Results 1 to 9 of 9
Thread: A3000 640x512 interlaced mode on PC VGA monitor
  1. #1
    Inactive Member
    Amibayer!
    SJBUK's Avatar
    Mar 2009
    Uk
    Hertfordshire
    49 (100%)
    Default A3000 640x512 interlaced mode on PC VGA monitor
    Folks,
    I've got my A3000 running fine at 640x256 but any interlaced mode is a real colourful mess on either of my PC monitors. No amount of manual monitor tuning seems to help. Am I pushing it trying to get interlaced modes working on a PC monitor or am I missing something?
    Running KS 37.175 and WB 38.12. Will KS/WB 3.1 help?
    Steve
  2. #2
    Repairer Extraordinaire Amibayer!
    Site Developer
    Administrator
    TheCorfiot's Avatar
    Mar 2008
    Wales
    Age
    53
    230 (100%)
    Default Re: A3000 640x512 interlaced mode on PC VGA monitor
    @SJBUK
    There's a little fine tuning pot adjustment near the VGA connector on the back panel which you need to adjust whilst displaying an interlaced mode.
    Be gentle, go slowly & listen for a clicking noise as this tells you you have reached one end of the pot & will need to adjust in the opposite direction. It is multiturn & will have a good few rotations from one end to the other.
    TC
    Ritchie Blackmore's Rainbow June 2016, I Was There
  3. #3
    Inactive Member
    Amibayer!
    SJBUK's Avatar
    Mar 2009
    Uk
    Hertfordshire
    49 (100%)
    Thanks TC. I've tweaked that and managed to get 640x256 nice and stable but any interlace mode is a real mess, not just tearing but severe sync and colour problems. Tried both a Dell and Samsung monitor with exactly the same result.
  4. #4
    Site Developer
    Administrator
    TheCorfiot's Avatar
    Mar 2008
    Wales
    Age
    53
    230 (100%)
    SJBUK
    Are you using a LCD or CRT monitor.
    You will find that the "Amber" flicker fixer still outputs at 50Hz in PAL mode which CRTs can cope with LCD's tend to not be able to go below 56-57Hz.
    test this by trying an NTSC interlaced mode (60Hz) such as 640x400 If that syncs OK then it's down to the LCD which I've a feeling is what you are using.
    These older systems really do function best with CRT's
    Even the new Indivision AGA performs much better with a CRT rather than LCD..
    Keep us posted
    TC
    edit --
    Check the link
    http://amiga.resource.cx/exp/search.pl? ... 0&company=
    You will find a manual & test utility disk here too... The A3000's Amber circuit is based on this card
  5. #5
    Inactive Member
    Amibayer!
    SJBUK's Avatar
    Mar 2009
    Uk
    Hertfordshire
    49 (100%)
    They are LCD monitors, no room really for CRT anymore!
    Thanks for the link, I'll give it a spin later if I get time and post the results
    chiark mentioned it might be a buffer problem and on reflection it does seem similar to problems I've had on faulty PC display cards (dodgy VRAM) in the past.
    Cheers,
    Steve
  6. #6
    Site Developer
    Administrator
    TheCorfiot's Avatar
    Mar 2008
    Wales
    Age
    53
    230 (100%)
    @Steve
    It's possible there is a fault as the Amber circuit works in 2 entirely different modes depending on whether it is de-interlacing & scandoubling or just scandoubling. The former being the most complex & full use of the circuit & the main reason for the tweaking.
    Mate I wish you all the best, the A2320 manual should give you a good understanding of the system function & does have some good troubleshooting tips, it is NTSC biased a bit (60Hz) just remember you are on 50Hz.
    Will be interesting to see if the LCD's display differently when the A3000 is outputing an NTSC 60Hz signal.
    Good luck
    TC
  7. #7
    Amiga fanboy Inactive Member
    Amibayer!
    rkauer's Avatar
    Dec 2007
    Age
    54
    110 (100%)
    IF you really want to use it on a lcd panel, then a good measure is using a LCD-TV! It will sync down to the desired 50Hz vertical refresh.
    16 Amigas at home :D
    3x C= 64 :smile:
    1 VIC-20 :smile:
  8. #8
    Inactive Member
    Amibayer!
    SJBUK's Avatar
    Mar 2009
    Uk
    Hertfordshire
    49 (100%)
    Bah, NTSC interlace is just as bad. Haven't tried any tests yet, haven't got any way of transferring from PC to Amiga sorted out yet. I'll stick a floppy drive in and give it a go.
    Piccie uploaded to PhotoBooth topic:- viewtopic.php?f=89&t=2085
    Have no room for any more displays so will have to get all my miggy's talking to the LCD's somehow.
  9. #9
    BANNED Kin Hell's Avatar
    Nov 2007
    U.K.
    Cornwall
    Age
    57
    48 (100%)
    @ SJBUK
    You might want to read here m8!
  1. A1200 video mode issues
    By RedDaemonFox in forum AmiOracle
    Last Post: 28th September 2009, 01:48
  2. Closed WTB: A500 Accel Must Have Switch to Go Back to 68K Mode
    By kjmann in forum Found Archive
    Last Post: 24th March 2009, 05:18
  3. Corrup A3000 interlaced display on LCD monitor
    By SJBUK in forum Photo Booth
    Last Post: 20th March 2009, 23:40
  4. Closed 17inch tft monitor
    By jimbob005 in forum Found Archive
    Last Post: 6th February 2009, 22:26
Tags for this Thread
