Results 1 to 9 of 9
Thread: Amiga CD32 - CXA2075M Modification
  1. #1
    Cassius1979's Avatar
    Jun 2013
    Cheshire
    16 (100%)
    Default Amiga CD32 - CXA2075M Modification
    Hi, has anyone experience with completing the above modification Iíve ordered the chip and resistor and read the schematics, can anyone point to which resistors and caps will require removing from the board prior to installing the CXA2075. Thanks.
  2. #2
    supaduper's Avatar
    Sep 2012
    west midlands
    350 (100%)
    Hi Bud, I have done this mod and you can remove the 4 square filter cans and some resistors, on my A600 I just removed the R221 and R223 resistors
    incase you have not seen the website where this fix was shown, here it is , there are some pics on what components to remove
    https://www.ikod.se/cxa2075m/
  3. #3
    Jun 2013
    Cheshire
    16 (100%)
    Cheers pal, that pretty much matches up to what I can see on the schematics but the extra diagrams for which capacitors to remove are a great help, I’ll be in touch in a few weeks
  4. #4
    Amibayer! Seaside's Avatar
    Jan 2010
    Athens
    56 (100%)
    Question guys.
    On game consoles that are equiped with 1145 chip can someone use the 2075M ?
  5. #5
    Starvak-Sp's Avatar
    Mar 2018
    Spain
    Huelva
    5 (100%)
    Wow. This is very interesting!
    But there is only information for the a1200 on the url signed.
    Can any detail which components to remove on A600 and cd32?
    For a600 R221 and R223 is named clear, but which capacitor? Cxxx
    Cheers.
  6. #6
    supaduper's Avatar
    Sep 2012
    west midlands
    350 (100%)
    Quote Originally Posted by Starvak-Sp View Post
    Cheers.
    Ask GoOse here, as he has done the mod on the CD32
    https://www.exxoshost.co.uk/forum/me...wprofile&u=415
    Hey Seaside
    I can`t answer that as I have never tried another game console but I cannot see why it will not work as it must be the same circuitry
  7. #7
    sean_skroht's Avatar
    Oct 2016
    South Australia
    2 (100%)
    I have tried this modification on an A1200 rev. 2B motherboard because of Z221 and Z222 failing and, while it does work, I have found that the CXA2075M gets very hot to the touch, as in, you can't leave your finger on it for too long. Has anyone found the same? Also I thought the picture was no where near as good as the original CXA1145M. I had a lot more of the spider effect around edges of objects through composite video with the CXA2075M than the original chip. Would love some feedback from others who may have tried this mod. Thanks guys.
  8. #8
    supaduper's Avatar
    Sep 2012
    west midlands
    350 (100%)
    I have done this on my A600 and it does not even get warm, and the picture is better with the CXA2705M but it is composite, so you have the 2.61k resistor on the chip too ?
  9. #9
    Oct 2016
    South Australia
    2 (100%)
    Yeah I have the 2.61k resistor connected properly. The chip gets insanely hot. Im wondering whether its a fake. I ordered 5 of them very cheaply on ebay. The first one i fitted didn’t produce a picture at all and was also stupidly hot, second one I fitted did produce a picture (albeit not as good a picture as the CXA1145M) and that is also very hot. Don’t want to have to keep fitting too many on there as I could eventually lift the pads due to heat stress.
  1. Replies: 0
    Last Post: 1st October 2017, 02:38
  2. Curious Amiga 1200 floppy connector modification....
    By voyager_1701e in forum AmiOracle
    Last Post: 9th March 2014, 14:41
  3. Request 360 modification
    By BamberO in forum Services
    Last Post: 1st March 2013, 01:02
Tags for this Thread
