Results 1 to 1 of 1
Thread: Amiga 4000 Repaired!
  1. #1
    johntayloruk's Avatar
    Feb 2019
    West Yorkshire
    Age
    40
    3 (100%)
    Default Amiga 4000 Repaired!
    Hey, just thought I'd do a post for a project I've been working on thanks to having lots of time with the lockdown.
    I bought a non-working Amiga 4000 Motherboard on ebay, it was filthy, corrosion on many of the resistors, the battery had gone to work and had eaten its way through to the rear. I didn't want to even turn it on in the state it was is so I gave it a clean with white vinegar and IPA (my word the amount of fizzing and fishy smell...yuk ).
    Anyway, I've had an ultrasonic bath I've been wanting to try for a while so I removed the caps and socketed chips and gave it a good soak. It came up like new and I could then see what I was faced with...
    U177 (74HCT174) had pretty much been eaten away, hardly any pads remained and there were traces broken all over the place., particularly around the memory sockets going through the vias to the underside of the board.
    The traces from the row of resistors around R982 to the jumpers at J975 were completely broken and had to be repaired.
    The F245 chip at U891 had also been damaged and had to be replaced. Again that fishy smell when you get underneath...yuk!
    Anyway....after many hours testing traces, re-flowing most of the board, replacing the caps and adding new simm sockets I turned it on and.....it only worked! I was so happy to see that WB 3.1.4 screen/ I did a full check with Chucky's Diagrom and all was ok. I used some solder mask to cover things and to secure some of the connections in place (probably too much), but it's working fine now!
    I've had 10 of Chucky's A3660 boards made up so my next job is to put one together and then likely look to sell this as I have another original A4000 as well as a new one I've just made up!
  1. Sold Commodore Amiga A500 1MB - Repaired and Refurbished
    By TheCorfiot in forum Amiga
    Last Post: 29th July 2016, 11:18
  2. Sold Commodore Amiga A500+ Repaired and Refurbished
    Last Post: 13th July 2016, 21:29
  3. For Sale Amiga monitor switch - to be repaired
    By Kris in forum Amiga
    Last Post: 3rd February 2016, 10:41
  4. Filled Amiga 4000 rev B motherbroad needs to be repaired
    By awmosoft in forum Services
    Last Post: 2nd September 2014, 19:11
  5. Sold Amiga 600 motherboard REV 1.5 fully recapped and repaired
    By kaini in forum Sales Archive
    Last Post: 21st July 2014, 12:47
Tags for this Thread
