Results 1 to 5 of 5
Thread: Commodore C64 /VIC20 / PLUS4 POWER SAVER_PROFESSIONAL
  1. #1
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    0
    Default Commodore C64 /VIC20 / PLUS4 POWER SAVER_PROFESSIONAL
    --> " POWER SAVER HQ " <--
    PROFESSIONAL POWER SAVER PROTECTION FOR:
    - C64 (all models)
    - VIC20
    - PLUS 4
    --> Over 11 pcs "Power saver HQ" sold on AMIBAY. Thank you for the trust !<--
    This "Power Saver HQ" is different from ordinary protectors: it is professional. And it was created to protect all the Commodore power supplies according to the list.
    The protection is complete, both for the 5VDC line but also for the 9VAC line. It is completely made of semiconductors with very fast intervention times 20us (microseconds!), no relay on board that would require long intervention times 200ms (milliseconds!).
    What does it means this time value?
    It means 10.000 time fasters then relay-based protections . This is the only way we can safely safeguard our Commodore vintage computer
    5VDC MONITORING
    In the event of an output voltage from the power supply greater than 5.35V / 5.4V, our "Power Saver HQ" intervenes to cut off the output voltage, protecting all the ICs on this chain, thus avoiding a rather expensive expense given the cost (6526A, 6510, PLA, RAM, ROM, etc.).
    9VDC MONITORING
    The alternating 9VAC line is monitored and protected by fast solid-state devices that limit any peaks of disturbances coming from the network as well as additional protection against abnormal absorption.
    I remind you that from this line the power supplies for SID 6581 and VIC 6569 are also obtained as verifiable from the official Commodore documentation.
    This "Power Saver HQ" therefore offers you protection both on the 5Vdc line and on the 9Vac line and also has three LEDs used to monitor the smooth operation of both the power supply and the Commodore
    GREEN LED
    1) ON: All ok. Your Commodore is working has 5VDC under safety threshold
    2) OFF: There isn't 5VDC output from the "Power saver HQ " DIN male connector. (No 5VDC at the input of "Power saver".Check if your original power supply is connected and if it works)
    YELLOW LED
    1) OFF --> regular operation.All ok
    2) ON --> protection has occurred ... and your Commodore is SAFE! In this case we will notice that the green LED has also gone out, so we will no longer have 5Vdc output. At this point we will have to open the box to replace the protection fuse (Fuse 1.25A / 5x20mm)
    RED LED
    1) OFF : All ok. Your Commodore is working properly
    2) ON: Your original "power supply" has a serious breakdown, therefore it is likely that its internal regulator (78S05) breaks and about 12V spills out towards the C64 ... disaster!
    DON'T WORRY!
    In this case our "Power saver HQ" intervenes very quickly and cuts off the power supply to your Commodore!
    You only need to repair / replace the original Commodore power supply and replace the internal fuse of " HQ Power saver"
    COMMODORE PLUS 4 (DIN MALE INFORMATION)
    According to 4 PIN square connector that is not available we can provide the "Power saver HQ" with our DIN MALE modified (check the picture) with +8€ extra
    Price --> 35€ 33€
    Price for Plus option --> +8€
    Payment : Paypal friend
    Dispatch time:
    2 working days after payment
    SHIPMENT FOR EUROPE
    --> TRACKED MAIL 12€
    --> UNTRACKED MAIL 8€
    SHIPMENT FOR AMERICA/CANADA/USA
    --> TRACKED MAIL 14€
    --> UNTRACKED MAIL 10€
    SHIPMENT FOR JAPAN/AUSTRALIA/OCEANIA
    --> TRACKED MAIL 15€
    --> UNTRACKED MAIL 11€
    ** for more than 1pcs shipment charge will be optimized by using UPS/SDA courier.
Name:	20200201_125947 (FILEminimizer).jpg
ID:	155008Click image for larger version.
Name:	20200201_130011 (FILEminimizer).jpg
ID:	155009 Click image for larger version.
    Last edited by axel81; 5th April 2020 at 15:56. Reason: Adding pictures,new description
  2. #2
    HappY85's Avatar
    Aug 2011
    Denmark
    DK
    35
    1 (100%)
    Declaring interest in 2 power saver.
  3. #3
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    0
    Quote Originally Posted by HappY85 View Post
    PM replied.
    Payment received
    Shipment done...than you!
  4. #4
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    0
    @Update 28/03/2020
    New price: 33€ (was 35€)
    Description: update compatibility with C64 + C64C + VIC20
    9 UNIT SOLD on AMIBAY!
    Thank you for the trust...
  5. #5
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    0
    @Update 01/04/2020
    Description: update compatibility with Plus 4
    Adaptor for Plus 4: 8€
    @Admin
    Please change Thread name in --> Commodore C64 /VIC20 / PLUS4 POWER SAVER_PROFESSIONAL <Done>
    Thank you
  1. For Sale NTSC Commodore VIC20 P1480257 5c/9v DIN power
    By mrr19121970 in forum Commodore
    Last Post: 18th June 2016, 13:14
  2. C64 power supply on Plus4 ?
    By SunDown79 in forum AmiOracle
    Last Post: 7th March 2015, 23:26
  3. Replies: 8
    Last Post: 3rd February 2015, 19:02
  4. Closed Commodore Vic20 box or Commodore Vic20 Boxed
    By uccio69 in forum Found Archive
    Last Post: 29th March 2014, 12:00
  5. Wanted Commodore plus4 Power Supply
    By scoca in forum Commodore
    Last Post: 15th April 2013, 12:21
