Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Amiga 600 Case Saver Kits
  1. #1
    Jeff_Birt's Avatar
    Nov 2017
    Rolla, MO
    1 (100%)
    Default Amiga 600 Case Saver Kits
    After coming out with the Case Saver kits for the C64 bread bin and 64C we started getting requests for a similar kit for the Amiga 600. The A600 uses similar 'hooks' as the VIC20 and early C64 bread bins but scaled down considerably. In addition to four back clips there are two clips on the side.
    The back clips are made to slip in between the two original 'hooks' and can be used to repair broken clips or to bolster intact clips to keep them from breaking off in the future. The arch of the clip is very close to the original while keeping it as thick as possible for added strength. The 'wings' on the rear of the repair clip register against the original hooks to help align then and keep them in the proper place while the epoxy cures.
    The side clips were tricky to make as there is not a lot of room to work with and we wanted them to also hold themselves into place while the epoxy cures. These repair clips are made to set over a broken clip that is filed flush, so there is a left and right hand side slip. The tip of the hook tapers down to the dimensions of the original clip while being stronger.
    Each kit contains four of the rear repair kits and once each of the left and right side repair clips.
    As these parts are very small and light we set up a special fixed rate shipping method for customers in the United States. This works similar to the International Fixed Rate we set up several months ago for the C64 repair kits.
    NOTE:
    Hi. I wanted to let you know about a fitment issue I found last evening, 3/26/20, with some floppy drives. The 'wings' I added to make gluing in the rear clips easier stick out too far and contact part of the floppy drive mounting bracket. I just modeled a new part without the 'wings' and in new kits two of the 'wingless' type and four of the original 'winged' type will be provided so that the ones with no 'wings' can be used on the right hand side by the floppy drive if needed. I'm sorry if that has cause a fitment issue for your floppy drive. If you have had any issue let me know.
    Per the rules here are the prices. Note that the eBay prices are a bit higher as eBay takes a good sized bite out of every sale.
    From my website: $5 for one kit, $4.25 for 2+. Shipping in USA starts around $2.50, shipping worldwide around $5.
    From eBay: $6.95 for 1, $5.91 2+. Shipping in USA is $1.50, about $5 worldwide.
    My website: https://www.soigeneris.com/amiga-600-case-saver-kit
    eBay: https://www.ebay.com/itm/Amiga-600-C...t/133363149614
    Installation video: https://youtu.be/qYJHp-pm4-Y
ID:	155533Click image for larger version.
ID:	155534Click image for larger version.
Name:	Rear Clip Model.PNG
ID:	155532Click image for larger version.
    Last edited by Jeff_Birt; 7th October 2020 at 16:05. Reason: Revised ebay listing information
  2. #2
    Amibayer! timtheloon's Avatar
    Apr 2015
    United Kingdom, England
    Hampshire
    164 (100%)
    Suppose these could also be used to fix the A1200 case as well, just don't need the side ones
    Got too many Amigas, Think I gotta problem
  3. #3
    Jeff_Birt's Avatar
    Nov 2017
    Rolla, MO
    1 (100%)
    That is a good question, I don't know, don't have an A1200 to measure up. On the C64/VIC20 bread bin cases I've come across seven different variations of the rear tabs. I would not bet on the A1200 being the same. When I manage to get my hands on one I'll measure it up.
  4. #4
    Apr 2015
    Hampshire
    164 (100%)
    Well i'll let you know when my order comes I'm sure they are the same
    Thought I would add some pictures
    Just need one extra back one for the 1200
    has you can see this 600 is in need of this fix
  5. #5
    blindguy's Avatar
    Jun 2019
    United States
    AZ
    10 (100%)
    I just ordered a few packs and I'll try on my A1200.
    I did DL a few things that look like this from Thingverse that are for the A1200 and they didn't didn't fit on my A600 as they were too wide.
    Great stuff!
  6. #6
    Amiga - The Survivor miggymad's Avatar
    Aug 2019
    Hitchin
    35 (100%)
    /watches this thread with interest
    Amiga A1200 - Vampire V4 SA X3 - PC Engine Everdrive - C64 SD2IEC
  7. #7
    Jeff_Birt's Avatar
    Nov 2017
    Rolla, MO
    1 (100%)
    Thanks for the pictures! Please let me know how they fit. They are a solid print so they can be filed or trimmed if needed. When I can get my hands on an A1200 I'll do some precise measurements. The nice thing about having them just the right width is that the friction holds things in place while the epoxy cures.
    I do have an A500 which I'll investigate next and compare to an A500 case someone is sending me that is in rough shape to see what can be done to fix those up too.
  8. #8
    Aug 2019
    Hitchin
    35 (100%)
    Your head's in the way Birt
    You should have that on your profile ...
  9. #9
    Jeff_Birt's Avatar
    Nov 2017
    Rolla, MO
    1 (100%)
    Yeah, my big 'Charlie Brown' head always seems to block the camera.
  10. #10
    tboniasty's Avatar
    Dec 2016
    Poland
    opolskie
    4 (100%)
    Quote Originally Posted by timtheloon View Post
    No, they are not same. I was designing and printing spare latches previous year.
  1. For Sale C64 Case Saver Repair Kit
    By Jeff_Birt in forum Commodore
    Last Post: 30th November 2020, 14:06
  2. For Sale Amiga DIY Kits
    By maw2k in forum Amiga
    Last Post: 16th December 2019, 12:28
  3. C64 ‘Case Saver’ repair kit update!
    Last Post: 24th November 2019, 15:04
  4. Sold Amiga Mouse and Joystick Port Saver Cable
    By Peter in forum Sales Archive
    Last Post: 7th May 2013, 14:22
  5. Sold Amiga 600/1200 CF HD Kits
    By fitzsteve in forum Sales Archive
    Last Post: 31st January 2013, 21:28
Tags for this Thread
