Results 1 to 2 of 2
Thread: Cannot boot CD32 TF330 with PIC chip removed from Kipper 2K riser?
  1. #1
    AlexC1981's Avatar
    Mar 2019
    Essex
    Age
    38
    1 (100%)
    Default Cannot boot CD32 TF330 with PIC chip removed from Kipper 2K riser?
    Hi All,
    I wonder if you could help me please?
    I have a TerribleFire TF330 installed in my CD32 via a Kipper 2K riser that I bought here. A PC keyboard works fine through the PS/2 socket on the Kipper riser, but I recently bought an Amiga 500 keyboard in a case that I want to use in the CD32's AUX port.
    I read that if you remove the PIC chip from the Kipper riser you can use the AUX port again. Unfortunately the CD32 will not boot when I remove the PIC chip. I found one or two other notes online where people had the same setup as me and they could remove the PIC chip to disable the PS/2 socket on the riser and this didn't cause them any problems.
    I thought maybe I had done something wrong when I wired up the PS/2 lead to the A500 keyboard, but it will not boot regardless of whether or not I have my A500 keyboard plugged in.
  2. #2
    AlexC1981's Avatar
    Mar 2019
    Essex
    Age
    38
    1 (100%)
    Sorry!
    It's all working fine now. Not sure what happened, perhaps I didn't reinstall the card properly when I took it out to remove the PIC.
    The other good news is that my Amiga 500 keyboard is working perfectly that I wired up using a PS/2 lead from an old PC keyboard.
  1. Replies: 273
    Last Post: 28th May 2020, 00:11
  2. Wanted Kipper 2k riser PCBs - Amiga CD32
    By Retroheaven87 in forum Amiga
    Last Post: 6th July 2019, 15:34
  3. TF330 wont boot - any advice?
    By fitzsteve in forum AmiOracle
    Last Post: 1st April 2019, 19:54
  4. Closed Kipper A508 fastmem board with CPU riser
    By DesktopDynamite in forum Found Archive
    Last Post: 7th March 2017, 19:58
  5. Replies: 11
    Last Post: 27th October 2016, 21:35
Tags for this Thread
