot from it. That way you can test the PPC without any OS interfering with the tests.
    http://powerup.amigaworld.de/index.php?lang=en&page=24
    A4000DT: CSPPC 604e@330, 060@60, Mediator PCI 4000D, R9200 256MB, CVPPC, IndiAGA MKII, Deneb, PCI NIC+Sound, 144MB, Intel 40GB SATA SSD, AmigaOS 3.9/4.0/4.1
    A1200D: Blizzard1220@28MHz, 8MB, IndiAGA MKII, AmigaOS 3.9 A4000D: 030@25, IndiAGA MKI, 8MB, AmigaOS 3.9 A3000D: 030@25, 16MB, AmigaOS 3.9
  4. #4
    McA4000T's Avatar
    Aug 2019
    Netherlands
    Noord-Holland
    1 (100%)
    Quote Originally Posted by fitzsteve View Post
    SysSpeed does only recognise the 060, Scout says PPC n/a.
    Tried earlier WarpOS with no luck.
    I just reflashed the firmware with no luck either.
    Quote Originally Posted by drbrain View Post
    Tried that, it starts with PPCInstall, so this came with the same result: no ppc.library available and a "ppctest failed" error message.
    Also did the WarpOS test, it just says "Starting WarpOS test" and that's it, no results, nothing happens after that.
  5. #5
    Aug 2009
    Sevenoaks, Kent
    Age
    40
    1026 (100%)
    Blog Entries
    2
    Sorry to hear that, it definitely seems there's an issue with the hardware
    My YouTube Channel:
  6. #6
    Mar 2010
    Sweden
    Helsingborg
    Age
    37
    57 (100%)
    As fitzsteve said there seems to be a hardware problem if all tests fail.
    If you want to repair it, then talking to stachu100 is probably your best option.. http://www.amibay.com/member.php?1445-stachu100
  7. #7
    McA4000T's Avatar
    Aug 2019
    Netherlands
    Noord-Holland
    1 (100%)
    Now I am confused ...
    I put some fresh solder on the oscillator of the PPC and the PPC was recognized in SysSpeed, scout and WhichAmiga.
    Then I did the ppctest and it failed.
    After the next reset the PPC was no longer found and it still isn't.
    Still I am convinced that the PPC is working and some other component is preventing it from functioning.
    Anybody any ideas what I can test or try next?
  8. #8
    k0x's Avatar
    Aug 2013
    Czech republic
    Ostrava
    136 (100%)
    Better send it to some hw specialist - its to pricey
  9. #9
    matt3k's Avatar
    Mar 2011
    United States
    NY
    32 (100%)
    Having owned one of these card, it probably is the socket. The sockets on this card are extremely fragile. If your handy enough replace the sockets for both cpus, if not find a specialist.
  10. #10
    Aug 2009
    Sevenoaks, Kent
    Age
    40
    1026 (100%)
    Blog Entries
    2
    Or maybe the PPC chip needs to be reflowed, send to Stachu or similar for a service, maybe even upgrade the chip whilst you're at it. Resist any urge to overclock the 060 as bus speed increase isn't good for the fragile CPLD. Good luck
    My YouTube Channel:
  1. Closed PPC604e 233Mhz
    By BLTCON0 in forum Other
    Last Post: 9th February 2019, 19:22
  2. Closed PPC603e CPU for BPPC and PPC604e CPU for CSPPC
    By blizzard-pl in forum Found Archive
    Last Post: 2nd October 2012, 07:09
  3. Closed Phase 5 Cyberstorm PPC604e
    By Nash in forum Sales Archive
    Last Post: 4th May 2012, 22:52
  4. Sold CYBERSTORM PPC DCE 060@50MHz / PPC604e@233MHz
    By LTAC in forum Sales Archive
    Last Post: 17th March 2011, 14:37
  5. Found Cyberstorm 060/PPC604e
    By Detordiggei in forum Found Archive
    Last Post: 15th December 2010, 21:27
Tags for this Thread
