Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Elbox Mediator PCI 4000Di Mk II 5V
  1. #11
    timmie's Avatar
    Dec 2014
    Netherlands
    Utrecht
    46
    37 (100%)
    OK, since I'm still not convinced power is the cause of my issues, I would like to make sure the mediator I have is not the cause either. So still looking for this non 3V edition of the Mediator 4000Di.
  2. #12
    Amibayer! timtheloon's Avatar
    Apr 2015
    United Kingdom, England
    Hampshire
    155 (100%)
    You still up for the swap??
    Got too many Amigas, Think I gotta problem
  3. #13
    timmie's Avatar
    Dec 2014
    Netherlands
    Utrecht
    46
    37 (100%)
    Thanks for the offer. But as I hope you understand, I'd rather first test with an older Mediator and depending on the outcome choose which one to keep.
  4. #14
    Apr 2015
    Hampshire
    155 (100%)
    No problem I understand but if you change you mind my swap offer still stands
  5. #15
    BULI's Avatar
    Jun 2015
    Poland
    Rzeszów
    21 (100%)
    Quote Originally Posted by timmie View Post
    - Additional issue: Wipeout has crackling audio with AHI, no matter what (working) AHI device I pick (SB128: stereo, hifi, ++, SB128_1:,...), but the type of crackling can vary with the type of AHI device. AmigaAMP with WarpUP engine works fine with AHI using soundblaster, no sound issues whatsoever. But my AHI knowledge is limited. I don't know which device should be best for Wipeout, and what I should configure it in terms of samplerate, channels, etc.
    For correct sound in VipeOut set AHI UNIT 0 to Paula Stereo++ 22050 and 1 chanel audio, or Paula 8bit DMA
  6. #16
    timmie's Avatar
    Dec 2014
    Netherlands
    Utrecht
    46
    37 (100%)
    So, now I basically tried with alternatives for all components apart from the mediator. Last step was swapping out the CSPPC for an A3640 and put in a Apocalypse card. Still I get crashes after about 15 minutes of PPC Warp3D gameplay (guru 8100 00FF). And I also tried with a 3rd PSU.
    So a Mk2 5V Mediator to test with my CSPPC is basically my final option to test and see whether it's just Karma that's left as the cause for the instability.
  1. Replies: 22
    Last Post: 12th January 2018, 07:24
  2. Sold Elbox Mediator PCI 4000Di MK2 + PCI cards
    By jack-3d in forum Amiga
    Last Post: 6th March 2016, 21:26
  3. Elbox mediator 4000Di
    By Marmes in forum AmigaKit.com
    Last Post: 3rd July 2013, 17:33
  4. Closed Elbox Mediator 4000Di
    By bitcpy in forum Found Archive
    Last Post: 20th December 2012, 20:01
  5. Found Mediator 4000D for Mediator 4000Di
    By abraXXious in forum Sales Archive
    Last Post: 23rd January 2011, 07:33
