Hi all,
I have recently acquired a hp Proliant ML350 G6 server which is in desperate need of an upgrade, as it currently only has 6gb of ram and a Intel Xeon 5506 processor... with this in mind I would like to get hold of the following, if anyone has any for sale:-
1. Server grade Registered ECC memory PC3-10600R (ddr3 1333)... I believe this is triple Chanel memory so has to have three memory modules of the same size to work but please someone correct me if this is not the case.
2. Intel Xeon X5675 (6 core)... which is the best Xeon that this motherboard will except
Also I need some advice about service packs/bios updates for this machine... after some research I have found out that you have to have an active service plan with hp to be able to download service packs. As you may well be aware that this server is that old and has been unsupported by hp for many many years there is just no financial reason to have a service plan with them for this outdated server, if in fact they will do anything for it! Anyone with any ideas on how to download the service packs/bios updates please?
Thanks in advance
kindest regards
Thanks in advance
kindest regards
