Results 1 to 3 of 3
Thread: WANTED: Info and/or GVP HD8+ RAM
  1. #1
    10 PRINT "8 Bit Hero" VIP
    Amibayer!
    gazcbm's Avatar
    Feb 2008
    Manchester, UK
    Age
    40
    61 (100%)
    Default WANTED: Info and/or GVP HD8+ RAM
    Hi All,
    I am looking for a few simms to put in my GVP-hD8+ sidecar, if you have any spare let me know how much you want for them. Alternatively if somebody could shed some light on the exact spec that I should be looking for that would be equally just as good!
    Thanks in advance
    :Commodore: Computers: Plus/4 x3, C16, C64 x9, C64C x3, C64 Aldi, C64GS, C128 x3, C128D, C128CR!, SX64, Amiga 1200 - 8Mb GVP030 & 8GB CF, Stock 1200, Amiga 500, CD32 x2
    :Commodore: Peripherals:1541, 1541-II, 1570, 1571, 1581, 1541 Ultimate-II, Easy Flash, Dual SID, 1084s x4, ZoomFloppy, SD2iEC, Micro SwinSID, C64 NIC
  2. #2
    Ya' Like it Retr0? VIP Zetr0's Avatar
    Nov 2007
    Age
    44
    137 (100%)
    hello there
    The HD8+ takes 30pin simms, I belive i have 8x 1mb sticks of them, i will double check later, should that i do, you cn have them for £5 which will include postage
    heres some info on the card
    Impact A500 HD8+ Series II
    Company : Great Valley Products, USA
    Date 1990
    Amiga A500: Interface: side expansion port
    Autoconfig ID: 2017 / 10,11
    • Features:
      [list:13chkyik]
      * SCSI 2 DMA controller 3.58 MB/s transfer speed
      * FaaasT ROM SCSI driver (gvpscsi.device) - autobooting requires at least Kickstart 1.3
      * RDB compatible
      * place for a 3.5" hard disk inside the case
      * 50 pin internal header
      * DB25 external connector
      * supported by Linux
      * A-Max II driver (gvpscsi.amhd)
      * memory four 30 pin SIMM sockets accept 8 MB RAM
      * accepts 1 or 4 MB 120 ns SIMMs
      * supports 2, 4 or 8 MB configurations
      * fully autoconfiguring
      * notes connects to the side expansion port
      * has no passthrough connector
      * stylish design matches the A500
      * disable switch
      * hard disk activity LED
      * external power supply
      * built in fan
      * mini expansion slot for the optional PC emulator card
      * problems may arise with the combination of A500, 8372A Agnus and an internal memory expansion with CPU or Gary adaptor - a trace has to be cut to solve the problem
      for jumper settings see this linkie
    [/list:u:13chkyik]
    Hope this helps. PM me your details and i can hopefully get these memory sticks posted to you on Friday
    8)Flux Mastah' Zee8)
    50 L337 1'M W1R3FR4M3
  3. #3
    Amibayer!
    gazcbm's Avatar
    Feb 2008
    Manchester, UK
    Age
    40
    61 (100%)
    PM on its way! Thanks
  1. Info on running an A2091 on an A500
    By kjmann in forum AmiOracle
    Last Post: 16th March 2009, 17:15
Tags for this Thread
