Page 1 of 3 123 LastLast
Results 1 to 10 of 50
Thread: Amiga Video Adapter - RGB to VGA SVGA (BUFFERED) with DB23 ORIGINAL - PCB INSIDE!O_o
Hybrid View
  1. #1
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    26 (100%)
    Default Amiga Video Adapter - RGB to VGA SVGA (BUFFERED) with DB23 ORIGINAL - PCB INSIDE!O_o
    ...The best Amiga RGB-VGA adapter on the WEB..with original D-SUB DB23 female
    This is the ONLY VIDEO ADAPTER realized on PCB board (buffered) and with ORIGIANL DB23 Female : no DB25 cutted!
    >>> ...take your time and check all the pictures...check the real and original DB23 PIN <<<
    ADAPTER FEATURES
    1) D-SUB DB23-pin female (ORIGINAL COMMODORE) to DB15-pin HD female.
    2) All connection realized with high quality PCB (no wired!)
    3) Backshell cover adapter is DB25-DB15
    4) Buffered/unbuffered option available
    DESCRIPTION
    This adapter allows you to connect a VGA/SVGA* or Multiscan monitor to your Amiga RGB port.
    This is fully buffered for Commodore-Amiga 500, 500+, 600, 1200 or "big box" Amiga systems (not Amiga 4000 because back cover shell DB23 is needed).
    This adapter allows you to use the following display modes:
    • DBLPal
    • DBLNTSC
    • Euro 36Hz and 72Hz
    • Super72
    • Multiscan/Productivity
    • VGA Only
    IMPORTANT NOTE:
    *SVGA monitor must be able to sync the Amiga's 15Khz signal (most CRT monitors have no problem doing this). Some LCD monitors such as DELL U2410 or BENQ BL702A sync down and support 15Khz- check your monitor specifications for more information.
    If your monitor does not support 15KHz, then you will not get a picture until the software drivers are installed and workbench is loaded.
    PRICE with Paypal friend
    Buffer option --> 21€ --> 15€
    No Buffer --> 19€ --> 14€
    SHIPPING PRICE
    EU: 5,50€
    Worlwide: 7,50€
    With Paypal traditional +6% on total amount for fees
    Other items available for Amiga
    DB23 Female connector for RGB port
    http://www.amibay.com/showthread.php...-New-old-stock
    @Update 9 October 2020
    New Cover shell available...I like it!
    Check the last picture in order to compare NEW Vs OLD
ID:	161354Click image for larger version.
ID:	161355Click image for larger version.
ID:	161356Click image for larger version.
ID:	161357Click image for larger version.
ID:	161358Click image for larger version.
ID:	161359Click image for larger version.
ID:	161360Click image for larger version.
ID:	161361Click image for larger version.
ID:	161362Click image for larger version.
  2. #2
    jvidia's Avatar
    Oct 2011
    Portugal
    Cascais
    70 (100%)
    What's the difference between buffered and unbuffered?
    Commodore A-500 + PHILIPS CM 8833 | ATARI 1040 STFM + PHILIPS CM 8852 | BENQ ​BL912
  3. #3
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    26 (100%)
    Quote Originally Posted by jvidia View Post
    Hi
    As you can see from the picture one and two...the first has IC on board...the second picture is without IC
    Anyway buffered is necessary for big box Amiga
    Unbuffered version is enough for Amiga 500/600/1200..but if you want you can use also the buffered version
  4. #4
    Technoid's Avatar
    May 2016
    Sweden
    Södermanland
    42
    8 (100%)
    Since I was for a long time wondering what the electrical diff was : the buffered version runs the rgb twice through the 74 chip flipping the signal twice and through that "bosting" the signal strenght since the 74 chip is powered by the rgb ports +5 volt pin.
  5. #5
    jvidia's Avatar
    Oct 2011
    Portugal
    Cascais
    70 (100%)
    Quote Originally Posted by Technoid View Post
    Buffered results in a better image quality?
  6. #6
    deetsay's Avatar
    Nov 2012
    Finland
    Säynätsalo
    44
    34 (100%)
    Interested in 2x buffered version!
    tero
  7. #7
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    26 (100%)
    Quote Originally Posted by deetsay View Post
    PM sent..payment received and items shipped this morning.Thanks again
  8. #8
    oldman1000's Avatar
    Nov 2011
    holland
    den haag
    92 (100%)
    Interested in one
  9. #9
    axel81's Avatar
    Jan 2020
    Italia
    Monza Brianza
    26 (100%)
    Quote Originally Posted by oldman1000 View Post
    Interested in one
    PM sent
    PM sent
  10. #10
    Interested in 1x buffered version!
  1. For Sale Amiga DB23 Video port to Components (YPbPr) adapter
    By Nitz76 in forum Amiga
    Last Post: 29th January 2020, 14:04
  2. Replies: 0
    Last Post: 24th February 2019, 02:49
  3. Wanted Amiga 500 DB23 to S-Video converter NTSC (USA)
    By naveed in forum Amiga
    Last Post: 8th July 2013, 07:24
  4. Found Amiga 1084s video cable DB23 => DB9 M
    By jcarvalho in forum Found Archive
    Last Post: 17th October 2012, 08:16
  5. Closed Amiga 1084s video cable DB23 => DB9 F
    Last Post: 9th October 2012, 15:33
