Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: How towerize an Amiga 3000D motherboard!
  1. #1
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    109 (100%)
    Default How towerize an Amiga 3000D motherboard!
    Hello,
    i was looking for years for a solution for my A3000D motherboard (to housing it!).
    Months ago, i have found, near a trashcan, on a street, an ATX case with some IDE devices.
    I have picked up all this good. The devices, as ever, i have played with it on my IDE card...and the Tower?
    Now, if you are experienced about this matter, you know that, for an A3000D motherboard, there is no room on an ATX sized case! You will be frustrated, even if the motherboard can be put in some position, no room at all for cpu card and/or Zorro board.
    A week ago, just because i need to move, and i wish absolutely to take with me my motherboard, i have resurected the tower. Obviously nothing has changed from when i have tested the usability of it, months ago.
    Anyway i have found the solution...the solution is...made it higher (or taller, call it as you wish)!
    Look!
    I have forgotten to picture it on the original state. Anyway it was smaller...
    and now it looks in this way
ID:	158432 Click image for larger version.
ID:	158433 Click image for larger version.
    After some heavily modification, the motherboard and all the add-on (cpu card and Zorro boards) need to fit properly on this new modded tower
ID:	158435 Click image for larger version.
ID:	158436 Click image for larger version.
ID:	158437 Click image for larger version.
ID:	158438 Click image for larger version.
    ...to be continued...
  2. #2
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    109 (100%)
ID:	158507 Click image for larger version.
    The motherboard is settled down on six halters, three of them are screwed; the result is a very stable tower with the board strong fixed to the structure in metal and alu.
ID:	158509 Click image for larger version.
ID:	158510 Click image for larger version.
ID:	158545 Click image for larger version.
ID:	158511 Click image for larger version.
    ...My first full length Zorro board...it is a fake, on rigid paper, just to test the position of the metal grid, to sustain the Zorro cards.
ID:	158513 Click image for larger version.
  3. #3
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    109 (100%)
    Hello,
    if you wish to donate for this project, i am looking for an A3640 and a graphic card. In not working state, please; it means, not used by you and destinated to be throwed into a trash.
    Thanks in advance!
  4. #4
    rcade's Avatar
    Jun 2008
    United States
    Augusta, Georgia
    49
    8 (100%)
    That's some really nice work. Unfortunately a lot of the charm of the A3000 is the original case design. If I was going to tower something I would probably just do an A500.
    Pete Rittwage
    C64 Preservation Project
  5. #5
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    109 (100%)
    Quote Originally Posted by rcade View Post
    ... Unfortunately a lot of the charm of the A3000 is the original case design...
    That's true! But my motherboard was without any desktop case...Anyway, new pictures!
    The CompactFlash-halter
ID:	158591 Click image for larger version.
ID:	158592 Click image for larger version.
ID:	158593 Click image for larger version.
    And the plate-solution to complete the rear...Look!
ID:	158595 Click image for larger version.
    Now, the hard part is to come...where my skill play the big role: to complete the front, with a solution with style...and the painting of the metal panels on the sides. I wish to do something new...will see.
    Ciao
    Stefano
  6. #6
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    109 (100%)
    Hello,
    the inner now look like this
ID:	158685 Click image for larger version.
    I have changed my mind and done a different visual effect for the metal plate of the rear
ID:	158687 Click image for larger version.
    You can do a comparison by yourself, against the rear of the A3000 Desktop case
    https://bigbookofamigahardware.com/b...3000_3_big.jpg
    ...and the original A3000 Tower case
    Now, a bit of explanation about this project: it is more or less an improvisation; ideas come, i evaluate it and then, i try to realize it.
    Sadly, i haven't access to a complete tool to manage metal plate, so my works look a bit raw; anyway i feel that the design is good...and this is the most important part!
    Ciao
    Stefano
  7. #7
    Retrograde's Avatar
    Jul 2010
    Gothenburg, Sweden
    Vastra Gotaland
    43
    12 (100%)
    Damn, that's actually pretty cool!
    The original case looked like a bad fit.... but with a lot of work, i turning out nicely!
    Amigas: #A500+, 1MB #2xA1200, 8MB RAM, #MS: XBOX (latest)
    C64s: #C64/C, 1541C/-II, w. AR-IV and 2 Red Balls
    Segas: #Megadrive, Everdrive, Arcade Stick #Dreamcast, VGA (shmup station)
    Sonys: #PS1 #PS2+80GB HD #PS3, Hori Arcade Stick
  8. #8
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    109 (100%)
    Hello,
    ok, thanks for your interest on this thread!
    New pictures of the inner part
ID:	158717 Click image for larger version.
    Now the rear looks like this
    Ciao
    Stefano
  9. #9
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    109 (100%)
    New pictures! Now the front is complete! Look!
ID:	158922 Click image for larger version.
ID:	158921 Click image for larger version.
ID:	158923 Click image for larger version.
    A look inside the Card halter (Zorro cards)
    Now painting work! I will use DPaint to sketch a solution for this tower...see you soon...
  10. #10
    vibros's Avatar
    Sep 2009
    Italy
    Emilia-Romagna
    109 (100%)
    A picture like this, with low light, shows well the shape of the new design of the front...done absolutely with recycled parts!
    ...and powered on...
    And last but not least, for fanatics of LEDs, a bit of them on a fan inside the tower case.
    Ciao
    Stefano
  1. Sold Amiga 3000D motherboard
    By Assahi in forum Sales Archive
    Last Post: 22nd July 2020, 08:09
  2. Sold Amiga 3000D motherboard 9/03 faulty
    By Assahi in forum Amiga
    Last Post: 17th June 2020, 08:16
  3. What do I need to towerize my a1200
    By CrazyC in forum AmiOracle
    Last Post: 25th January 2020, 23:00
  4. Closed Amiga 3000D working motherboard + db + one MB for spare
    By Sveta in forum Sales Archive
    Last Post: 28th May 2013, 16:35
  5. Sold Amiga 3000D motherboard (faulty)
    By lopos2000 in forum Sales Archive
    Last Post: 3rd October 2012, 09:22
