Sold 2x Amy-ITX including chipset + CPU
highpuff
Sweden
Vastra Gotaland
For sale
Selling two fully assembled Amy-ITX mainbaord including a full set of Amiga Custom Chipset.
Amy-ITX Set #1:
1x AmyITX (tested for several hours)
1x 2MB Chipmem Module including RTC chip
1x MC68000 CPU
1x 8545 Agnus 2MB (NOS)
1x Paula
1x ECS Denise
2x 8520 PLCC CIA
1x Kickstart ROM (1.3 or 3.1)
1x D-Sub 15 to VGA cable
Price:
519€ (excluding Tracked Shipping) sent as gift to my Paypal.
Pictures: https://photos.app.goo.gl/4zKj7N5zH1xx7XgWA
Amy-ITX Set #2:
1x MC68000 CPU
1x Paula
1x OCS Denise
2x 8520 PLCC CIA
Price:
499€ (excluding Tracked Shipping) sent as gift to my Paypal.
Pictures: https://photos.app.goo.gl/NMa172iejPU4Vwzs9
Meet AMY
Based around the original custom chips of the Classic Amiga™ computer from Commodore™ I’m ready to run all your favorite Classic games and applications. My core design focuses on compatibility, stability and flexibility. My designer is an experienced hardware engineer and he started this project around 2010. Since then I’ve undergone some major design changes. Early boards were larger (ATX+) and based solely on through hole components. In the latest revision (they call me Amy-ITX now…) all non Commodore custom electronics are super small SMD (Surface-Mount Devices). This not only makes me smaller in size (about 50%) but also cuts cost and makes me more environmentally friendly.
My friends and family have played with me for several years already. And thanks to my original components I don’t have to rely on emulation or programmable gate arrays (FPGA’s). My design is quite elegant and compatibility is extremely high.
Technical
Mainboard
Size / Power
– 170 x 170mm Mini-ITX size with full standard compatibility.
– 24-pin standard ATX-power supply connector.
Ports
– 2x 100-pos Female Card Edge Connectors (Zorro II compatible).
– PS/2 connector for mouse.
– PS/2 connector for keyboard.
– 2x DB9 Joystick ports where one can be used as a serial mouse port.
– 1x DB25 serial communication port.
– 1x DB25 parallel communication port.
– 1x DB15 wide Audio Video (AV) port 15KHz standard Amiga video signal. (Non HD so NOT VGA)
– 1x Floppy 3.5” connector (internal).
Headers
– 1x 3-pin header to connect internal sound.
– 1x 3.5mm connector for external sound.
– Pin header for power on, reset and power led.
Other
– Support for full ECS-chip and 2Mb chip memory.
– ROM-bank switching if using a 27C800 ROM.
Chip memory Module
Memory
– 2MB chip memory (maximum amount of chip memory)
Connectors/Ports
– 1x 56-pos connector (non Amiga 500 compatible)
– 1x 18-pos IC-connector for optional Real-Time Clock (MSM6242B) (Included)
Important!
These products are sold as-is and I take no responsibility for any damage caused by for example ESD or other circumstances. Since it is a hobby of mine the subject is not included with warranty. Items are only shipped as tracked and insured.
Possibly interested in 1st board
2 questions please
a)What is the MAIN difference between these boards ? THE OCS - ECS ?
b)Can they work with terrible fire ? Or Vampire ? Or Indivision ECS ?
1) ECS has support for hires etc, read more here and the custom chip is abour 45€ to buy, hence the higher price.
2a ) I have used it with Terribe Fire (old 2MB version) without any problems.
2b ) A few are using it with Vampire 500.
2c ) Indivision ECS works and also ScanPlus ECS (but if used with accellerator you might need a raiser).
Possibly interested in one. Will send PM if Puppetmaster doesn't buy them both.
Do you also have any of the addons? Or can I install my vampire on it easily?
It would fit nicely in my old Hush Silent PC case :)
Sorry missed that you already confirmed it works with a vampire :)
What kind of cable would I buy for the DB15 audio video connector? Just doing some research in case I would end up first in line :)
There is some sort of card at the far right of the supplied pictures.
May I ask, what is the slot for and what is the card?
Thank-you.
@ProfPlum: I'm not quite following you here. The card mounted on the right of Amy is the ChipMemory module, slots on Amy is Zorro2 slots and the card to the upper left, just behind the monitor is a RTG card for Amy.
