Hello! Getting around to flashing the tf535 for the a2000 fix. Confirming the firmware on the exxos forum is the newest (r2 from 8/2). Got it from there as github tf area has been largely deleted of recent binaries by stephen. Also confirming you need to have it in the amiga and powered up while connected to the xilinx platform cable. I see a pwr2 connector on the board and wondering if I can use that instead at 5v? I could probably figure out the jtag1 header but can you confirm what port on the xilinx programmer plugs into each jtag pin also? Dont want to mess it up. Thanks for any info.
