Page 3 of 82 FirstFirst 12345671353 ... LastLast
Results 21 to 30 of 814
Thread: Solution for external Flicker fixer?
  1. #21
    St1ckman67's Avatar
    Aug 2011
    Age
    51
    0
    Ordered one of these today
    Johnim, If you are making cables for this, how much would it cost for one to be made?
  2. #22
    Amibayer! -Acid-'s Avatar
    Nov 2010
    South Shields
    Age
    42
    218 (100%)
    Ye ive ordered one as well, so i'll take you up on your cable offer just let me know what you would like in return
  3. #23
    Amiga user since 1989 Amibayer!
    Staff Moderator
    merlinkv's Avatar
    Oct 2009
    Spain
    Madrid
    Age
    55
    84 (100%)
    Looks like a nice solution.
    But if understand well, I need to made a custom cable (as showed in your pics) to connect to my Amigas.
    The "standard" Amiga-RGB to VGA adapter, don't work without modification, right?
    I don't know how it will be the third World War. But I do know how it will be the fourth: With sticks and stones.
    Here lies a brave, a formidable adversary and a true man of honor. Rest in peace. 04/21/1918
  4. #24
    Amibayer! UberFreak's Avatar
    Sep 2009
    Israel
    43 (100%)
    Hi
    From what I understand so far, this board can only output 60Hz, which essentially makes it not very useful for PAL (jerky motion in games & demos).
    Is this correct?
    Also, is the output resolution selectable, or is it set by the device according to the input H/V scan rates?
  5. #25
    VIP Chinners's Avatar
    Oct 2009
    North Yorkshire
    189 (100%)
    I just received one of these boards today, but am in 2 minds as to whether to use it or not - my monitor de-interlaces the image fine, and I can cope with the flicker, as all the games I play don't use interlaced mode...
    Anyway, my idea for using this was to use a scart socket as the input, feeding the video to the relevant pins, and passing audio out to a 3.5mm socket:
    Mig ---scart-------]vgabox[----VGA
    |---- Audio
    Then, I could use the same board to easily display my amstrad, st etc which all use different connectors but all can output to scart.
    Would this work as some sort of nice standard VGA converter?
  6. #26
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    147 (100%)
    hi guys for this cable to be made you need the multi cable that comes with board and power cable and either
    a 23pin female socket and housing for the video port( need to find a supplier)
    or a rgb to scart to be converted (can keep scart connector on for normal tv if needed)
    or an old 520 modulator for the a500
    or a 23pin to 15pin adapter not in use
    and maybe 4 resistors havent tried with them yet
    for the resistors from maplins
    let m know john
    A1200T 1d4:blizzard 1260/50/192mb/scsi kit:mediator 1200:radeon 9250:sb128:100mb net:spider usb clone:fastata-iv:amiga to ps2 mouse:80gb hd:zip100 ide:a4000 keyboard
    A1200D 1d4:blizzard1230mk4/50/64mb:indy mk ii:fastata mk ii:40gb*A1200 rev 2b*2 x A1200 1d4*A1200 1b*A600 2mb 4gb*A500
    PC:8700k@4.8ghz, Msi sli plus mobo, Corsair 32gb ddr4 3000mhz, Evga 1080ti ftw hybrid, Evo 970 m2 500gb.
    sfs cf guide http://www.amibay.com/showthread.php?t=19953 cwb3.9 guide http://www.amibay.com/showthread.php?t=20315 mediator drivers http://www.amibay.com/showthread.php?t=11993 p96 newres guide(radeon install) http://www.amibay.com/showthread.php...905#post325905
  7. #27
    Nov 2010
    South Shields
    Age
    42
    218 (100%)
    Is the 23pin female socket and housing for the video port amiga specific or is there a chance to find them somewhere on the web?
    rgb to scart to be converted (can keep scart connector on for normal tv if needed).. this option sounds good to me would you just take the video port and attach the cable that is needed from that?
    or an old 520 modulator for the a500 < will this be just to get the video port connector off?
    23pin to 15pin adapter - any idea where to get these from?
    and maybe 4 resisters havent tried with them yet for the resistors it cost 0.96 from maplins < will i need to order these or are you going to buy a joblot and ask for it back?
    Also mate, what/how much do you want for providing such a service?
    Barry
  8. #28
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    147 (100%)
    hi mate
    if wanted im looking for enclosure that it fits into the board is 115mm x 105mm about 40-50mm high to allow for heat sink dissipation
    mine is an old one
    Is the 23pin female socket and housing for the video port amiga specific or is there a chance to find them somewhere on the web? looking for female socket not found yet tho Have housings thanks to imnogeek
    rgb to scart to be converted (can keep scart connector on for normal tv if needed).. this option sounds good to me would you just take the video port and attach the cable that is needed from that? yes proberly best option
    or an old 520 modulator for the a500 < will this be just to get the video port connector off? yes
    23pin to 15pin adapter - any idea where to get these from? no
    and maybe 4 resistors havent tried with them yet for the resistors from maplins < will i need to order these or are you going to buy a joblot and ask for it back? maybe job lot ask back
    just price of components and return postage
  9. #29
    Amibayer!
    Staff Moderator
    johnim's Avatar
    May 2010
    birmingham
    Age
    43
    147 (100%)
    it looks like the 5v+ on pin 23 of the video port is not enough for this board the manual says 5v 2a
    but the port only gives out 100ma
    any ideas/help guys
    ---------- Post added at 21:44 ---------- Previous post was at 21:11 ----------
    i found the problem the 5v resistor was dead as it gave 5v before but 2v after so swaped with another and works now
  10. #30
    St1ckman67's Avatar
    Aug 2011
    Age
    51
    0
    Johnim, I got mine in the post just a few seconds ago so I'm gonna see what I can do with mine but for now I found this on YouTube http://www.youtube.com/watch?v=ARh1zfiKvGw that might shine some light on it.
  1. Sold External flicker fixer/Scan Doubler
    By the-topdog in forum Sales Archive
    Last Post: 17th October 2010, 01:32
  2. Closed Scandoubler Flicker Fixer *external*
    By Drummerboy in forum Found Archive
    Last Post: 28th January 2010, 02:40
  3. Closed WTB External Scandoubler/Flicker Fixer: Scandex, ToastScan..
    By xenon in forum Found Archive
    Last Post: 15th September 2009, 12:09
  4. Closed Wanted: External Flicker Fixer / Scan Doubler
    By systmcrsh in forum Found Archive
    Last Post: 18th October 2008, 19:03
Tags for this Thread
