Page 6 of 6 FirstFirst ... 23456
Results 51 to 56 of 56
Thread: Heavily expanded A1200 now split
  1. #51
    Iwoska's Avatar
    Feb 2019
    Ireland
    Roscommon
    58
    43 (100%)
    Parcel arrived at the beginning of the week but I did not have time to open it until now.
    Everything ok. Positive feedback left. Thank you.
    Quote Originally Posted by Cozzer79 View Post
    Payment received and feedback left. I'll get that packaged up this evening and on its way to you tomorrow; I'll confirm tracking then.
    Not had your address yet that I can see - I'll send a chaser later if I've not got it by then. Thanks! Edit: Got it, thanks again!
    Quote Originally Posted by Iwoska View Post
    Payment sent for:
    Amiga 1200 upgraded PSU (power-switched unit inside, Eos VLT60-3000) 45
    PCMCIA WiFi network card (WPA2 enabled) 15
    PCMCIA CF card adapter (with 1GB CF Card - blanked) 10
    Address sent by PM
    Commodore VIC 20, 64, 128 Spectrum 48, 128+ Philips NMS8245 (MSX2)
    Commodore Amiga 500, 500 Plus, 600, 1200 030/882@50MHz 256MB
    PC SS7 AMDK6III@500MHz 768MB
    Sega SMS, SMD Nintendo NES, SNES, N64, GBA NEC PC Engine
  2. #52
    Amibayer! timtheloon's Avatar
    Apr 2015
    United Kingdom, England
    Hampshire
    136 (100%)
    Default Heavily expanded A1200 now split
    A1200 mobo received
    tested it I was like why is it not working oh yeah no 020 cpu need a accelerator!!!
    one question when does it start graphic glitching????
    positive feedback left too
    Happy New Year Retro Users
  3. #53
    Amiga Enthusiast Cozzer79's Avatar
    Nov 2015
    United Kingdom
    Oxfordshire
    40
    80 (100%)
    lol - yup, no CPU fitted!
    With an Indivision AGA fitted, the glitches start from cold boot - with the cable attached to it it was pushing g the right side of Lisa up, but without it fitted, I've not had it do anything worrying after several hours. Most likely a dry joint so it'll need reflowing eventally if you're not going to put an Indivision on it
    Quote Originally Posted by timtheloon View Post
    A1200 mobo received
    AMIGA WinUAE
  4. #54
    Apr 2015
    Hampshire
    136 (100%)
    it been on for a while now and still no glitches maybe it was that last magic push you give it
    Ill try it with an indy to see what happens
  5. #55
    Kunglao's Avatar
    Mar 2016
    Germany
    Munich
    39
    5 (100%)
    Received parcel, very good shipping protection and packaging. First test booted up the BPPC but did not boot with B-Vision attached. I assume my PSU needs an update as it only provides 4A at 5V. Ordered a 12A/5V variant and will inject additional 5V to Floppy-Power-Port. Testing can start in two weeks from now as I'm busy until then, but assume everything will be fine. Great card, thanks for the deal.
  6. #56
    Nov 2015
    United Kingdom
    Oxfordshire
    40
    80 (100%)
    Hi matey - it needs a biiiiggg PSU; Stachu recommended at least 8A on the 5V rail. On my board, I added wires for 5V, 12V and Ground from the underneath of the power supply connector to the rear of the floppy power connector - a common mod to improve power distribution. Injecting power into the floppy connector is another popular method though. Not all boards are equal! I know the 12V isn't necessary for this, but I had numerous 12V fans running from the floppy connector.
    Quote Originally Posted by Kunglao View Post
    AMIGA WinUAE
  1. Replies: 10
    Last Post: 30th May 2012, 09:03
  2. Closed Huge A1200 package, as a whole or split.
    By Sallinen in forum Sales Archive
    Last Post: 25th July 2011, 23:31
  3. Closed Expanded A1200
    By Dagger in forum Sales Archive
    Last Post: 9th July 2010, 16:10
  4. Sold A4000/060 Heavily Expanded
    By Ruud in forum Sales Archive
    Last Post: 17th February 2010, 01:49
