Results 1 to 7 of 7
Thread: A2K rev.6.2 mobo black screen
  1. #1
    pietro_tiberi's Avatar
    Sep 2009
    Rome - Italy
    Lazio
    0
    Default A2K rev.6.2 mobo black screen
    I'm trying to restore an A2k. CPU and Kickstart are ok (pulled from a working A2K). PSU is Atx and jumper J300 is set properly (pin 2-3 connected). CPU voltage is 4.94 V (pin 14-16).
    But I get BlackScreen...what should i check next?
    Inviato dal mio Redmi Note 7 utilizzando Tapatalk
  2. #2
    Finger lickin' good Amibayer! matt020's Avatar
    Dec 2009
    Western Australia
    Western Australia
    7 (100%)
    I have a motherboard with the same issue. It is common for the A2K motherboard to suffer battery damage, and for traces between CPU and Kickstart ROM to be damaged.
    What is the condition of the board around the CPU and ROM chip?
    Amiga 500 / 2000 / 1200 / CD32
  3. #3
    Sep 2009
    Rome - Italy
    Lazio
    0
    Some tracks look like damaged but I tested them with a multimeter an connection is ok. I checked carefully pin 6&7 from CPU to Gary,FatAgnus,buster&co and they are ok.
    I tested pin 2,3,4&5 from CPU to ROM and they are fine....
  4. #4
    QuarXky's Avatar
    Nov 2014
    Spain
    Granada
    8 (100%)
    Pay attention to CPU socket the contact in the red circle not appear so good, be carefull with this.
  5. #5
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    even contacts on ROM socket are green-blue, sign of acid attack! Another thing, with this issue, sometimes, multimeter do not tell the truth! You need to clean all the contacts (solder joints and via) and replace sockets.
    Regards
    Stefano
  6. #6
    Sep 2009
    Rome - Italy
    Lazio
    0
    Connection fron pin1 CPU to Rom is ok. But I have RST pin18 always High. could you helpm me?
  7. #7
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    105 (100%)
    Hello,
    the right things to do is replace CPU and ROM socket.
    Regards
    Stefano
  1. CM8833 Black screen
    By dougal in forum AmiOracle
    Last Post: 12th August 2017, 02:15
  2. 500+ That had a black screen.....
    By britlord in forum AmiOracle
    Last Post: 27th May 2016, 05:15
  3. C64 with Black Screen
    By rob_santry in forum AmiOracle
    Last Post: 14th September 2015, 06:32
  4. A600HD Black Screen
    By Brataccas in forum AmiOracle
    Last Post: 22nd January 2009, 01:56
