Page 18 of 18 FirstFirst ... 81415161718
Results 171 to 174 of 174
Thread: Mystery hardware Pr0n project
  1. #171
    Beegle's Avatar
    Feb 2014
    Canada
    Quebec
    3 (100%)
    Wow, this thread is perfect. Good job.
    The more ISA sound cards, the better.
  2. #172
    Time to finish it...
    What if you glue the buttons you already made to a piece of rubber that is fastened inside the top shell? You could have letters and symbols printed as stickers and glue these on, maybe some clear coat to keep them nice over time.
  3. #173
    RETRO Nuts spanner's Avatar
    Mar 2012
    London
    Age
    49
    4 (100%)
    Quote Originally Posted by Elerion View Post
    I sent an RFP for printout of the V2 of the case in Laminated Object Manufacturing (LOM) technology.
    Different from what I originally planned, but much cheaper then SLS, Objet or stereolitography printout.
    V2 of the case have several improvements:
    - Keyboard was completely redesigned. Each key is now printed separately, to ensure 100% functionality.
    - I increased the size of the engraved letters on the keyboard. Previous ones were too tiny for 3D printing. With some luck these should be big enough to be visible.
    - DTV board was a tight fit, so I added a 0,25 mm for DTV board place.
    - I found that SD2IEC reset button would come quite handy (actually to quickly return to root directory of SD card) so I added another button to right side of the case.
    - Increased the slot for SD cards, so fat SD adapters can fit.
    - Returned to original idea of having separate led's for drive operation, so this model has 2 leds on the right side of the keyboard.
    We'll see what happens.
    Here is a pair of crude renderings of the model:
    Very nice work,I wish I had a 3D Printer now...
    I am moding mine at the moment but need some help..
    Here are some questions..
    1.) Can you show the bottom of the main board so I can see how you soldered the IEC connections please.
    2.) What power supply do you use I have a 5v 2.5A and the led comes on but don't power it,I have a 6v 800mA and it works fine,now if i power my keyboard with the 6v power supply will it blow it..?
    Here is mine still working on it..
    http://youtu.be/rFdugtgUAPs
    http://youtu.be/vzE1adcGLlc
    More vids soon
    [SIZE=1]A600 A1200,A500,CD32,C64 in C case,C64 Compact,SD2IEC and UK1541,C64DTV,[/SIZE]Atari VCS,Atari 800XL/130XE,1010,1050,[SIZE=1]Atari 520STFM,Acorn Electron,ZX spectrum,ZX Spectrum X2+2.Mattel Aquarius,Sega Mega Drive/CD1 and 2,Sega Saturn,Dreamcast,Sony PS Original x2,Action Reply card for PS,PS1 White,PS2 Slim x2,PS3 x2,PS4,PSP Fat,SP Vita,Xbox Original,Xbox360 Siim x2,NDSL,NDSiXL Mario,3DS,2DS.[/SIZE][SIZE=1]
    [/SIZE]
  4. #174
    Hook up IEC:
    http://www.richardlagendijk.nl/cip/a...g_the_dtv_2/en
ID:	75729Click image for larger version.
    Also: http://www.pitsch.de/stuff/c64dtv/C6...lderpoints.jpg
    Why not put two diodes in series with the 6V in case you're worried about the keyboard, you'll get at least 1V voltage drop over these.
    More help:
    http://www.pitsch.de/stuff/c64dtv/index_en.htm
    There hasn't been much action here for a while... good luck with yours.
  1. Hardware Pr0n II: An Amiga 3000 Story
    By AndyLandy in forum Photo Booth
    Last Post: 13th May 2018, 23:30
  2. Blizzard Vision Hardware Pr0n!!!
    By fitzsteve in forum Photo Booth
    Last Post: 5th December 2010, 22:12
  3. A1000 hardware pr0n
    By salaxi54 in forum Photo Booth
    Last Post: 4th December 2010, 12:03
  4. Sold VLab + mystery videoslot card
    By cv643d in forum Sales Archive
    Last Post: 13th November 2010, 16:41
  5. Hardware Pr0n: An Amiga 2000 Story
    Last Post: 20th June 2010, 21:05
Tags for this Thread
