Results 1 to 3 of 3
Thread: Adapter for TL866 Minipro EPROM Programmer 27C322 27C160 27C800 27C400
  1. #1
    Kulamario123's Avatar
    Feb 2019
    Ireland
    Wicklow
    Age
    40
    7 (100%)
    Default Adapter for TL866 Minipro EPROM Programmer 27C322 27C160 27C800 27C400
    I have for sale Adapter for TL866 and TL800II Plus Minipro EPROM Programmer
    Available 4pcs
    This Adapter working with all revision TL866.
    Programming adapter supporting 27C322 (4Mx8-bit), 27C160 (2Mx8-bit), 27C800 (1Mx8-bit) 27C400 (512kx8-bit) parts.
    Converts the mask- EP- EEP- ROM pinouts of the above parts to the JEDEC pinout of 27C4096 EPROMs (as supported by TL866 USB programmer, and possibly other cheap programmers too). The TL866 programmer is supported through its MiniPro software by selecting '27C4096' device and disabling 'Check ID'. You may also like to reduce VPP Voltage to 12.50V (check your device data sheet).
    Since the TL866 has only a 40-pin programming socket, the extra address pins on 27C800 27C160 are configured manually
    Each adapter is checked before shipment.
    If you cannot program the memory, this is not the adapter's fault.
    It could be the fault:
    - damaged memory
    - insufficiently cleared memory
    - defective programmer
    - etc.
    Price what I want to get is 25 euro include postage to worldwide
    Pay via paypal like for friends or family members
    Or if I'll be pay for goods buyer must add 7% extra
    https://drive.google.com/folderview?...5O8EisSnDJtVvy
  2. #2
    XLV2K's Avatar
    Sep 2012
    Attiki
    5 (100%)
    The Tl866II Plus only supports up to 18V Vpp, doesnt it? and the 27C800 EPROMs need 21V Vpp .. does this adapter adapts the Vpp too, to the needed levels, when used with the TL866II Plus?
  3. #3
    Feb 2019
    Ireland
    Wicklow
    Age
    40
    7 (100%)
    Dnt know
    I use this for 27C400
  1. Replies: 17
    Last Post: 28th November 2019, 19:17
  2. Replies: 6
    Last Post: 3rd October 2019, 15:43
  3. Replies: 13
    Last Post: 30th December 2018, 06:16
  4. For Sale Eprom burner adapter for 27C400 / 27C800 / 27C160 / 27C322
    By piemmeweb in forum Other
    Last Post: 5th April 2018, 16:08
  5. Closed EPROMs: 27c400, 27c800, 27c160, 27c322
    By Jazzmarazz in forum Found Archive
    Last Post: 22nd June 2013, 23:28
Tags for this Thread
