Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 77
Thread: Installing cwb OS39 with winuae from scratch
  1. #11
    HypnusBE VIP
    Amibayer!
    jvdbossc's Avatar
    Nov 2009
    Belgium
    Antwerp (province)
    Age
    42
    81 (100%)
    I like this, sharing stuff with ohers, to preserve The guide is great, and to the point, the way I like it..
    I have my own remarks hopefully they help out:
    You do not need a cdrom driver, just call a volume the same as the cdrom. It can even be a dir in winblows as long it is called the same as the os 3.9 cdrom. Same goes for 3,1 flops etc.. or assign.. The amiga does not care as long the volume name is right..
    There is no mentioning of picasso96 uae slowing down the install proces, aga emulation is very slow comparing to rtg... I would install uae rtg before so 3.9 to get nice graphics
    Copy the right files is also a method...There used to be a guide on google to do it that way, but it seems disapeared.. I think, not sure, if you copy the classic structure meaning workbenc 3.1 to ffs hard disk and then copy the same structure from os 3.9 it works
    these are just suggestions, I am very happy with the guide.
    Proud on the classics: A1000-A500-A2000-A600-030-A1200 PPC -A3000D(basic)-A4000D(060)
    Mac Mini 1.45 ghz 1 G RAM MORPHOS 2.6
    Pentium 3 1.4 ghz 512 sdram AROS
  2. #12
    Amibayer! Mendel's Avatar
    Feb 2012
    Finland
    kokkola
    50 (100%)
    This is awesome, I shall try this immediately!
  3. #13
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    147 (100%)
    i hope so mate it took ages to make
    any help needed just ask
    also i would follow my other guide for installing sfs on a real hardrive/cf to copy cwb3.9 to
    http://www.amibay.com/showthread.php?t=19953
    john
    A1200T 1d4:blizzard 1260/50/192mb/scsi kit:mediator 1200:radeon 9250:sb128:100mb net:spider usb clone:fastata-iv:amiga to ps2 mouse:80gb hd:zip100 ide:a4000 keyboard
    A1200D 1d4:blizzard1230mk4/50/64mb:indy mk ii:fastata mk ii:40gb*A1200 rev 2b*2 x A1200 1d4*A1200 1b*A600 2mb 4gb*A500
    PC:8700k@4.8ghz, Msi sli plus mobo, Corsair 32gb ddr4 3000mhz, Evga 1080ti ftw hybrid, Evo 970 m2 500gb.
    sfs cf guide http://www.amibay.com/showthread.php?t=19953 cwb3.9 guide http://www.amibay.com/showthread.php?t=20315 mediator drivers http://www.amibay.com/showthread.php?t=11993 p96 newres guide(radeon install) http://www.amibay.com/showthread.php...905#post325905
  4. #14
    Feb 2012
    Finland
    kokkola
    50 (100%)
    Theres another guide for that? Awesome.
    I had two problems that I managed to solve. 1) I had wrong version of installer so installing of BB1 failed. 2) System is write protected errors came up... I had to move things to different folder on the pc side of things...
    Now the final problem.
    I have an empty, unformatted 4GB compact flash and I have no idea how to transfer the classicwb into there. I succeeded in installing classicwb to winuae though... I shall search for your other guide.
  5. #15
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    147 (100%)
    once the cf is made from my sfs guide just add the folder of your cwb in winuae as a extradrive say dh2:
    just make sure you press enter with every change in hdtools
    and make a backup of the cwb just in case
    then in cli type copy dh2: all dh0:
    john
  6. #16
    Feb 2012
    Finland
    kokkola
    50 (100%)
    Okay this is as far as I get:
    I have ide->cf adapter plugged into a usb->ide adapter and cf card in ide -> cf adapter.
    I have gone to command prompt and given the following commands:
    diskpart
    list disk
    select disk 2
    clean
    I have winuae started from command prompt with:
    winuae.exe -disableharddrivesafetycheck
    dropdown box sees the drive... but then I cant figure out how to get the hdtoolbox to do anything with it.
  7. #17
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    147 (100%)
    see page 26-27 for how to add cf hd as you have it as ide0
  8. #18
    Feb 2012
    Finland
    kokkola
    50 (100%)
    With that other guide I am now getting some progress. Managed to partition! Next up formatting and transferring files!
  9. #19
    Amibayer! morcar's Avatar
    Feb 2008
    Wales, UK
    57 (100%)
    that is awesome thank you
  10. #20
    Feb 2012
    Finland
    kokkola
    50 (100%)
    Okay, now I have drive partitioned to system,work and tools. I have classicwb installed on hdf file in winuae. I can boot the hdf file alone but if I add the cf hard drive then it does not boot any more. Frustrating...
    I can boot from workbench floppy though and add both the hdf file and the actual cf hard drive and I see the followin partitions:
    Ram Disk
    tools
    work system
    System
    ClearRAM
    Install3.1
    I went to System, show all view by name and dragged everything from System to system... now rebooting...
    And SUCCESS! I have now ClassicWB booted on my CF card with winuae!
  1. winuae help
    By Justin in forum AmiOracle
    Last Post: 15th August 2011, 22:33
  2. Installing OS 3.9 winuae
    By Marc in forum AmiOracle
    Last Post: 14th August 2010, 07:45
Tags for this Thread
