[FONT=Arial, Helvetica, sans-serif]hi all who have mediators i dont know if you have seen this
[/FONT]
[FONT=Arial, Helvetica, sans-serif][FONT=Arial, Helvetica, sans-serif]mediator tools [/FONT]https://www.dropbox.com/sh/ymvzh0j4gniuju4/kA7go8Gnw6
http://web.archive.org/web/20040603201805/http://vgr.com/mediator/software3rdparty.shtml
[/FONT][FONT=Arial, Helvetica, sans-serif]http://web.archive.org/web/200312121...dication.shtml
Mediator Multimedia CD 2.1 [/FONT] [FONT=Arial, Helvetica, sans-serif]name[/FONT] [FONT=Arial, Helvetica, sans-serif]version[/FONT] [FONT=Arial, Helvetica, sans-serif]date[/FONT] [FONT=Arial, Helvetica, sans-serif]location[/FONT] [FONT=Arial, Helvetica, sans-serif]pci.library[/FONT] [FONT=Arial, Helvetica, sans-serif]9.6 beta [/FONT] [FONT=Arial, Helvetica, sans-serif]13 Dec 2010[/FONT] [FONT=Arial, Helvetica, sans-serif]Libs:[/FONT] [FONT=Arial, Helvetica, sans-serif]Starting from this pci.library in Mediator PCI 1200TX working in the MMU mode the part of the Radeon and Voodoo gfx card memory can be added to the Amiga 1200 system memory (like in the A3000 and A4000 computers). You can even use 250 MB of the Radeon memory as regular Amiga memory!
Use MedConfig (ver.1.9) to allocate the required gfx card memory to the Amiga system.
i have just got my radeon working on the first mediator1200 i hope this works with this
list of supported devices http://www.elbox.com/mediator_driver_guide.html
list of drivers http://www.elbox.com/downloads_mediator.html
list of versions of mediator http://buy.elbox.com/cgibin/shop?show=2BB
for any one having problems with sound use ghostmix
[/FONT]http://aminet.net/package/driver/audio/GhostMix
To Install GhostMix, follow the following steps:
1. Copy GMStart to c:
2. Copy GhostMix and GhostMix.info to Prefs
3. From a Shell, type "GhostMix SAVE" to save your current settings ready for use from the next reboot
4. Change the line in user-sequence that says "MIXER NoGUI QUIET" to "GMStart"
pci.library 9.7 21 Dec 2010 Libs:
FastEthernet.device 1.25 21 Nov 2010 Devs:Networks
Virge.card 1.13 27 Dec 2010 Libs
[/FONT]
Poseidon 4.4 stack
for spider put in Devs:USBHardware
install posiden 4.4
delete the devices in trident
open a cli and enter:
AddUSBHardware Devs:USBHardware/spider.device 2
AddUSBHardware Devs:USBHardware/spider.device 0
AddUSBHardware Devs:USBHardware/spider.device 1
it will then add 3 devices
2 for each set of ochi ports and i think the ehci high speed part
Mine is set to 8.
envarc:mediator/SpiderBuf
had to put it in the last slot 4 and needs to below voodoo/radeon to work
[/FONT]
[/FONT]
Poseidon 4.4 stack
install posiden 4.4
Mine is set to 8.
