Results 1 to 4 of 4
Thread: Apollo 1240 crystal oscilator
  1. #1
    uplink2's Avatar
    Nov 2017
    United States
    NH
    0
    Default Apollo 1240 crystal oscilator
    I've recently moved and when setting up my Amiga 1200 I found that the crystal oscillator for my Apollo 1240 accelerator had gotten knocked out of the socket, had bent pins and now the 1200 will not boot at all with it installed even with just a workbench disk. I tried it in another 1200 and still no joy. I then tried removing the board and the 1200 then boots fine. It had all been working before I moved. I suspect that the crystal oscillator got damaged somehow in the move.
    The oscillator is a 3XO 12C 56 mhz oscillator. I can't seem to find a US source for it and the German company that has them listed for sale doesn't allow me to create an account from outside the EU as those are the only countries listed to be able to set up an account. I will continue to check anywhere in the US.
    Any thoughts on where I can find one as they are cheap and it seems likely it got damaged based on how I found it when I opened it up? The battery is just starting to leak but it hasn't gotten to the board yet. I plan on removing that.
  2. #2
    Forza GVP NoPyroNoParty's Avatar
    Dec 2015
    Finland
    Helsinki
    137 (100%)
    The 56mhz oscillator slightly overclocks the 25mhz cpu onboard to 56/2 = 28mhz. You can try any dip 14 oscillator in the range 50-60mhz. Remove the battery asap and meanwhile neutralize the current leak with vinegar and IPA as it will corrode it quickly.
  3. #3
    Vabis's Avatar
    Apr 2013
    Iowa
    54 (100%)
    PM sent
  4. #4
    mpattonm's Avatar
    Jul 2017
    Czech
    VC
    9 (100%)
    You can also have one custom made: https://centuriontech.eu/product/customized_oscillator/
    Choose CMOS output type, 5.0V power voltage and enter frequency you desire (i.e. 56.00)
  1. Wanted Accelerator card Blizzard 1240 or Apollo 1240
    By bobymiller in forum Amiga
    Last Post: 7th February 2018, 10:02
  2. Wanted Apollo 1240 and Blizzard 1240 vs 1260
    By Turican in forum Amiga
    Last Post: 31st July 2016, 21:47
  3. Closed Want to buy (14pin DIL) Crystal Oscilator ~ 72Mhz
    By liviux76 in forum Other
    Last Post: 15th August 2015, 12:37
  4. Found 50 - 80 Mhz Crystal Oscillator for Apollo 1240
    By dougal in forum Found Archive
    Last Post: 30th December 2011, 16:31
  5. Closed 100Mhz crystal wanted for my Apollo 1240
    By AmigaNut08 in forum Found Archive
    Last Post: 19th June 2009, 11:16
Tags for this Thread
