gseb
This is for the adapter only, cpu is NOT included in the sale.
This adapter is built with one real 040 and 060 socket. It’s a 2 layers model, no additional pins layer are in between the 2 sockets.
I tested it on my A3640 test card and it's working perfectly. If you want to use it with others accelerators, you will have to find out yourself if it’s suitable or not for it.
Be aware that this is a very low profile version and that it only can fit on your accelerator if no components on your accelerator card's area where there is the regulator/network resistor (on 060 adapter) are not higher than the 040 socket from you accelerator. See last photo from the link Album...
The A3640 has to be equipped with ceramic capacitors instead the alu one on this area. Alu one will probably collide with the adapter if they are higher than the 040 socket's accelerator....
3.1.4 KS highly recommended as it does not need to be patched to work with a full 060.
If you really want to use KS 3.1, it has to be patched to work with a full 060.
Asking now 60€ (was 65€) for this adapter + post as PayPal gift.
Photos here :
https://photos.app.goo.gl/EuXuaNTBdiFC9f5R7
Also on sale on another place.
Photos here :
