Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Large Hard Drive Installation
  1. #1
    Positively negative VIP
    Amibayer!
    Justin's Avatar
    Sep 2008
    Cheltenham UK
    Cheltenham
    142 (100%)
    Default Large Hard Drive Installation
    Good morning all,
    Right then, as some of you may know I had some real problems installing some large hard drives (above 60gb) I had write errors, wrongly reported drive sizes, overlapping disk writes and failiures all over the shop, I changed from SCSI to IDE and was still having the same issues.
    the problem seems to stem from the A4000 3.1 roms having an NSDPatch issue, changing block sizes and RDBs make no difference, so here is what I have learnt, I hope this can save someone else weeks of pain.
    Stage 1: WinUAE
    1. Load Winuae with the same spec as your target Amiga
    2. Setup a HDF with the name DH0
    3. Install your OS (I used OS3.9 and will refer to this OS from now on) remember to also install Boing Bags 1 and 2.
    Stage 2: Download Time
    4. Leave Winuae and go and download classicWB from http://classicwb.abime.net
    5. Download NSDPatch from http://aminet.net/package/disk/misc/NSDPatch43_20
    6. Unzipped the classicWB file to somewhere you will remember!
    Stage 3: Back to WinUAE
    7. Start Winuae with your OS3.9 HDF and add your newly unzipped classicWB HDF to the hard drive list and boot.
    8. On the desktop you should now have an icon to install classicWB, hit that bad boy up, follow the on screen prompts and install.
    9. Once it has installed, press F12 and remove your HDF leaving just the classicWB HDF and reboot winuae (look at your pretty shiney new classicWB install, nice isn't it?)
    10. Now go and unzip the NSDPatch and install the fella. Once done exit out of Winuae.
    Stage 4: Getting the Harddisk On
    11. Hook up your new monster real HDD (SCSI or IDE)
    12. Start Winuae and add your real hard drive to the hard drive list and boot
    13. Open HDTools and find your real hard drive, install the drive and watch in awe as it finds your hard drive with the correct size and more importantly the correct geometry Partition the drive as you see fit, under the advanced tab select add/change filesystem, in the new window scroll down till you see SmartFileSytem, select it and then USE, now on each partition change the filesystem to CHF/00.
    14. Save and Reboot
    Now hopefully your workbench will now have some ghosted out uninitialised drives
    Stage 5: Formatting the Drives
    16. Using the SFSFormat Command in Shell/CLI - the SFSFormat has the following syntax -
    Code:
    sfsformat DEVICE <device mount name> NAME <volume name>
    so when you open a shell and type
    Code:
    SFSFORMAT DEVICE SDH0: NAME AmigaOS
    the volume name can be anything like Games&Demos or MrFudgleStick - clearly use your own names in place of SDH0: and System. Do this for each partition, it should only take a few seconds per partition and now all your partitions should be available
    *Remember to include the ":" at the end of the <device mount name>
    6. Cloning the existing System
    17. Now for the fun bit, after a reboot we are going to use COPY command to clone the existing WinUAE HDF and put this onto the newly formatted Harddrive
    the copy command has the following syntax -
    Code:
    COPY <source device/volume> <switch> <destination device/volume>
    so after a reboot, open a new shell and type the following into SHELL / CLI
    Code:
    COPY DH0: ALL SDH0:
    in the above example we are using device names -
    DH0: = the WinUAE HDF of ClassicWorkbench 3.9 we have setup earlier
    SDH0: = the large SCSI/IDE harddisk that we setup earlier as well
    so with your endevor use your own device/volume names in place of HD0: / SDH0:
    after typing out the line in shell/cli press enter and now watch the blazing speed as your HDF is transfered to your real hard drive.
    Stage 7: Testing Time
    18. Once completed press F12 remove the HDF from the hard drives list and leave your real hard drive there to boot (fingers crossed you have now booted classicWB from your real HDD)
    19. Move all your Apps, Games and Demos from your PC drives to where you want them on your Amiga hard drive, set everything you can up (WHLoad, IDEFix if you need it etc) run some files and test your new set up, all tickety boo? coolio
    20. Now when you are happy with your set up, chuck that bad boy into your miggy and bask in the glory and pride from your endevours and marvel at all that extra space.
