Results 1 to 3 of 3
Thread: Amstrad CPC 6128 with PSU + SCART video + audio cable; FDD does not work
  1. #1
    evrieze's Avatar
    Jun 2018
    Netherlands
    Brainport Eindhoven
    0
    Default Amstrad CPC 6128 with PSU + SCART video + audio cable; FDD does not work
    A partially defective Amstrad CPC6128 computer (Computer works, FDD failed).
    The computer starts and works normally, except for the floppy disk drive. Reading and writing to the floppy disk is not possible, and disk commands always produce an error message.
    This computer does not need an Amstrad monitor but is modified so that it can be connected to a normal television using the SCART (PERITEL) AV input. The picture is clear and sharp, and sound plays on the TV as well.
    A suitable power supply and the SCART connection cable are included.
    The external switching power supply provides 12 Volts and a maximum of 3 Amps. More than enough for this computer and a possible extension with an external floppy disk drive.
    A step-down controller is built into the computer that reduces the 12 Volt from the power input to 5 Volt for the main board.
    Optionally, I can send a 3.5 inch floppy disk and parallel connection cable with the other items ( + EUR. 10,= ).
    Price = 262 euro + P&P ( 12 euro to UK, Belgium, Germany and the Netherlands )
    Currently, this computer is offered on the second most popular auction site in Germany also (hood.de)
    Payment by bank transfer.
    Attached Thumbnails Attached Thumbnails P_20200627_173754.jpg   P_20200627_173809.jpg   P_20200628_153221.jpg   P_20200627_171859.jpg   P_20200627_171559.jpg
    P_20200627_171705.jpg   P_20200628_153646.jpg   P_20200628_153556.jpg   P_20200628_153358.jpg
  2. #2
    Amiga - The Survivor miggymad's Avatar
    Aug 2019
    Hitchin
    35 (100%)
    You need to add a proof of ownership picture, as per the rules
    If you have a post count of less than 50 and/or a feedback score of less than ten then you will be expected to provide proof of ownership for items of a value of 50 or more.
    This is to be in the form of a photo of the item with a piece of paper showing the forum name, your forum name and the date the item is listed For Sale.
    Amiga A1200 - Vampire V4 SA X3 - PC Engine Everdrive - C64 SD2IEC
  3. #3
    evrieze's Avatar
    Jun 2018
    Netherlands
    Brainport Eindhoven
    0
    Required proof of ownership added on 28. June 2020
    These pictures are also visible on : https://ibb.co/album/wB7DFf
  1. For Sale 2x Amiga Video/Audio to SCART cable (1 defective)
    By SunDown79 in forum Amiga
    Last Post: 17th February 2018, 19:11
  2. Replies: 0
    Last Post: 16th February 2016, 08:55
  3. Replies: 5
    Last Post: 30th August 2013, 15:44
  4. Replies: 82
    Last Post: 19th August 2013, 19:57
  5. Wanted AMIGA RGB VIDEO/AUDIO SCART CABLE 1.1M 5-feet A1200
    By WeiXing3D in forum Amiga
    Last Post: 8th May 2013, 03:24
Tags for this Thread