    Official Amiga Walker
  2. #2
    Online Gangster Amibayer! fitzsteve's Avatar
    Aug 2009
    Sevenoaks, Kent
    Age
    39
    1013 (100%)
    Blog Entries
    2
    Nice, easy simple to follow steps, you're a jawsome dude
    1 Vote here for sticky
    My Website has moved to: https://fitzstevesamigaworld.000webhostapp.com/ It's now on Free Hosting to preserve the content.
    My YouTube Channel: https://www.youtube.com/user/fitzsteve
  3. #3
    Amiga user since 1989 Amibayer!
    Staff Moderator
    merlinkv's Avatar
    Oct 2009
    Spain
    Madrid
    Age
    55
    84 (100%)
    That's one of the ways m8.
    Simple & effective.....
    I don't know how it will be the third World War. But I do know how it will be the fourth: With sticks and stones.
    Here lies a brave, a formidable adversary and a true man of honor. Rest in peace. 04/21/1918
  4. #4
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    148 (100%)
    great guide mate
    A1200T 1d4:blizzard 1260/50/192mb/scsi kit:mediator 1200:radeon 9250:sb128:100mb net:spider usb clone:fastata-iv:amiga to ps2 mouse:80gb hd:zip100 ide:a4000 keyboard
    A1200D 1d4:blizzard1230mk4/50/64mb:indy mk ii:fastata mk ii:40gb*A1200 rev 2b*2 x A1200 1d4*A1200 1b*A600 2mb 4gb*A500
    PC:8700k@4.8ghz, Msi sli plus mobo, Corsair 32gb ddr4 3000mhz, Evga 1080ti ftw hybrid, Evo 970 m2 500gb.
    sfs cf guide http://www.amibay.com/showthread.php?t=19953 cwb3.9 guide http://www.amibay.com/showthread.php?t=20315 mediator drivers http://www.amibay.com/showthread.php?t=11993 p96 newres guide(radeon install) http://www.amibay.com/showthread.php...905#post325905
  5. #5
    I look like Gizmo Amibay Treasurer
    Mega AmiMod
    Administrator
    davideo's Avatar
    Jan 2008
    Boston, Lincs
    175 (100%)
    Quote Originally Posted by fitzsteve View Post
    I agree - now stuck
    @Juvvie
    Good guide mate
    Dave G
  6. #6
    Staff Moderator
    merlinkv's Avatar
    Oct 2009
    Spain
    Madrid
    Age
    55
    84 (100%)
    I also agree
    1 vote more....
  7. #7
    Amibayer!
    Justin's Avatar
    Sep 2008
    Cheltenham UK
    Cheltenham
    142 (100%)
    thanks guys, glad you like it
  8. #8
    Ya' Like it Retr0? VIP Zetr0's Avatar
    Nov 2007
    Age
    44
    137 (100%)
    @Juv
    glad to see you got some life out of it in the end (where was my PM?!) =D
    would be okay with you if I helped format the first post my friend?
    8)Flux Mastah' Zee8)
    50 L337 1'M W1R3FR4M3
  9. #9
    Amibayer!
    Justin's Avatar
    Sep 2008
    Cheltenham UK
    Cheltenham
    142 (100%)
    Quote Originally Posted by Zetr0 View Post
    @Juv
    fill yer boots m8
  10. #10
    Nov 2007
    Age
    44
    137 (100%)
    format complete - now needs some pictures =D
  1. Closed A500 Hard Drive
    By dabone in forum Found Archive
    Last Post: 10th November 2010, 12:04
  2. 4GB CF IDE HARD DRIVE www.amigakit.com
    By www_amigakit_com in forum AmigaKit.com
    Last Post: 18th July 2010, 22:32
Tags for this Thread
